SOURCE: Dish Network - Dish 500 Satellite 110 is not being recognized
Lonnie, You have a simple problem,the 119 satellite is lower in the sky than the 119 if you make sure the pole you are mounted on is straight and plum ,then simply raise the dish a few elevation degrees and turn the dish to the left.Your dish is aimed low and to the right.
SOURCE: Dryer problem
you need a service call on it the smell could be a buid up of lint on the element.
SOURCE: problems with my heater
Hi
I just had the same prblem and had a gasfitter out yesterday to have a look at mine. He suggested to me to take the front panels off and use a compressor to clean out all the dust that has built up. My filters were clean as they get cleaned every week but as therinnaiguy said it is a overheat safety device.
I used my compressor and blew out all the dust it makes a fair bit of a mess but it seems to be working fine now. Just be careful when u use the air not to directly blow it around the electrical area.
There is also 2 wires u need to disconect u will see these when u take the cover off and also make sure u unplug the the power to the unit.
Hope this helps.
Glenn
SOURCE: Can an landlord of an aprtment complex not renew a tenant's lease
check your lease aggrement, and also your state laws on renters rights, you can find them on the internet !!!!
SOURCE: Hello. I just moved into
Hello & Welcome to FixYa
Error code F1 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Sorry for the bad news but hope you understand... Please get back to me if you have any other questions.
Kevin
