Jvc tv lt22dd1bj
How to re tune
JVC TV LT-24DD52J unable to tune in tv, tried auto and Manuel tuning but get error. Message NO CHANNES FOUND can you please help
Check and replace the tuner. It is faulty. If you wish to get some details; visit the site linked here. Pull up older posts.
May 21, 2017 | JVC Televison & Video
Can you tune in a JVC LT - 32DY8ZJ TV without a remote control?
As there is no Menu button on the front panel of the TV, you must have its remote control to tune it.
Nov 15, 2012 | JVC Televison & Video
I do not have a remote control with my dvd player. How do I tune in my dvd player to my jvc tv remote? I can play dvd's but I cannot use the arrows to select options. thank you
U can't not tune tv and DVD player together.Each have own signal frequencies.Try website like Remotes.com to buy an original or very close to the original remote.
Dec 17, 2010 | JVC AV-32120 32" TV
Can't get my new DVD/VCR to work.
I read the instruction manual one more time. It said to tune my TV to Video and voila, the VCR worked. All JVC VCR's seem to need the tv tuned to Video to play back. I had an older JVC VCR and I had to do the same thing with it.
Thanks anyway.
Jan 18, 2010 | JVC Televison & Video
Need to tune universal philips sur5010 remote to a jvc tv
  1. Turn on the TV manually.Tune in to channel 1.
  2. Keep keys 1 and 3 pressed simultaneously for three seconds until the LED flashes twice and then remains lit
  3. Then enter 4 digit code. The LED will now flash twice and thenremains lit. The code has now been stored in the memory of the SRU5010.
    If the LED flashes once for an extended period, the code has notbeen entered properly or the wrong code has been entered. Start again from step 2.
  4. Point the SRU 5010 at the TV and check that it responds as it should.If the TV responds to all of the key commands, the SRU 5010 is readyfor use. Do not forget to note your code.
JVC CODES: 0036, 0680, 0220, 0398, 0245, 0445, 0063, 0120, 0633, 0677, 00710
Link to manual
Sep 01, 2009 | JVC AV-32D305 32" TV
Connect vcr to jvc c2033us tv
You will need to put your aerial into the rear uhf socket of the VCR then take another connecting lead (flylead) from the out of the VCR & put this into the aerial socket of the TV. You will now need to select a channel on the TV (best to use channel zero) & tune the TV to the VCR signal. The best way to do this is to put in a recorded tape eg a film /press play/ then tune the TV until you pick up the playback of the film, then store this on the TV. This will give you your VCR channel. You will now need to tune the VCR to your broadcasted stations so that you can record.
Apr 01, 2009 | JVC Televison & Video
JVC TV tuning
my interi art jvc television with cant tune manually n i need help to operate it
Oct 19, 2008 | Televison & Video
Color problem
Please fine tune those B/W channels to obtain color picture. If TV is more then 4 - 5 years old, it needs resoldering in tuning area or might need replacement of IF block.
Aug 01, 2008 | JVC AV-21meu 21" TV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
