My lg tv wont turn on
TV WAS ON PLAYING FINE AND JUST WENT OFF LIKE SOMEONE TURNED IT OFF NOW LIGHT ON FRONT PANNEL WILL BLINK BUT SET WONT TURN ON?
  • 3 Answers
SOURCE: TV WONT TURN ON
I'm going throught the exact same thing right now. After the lights quit blinking, and the blue light goes off, does the red lamp light stay on. This usually means your lamp has gone bad ($200.00 plus). But when I ordered the lamp, it did the same thing. Had to have the certified hitachi repair man come out for the and told me it had to be a bad lamp, so I ordered a 2nd one with the same result. He came out again and had to take the TV away, later telling me the ballast must have blown when the original lamp went bad. Another $200.00 part. I haven't fought this one with Hitachi yet but am going to try. The ballast shouldn'e go just because the lamp goes out. The set is only 21/2 years old and I've already had to spend about $700.00 on the light enging replacement and now this lamp and ballast expense. Love the TV but would expect a lot less problems from a $2500.00 top model Hitachi. I'm going to see if they feel the same way, hopefully not but I'm not real optimistic they will care. Hope this helps.
Posted on Dec 17, 2007
  • 135 Answers
SOURCE: Sharp Aquos wont turn on
this is either a power problem or the screen needs re-gasing
Posted on Jan 18, 2009
  • 5 Answers
SOURCE: red blinking light when tv is turned off
if this is a 37lg30 i have brand new spare parts. the tv was never used it was dropped and the screen was damaged so i just took out the parts out. i was originally looking for some one that had a problem with there tv but a good screen like you but its easier to ship out the boards.
Posted on Jun 06, 2009
SOURCE: 42 inch olevia wont turn on...worked fine the
Sounds like the power supply.
Posted on Sep 08, 2009
  • 5 Answers
SOURCE: Vizio TV wont turn on after three weeks no use
My vizio recently did the same exact thing. Vizio sent an HDTV tech out to fix it and it was the power board. He put a new board in (took 15 min) and the tv works like new.
Posted on Jan 25, 2010
My phillips 60 inch tv 60pl9200d/37 wont turn on the power button flashes blue
Look in the manual. (Page 4)
Turn the TV on From main supply: Ensure that the main supply is turned on. A blue indicator light on the front of the TV lights up. When the TV is turned on by the main supply, the blue indicator light will blink for 45 seconds. This is the lamp's start-up period. When the light goes off, press the POWER button on the remote control or power switch. Press POWER to turn on the TV.
http://www.retrevo.com/support/Philips-60PL9200D-TVs-manual/id/633ag423/t/2/
Telephone number Philips Customer Care Center: 1-888-PHILIPS (744-5477)
Aug 14, 2011 | Philips 60PL9200D Projection Televisions
19 inch lg flat screen tv wont turn on
Power Supply board is dead.Tries Websites Shopjimmy.com,Ebay.com.Buy a refurbish power supply board for the replacement.
Mar 24, 2010 | LG 19LG30 19 in. LCD HDTV
Power went out now the tv wont turn on, there is just a blinking
Does the power light just blink? Some of the Mitsubishi sets have a receiver built into them; if the power is removed the power light upon return of power should blink for 70 seconds and then go out--then the set should turn on---if the light never stops blinking---2 possible things--set should have a recessed button on the front keyboard(reset) that you can depress with something not sharp and see if after 70 seconds the light will stop blinking; if no, the set now has a damaged receiver(from the back of the set it is a large metal box on the far left side-----the blinking power light is the receiver trying to boot up like a computer---only should happen if power lost---let me know what you find----the receiver if bad is usually no longer available and can only be repaired by removing it and sending out for repair/rebuild.
I do this here for free so if this information helped you take a minute and give me a vote here......ALSO IF YOU HAVE ANY QUESTIONS OR NEED HELP REPLY TO THIS POSTING.
SD TECH
Sep 07, 2009 | Mitsubishi WS-55711 55" Rear Projection...
WS-55517 Mitsubishi Rear HDTV projection tv will not turn on
2 blinks followed by 1 blink is the X-Ray protection-----means some problem in the High voltage circuit ---set produces over 25 thousand volts to fire the 3 picture tubes inside up----It could be excessive high voltage-------I think you would have to get lucky for someone to find and fix it in your home----more likely it will need a visit to a Repair shop.
Aug 20, 2009 | Mitsubishi VS-50605 50" Rear Projection...
TV screen turned on for only 10-15 secs then self turn off, followed soon after by the tv power another 10-15 seconds later. if i try this a few times screen wont light up at all.Is it the TV Lamp?
1) Can be dust do a good clean
2)Check for the fuse and change it if needed.
3) Capacitor needs to be changed, you'll have to findout which one.
Hope it helps, good luck
May 19, 2009 | LG RU-52SZ51D 52" Rear Projection...
Lg. screen tv mitsubishi HDTV 1080 SERIES INTEGRATED
i went to turn on the tv and the power button don't work
Jun 02, 2008 | Televison & Video
TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Mar 13, 2008 | TruTech PLV1615T 15 in. LCD Television
Operating tv
there is a short inside the set, count the times that the led blinks before it pauses and let us know make & model number of set, model # is on a sticker on the back of the set, with that info and the blink code maybe we can help you out
Nov 28, 2007 | Televison & Video
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
