Question about Encore Home
Need a lid for 13x9.5 inch pan - Encore Home
I need a new glass top for a EPC350 pressure cooker
Any 22cm /8.5 inch glass lid for normal pots and pans will fit.
Sep 13, 2015 | Pressure Cooker Home
How to preparare a cooked ham using cloves
  1. Preheat the oven to 350 degrees F (175 degrees C).
  2. Place ham in a roasting pan, and press whole cloves into the top at 1 to 2 inch intervals. Pack the top with a layer of brown sugar. Pour enough water into the bottom of the roasting pan to come to a 1 inch depth. Cover the pan tightly with aluminum foil or a lid.
  3. Bake for about 1 hour in the preheated oven or until the internal temperature of the ham has reached 160 degrees F (72 degrees C). Make sure the meat thermometer is not touching the bone. Let stand for about 20 minutes before carving.
Apr 24, 2014 | Computers & Internet
Need a replacement lid for an 84604 west bend 4 quart Oblong slo cooker
The only place I've seen them is on Ebay. The West Bend site doesn't seem to carry a replacement for the glass casserole lids any more. On Ebay I've seen the glass lids for both 6/4 quart models and 5/3 quart models. I am not sure, but I think the 6/4 pans and lids are just a little longer than the 5/3 pans and lids.
Oct 15, 2012 | West Bend Crock Pots & Slow Cookers
I have never had a smoker before is the water pan the bottom one or is that the wood chip pan?
Hi
To use your Brinkman Smoker or Other Smokers
1... Marinate or place a rub on the meat you will be smoking, and let it sit for a few hours or overnight in the refrigerator.
2...Cover your wood chips with water(and if you wish you can add some Jim Beam Whisky or other flavorfull liquids in a bowl with the water, 1 inch above the wood chips and use a flat peice of metal (pie pan,etc.)to weigh the wood chips down underwater.
You will do the wood chips at least 24 hrs before you plan to start smoking this gives the wood time to soak in the flavorfull liquids.
3...Start a fire in the smoker having the fire below the meat, but wait to put the meat on till the flames (if any) subside.
Use the water pan below the meat (if you use one) to catch the juices from the meat...it will be above the pan with the charcoal in it.
Use hardwood or charcoal for your fire/smoke,
Once the charcoal/wood are coated with gray ash, you can place the meat on the racks.
I would place an aluminum drip pan under the center portion of the cooking area on your smoker, to catch the juices from the meat, if you do not use a water pan.
4...Place the meat in the smoker on the grilling surface, and place the wood chips over the charcoal and hardwood in the main grilling area Close the lid and do not open it unless you must add wood chips during the cooking process.
Monitor the tempreture
5...Continue adding wood chips to the tray as needed during the time you are cooking.
If you have a Brinkmann or other smoker with one chamber for placing the wood chips and the meat, add wood chips only once per hour.
6...Apply your sauce to the meat one hour before the meat should be done.
Test your meat with a thermometer for for an internal tempreture of 160 degrees for medium and 170-180 degrees for medium well to well
Note: Apply the sauce quickly to avoid loosing the heat in your smoker if you leave it open too long it will allow the heat and smoke to escape, increasing the cooking time.
Close the lid if it needs to continue cooking till you reach the right internal tempreture
7...Test your meat with a meat thermometer after a few hours of cooking time.
Make sure your meat is at least 160 degrees internal tempreture for medium and more than 170 degrees for medium to well.
Close the lid and maintain your heat if it needs to continue cooking.
Please take time to rate me.
Sep 04, 2011 | Grilling
Need manual and cookware
The Use and Care Manual for the Hamilton Beach 31197 Countertop Oven with Convection can be found online here:
http://useandcares.hamiltonbeach.com/files/840156300.pdf
Any cookware you have that you are able to use in your regular oven can be used in the Countertop Oven providing it fits. You may need to purchase some smallersized ovenware from a kitchenware store.
Look for these pan sizes:
6 - cup muffin pan
2 - 8 x 4-inch (20 x 10 cm) loaf pans
9 x 5-inch (23 x 13 cm) loaf pans
2 - 8-inch (20 cm) round or square baking pans
Most 1 to 11⁄2 quart (1 to 11⁄2 L) casserole dishes
Trust this is helpful; thank you for using FixYa!
Aug 31, 2011 | Hamilton Beach 31197 120 Watts Toaster...
Where is the oil drain plug of a 2005 toyota sequoia ?
Look under the engine (not the transmission) for the drain plug on the engine oil pan.
The following is some information on how to change the oil pan:
REMOVAL & INSTALLATION 3.4L Engine
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Disconnect the negative battery cable.
  3. Drain the engine oil.
  4. Remove or disconnect the following:
    • Engine undercover
    • Front differential, if equipped with 4WD
    • Oil pan, separate it from the engine using SST 09032-00100 and a brass bar
    To install:
  5. Apply seal packing to the oil pan.
  6. Install the oil pan to the cylinder block. Tighten the nuts and bolts to: 67 inch lbs. (8 Nm) WARNING
    If parts are not assembled within 5 minutes of applying time, the effectiveness of the seal packing is lost and must be removed and reapplied.
  7. Install or connect the following:
    • Front differential, if removed
    • Engine undercover
    • Negative battery cable
  8. Fill with engine oil.
  9. Start the engine and check for leaks.
4.7L Engine
  2. Remove the engine from the vehicle and mount it on a stand.
  3. Remove or disconnect the following:
    • Oil dipstick tube
    • Lower oil pan
    • Oil pan baffle
    • Upper oil pan
    To install: Fig. 1: Upper oil pan bolt location — 4.7L engine 7924sg75.gif
  4. The upper oil pan bolts are different lengths and are identified as follows:
    • A: 0.79 inch (20mm) w/10mm head
    • B: 0.98 inch (25mm) w/12mm head
    • C: 2.36 inch (60mm) w/12mm head
    • D: 1.38 inch (35mm) w/10mm head Fig. 2: Upper oil pan sealant application — 4.7L engine 7924sg74.gif
  5. Apply silicone sealant to the upper oil pan as shown.
  6. Install the upper oil pan and tighten the fasteners in several passes to the following specifications:
    • 10mm: 66 inch lbs. (7.5 Nm)
    • 12mm: 21 ft. lbs. (28 Nm) Fig. 3: Lower oil pan sealant application — 4.7L engine 7924sg76.gif
    • Oil pan baffle. Tighten the fasteners to 66 inch lbs. (7.5 Nm).
    • Lower oil pan. Tighten the fasteners in several passes to 66 inch lbs. (7.5 Nm).
    • Oil dipstick tube
  8. Install the engine.
Sep 01, 2010 | Toyota Sequoia Cars & Trucks
When i put the ingredients as directed, i selected the program then put the delay on. when i woke up expecting fresh bread, i had a hard 3 inch brick with flour and yeast sitting on top of it. was i...
No, Everything should be done automatically. It seems that the machine did not knead the dough. Two things may have caused this. 1) The paddle is frozen and wont turn. Take the pan out of the machine and see if you can rotate the paddle by hand. If yes...that's cool, if no then the sealed bearing that the paddle rotates on is jammed or broken. Try filling the pan with warm water and let it soak. If after a few times it's still frozen, then the bearing is broken and bread pan needs to be replaced. 2) Belt fell off or is snapped. Keep the pan out of the machine and go to a kneading cycle. Look through the window on the lid and see if the motor shaft is turning. If no... the belt fell off or snapped, or the motor is broken. Good luck..Hank
Dec 03, 2009 | Oster 5836 ExpressBake Bread Maker
The pan is stuck in my Sunbeam bread machine
I just had the same problem. What the manual either does not tell you or hides quite well is that you have to TWIST the pan before lifting it out. I don't know why this was listed under the Panasonic bread machine when it clearly refers to the Sunbeam bread machine.
Feb 05, 2009 | Panasonic SD-YD250 Bread Maker
Home Logo
22 people viewed this question
Top Encore Home Experts
Donni Steen
Tom Chichester
Are you an Encore Home Expert? Answer questions, earn points and help others
