Question about Karcher 2.642-188.0 Pressure Washer T-Racer Wide Area Surface Cleaner
Arm does not rotate
The rotor arms do not rotate either at all or very slowly, meaning that cleaning is not working at all.
Why doesn't upper spray arm function properly?
A couple of scenarios could cause this problem but the simplest might be the way the dishwasher is loaded. The upper spray arm rotates when water is pumped through the vertical supply tube and into the arm. Make sure that you are not loading the lower rack with items that interfere with the rotation of the upper arm rotor. It might also be a good idea to verify that the feed tube that goes to the spray arm is securely connected to the vertical supply tube.
Dec 02, 2015 | Kenmore Dishwashers
Why are the items on bottom rack not being cleaned properly
If is clean dishes in the upper basket, I conclude that the pump produces enough pressure what means that the lower spray arm for some reason does not rotate and because that washing result is bad. Before washing I would check the lower spray arm rotates freely and after that open the door during washing and check if the lower spray arm rotates. Sometimes, the holes in the spray arm clog and disable turning which leads to poor washing results in the lower basket.
Dado
Aug 17, 2014 | Indesit Dishwashers
Frigidaire gallery prof series dishwasher- arms dont work
Hello - I suggest verifying that there is enough water pressure coming into the unit. Do you noticed if the spray arm is cracked or broken? Will it rotate slowly? If so, you might have to remove and replace the spray arm assemblies.
Oct 05, 2012 | Frigidaire Dishwashers
Why is the top sprayer is not rotating?
This dishwasher uses a pulsating mechanism to push water to each of the spary arms forcing water alternatingly in each arm. This ensures a strong spray is maintained for cleaning.
The pulsating action is obtained through a ball (see item 58 in this diagram). It is possilble that this ball is either stuck or is damaged and needs to be replaced.
Sep 21, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Top arm stopped rotating on Bosch clasixx
not worth fixing, you are better off putting that money towards a new one. unless you can find the arm and repair it yourself
Nov 10, 2011 | Bosch 24 in. SGS43C12 Classixx...
The top drawer of our F & P dishwasher is showing and F2 fault, I have just fitted a new front control unit. F2 is the pump I believe, where on the unit do I find that?
The F2 fault implies there is a problem with the motor rotor which is located under the drain plate at the bottom right in the centre of the drawer. The rotor is actually driving the wash arms.
F2 does not necessarily mean you have to replace the rotor. It is also possible there is some debris inside the rotor cavity which is preventing the rotor from rotating at the normal speed.
Remove the racks and the wash arm. Twist the centre ring so that it disengages the drain plate. You can then pull the rotor out with a few back and forth twisting motions. Check if the cavity is clean. Re-insert everthing and start the wash cycle. If F2 comes in again, you will have to eliminate the cause by using the rotor from the bottom drawer and see if it makes any difference. You may then have to buy a replacement part.
good luck
May 26, 2011 | Fisher and Paykel 23 in. DD603H SS...
The unit goes through its cycles but the top rack is not getting clean. The bottom spray wheel works, the middle and top spray arms are getting water but it seems not enough to make them rotate. The pump...
The problem is likely to be that the jets in the rotor arm are blocked.
To check this, remove the arm (it is easy to do, as it is intended for the user to do this) and clean out all the holes. Try running water from you tap through the holes (backward flow) to remove anything that is too large to pass through the jets.
Sep 26, 2010 | Dishwashers
How do i release tension on a 2004 pontiac vibe
Take note of the tensioner pulley and the tensioner arm that extends from the pulley. The tensioner pulley is the smallest pulley and has a metal arm extending from it. A bolt is located near the top of the arm. Place a ?? mm wrench on the tensioner arm bolt and rotate it forward to relieve the tension on the belt. Do not release the tensioner arm.
Pull the belt off of the pulleys and slowly rotate the tensioner arm back into its original position.
  • Step 3 Place a 15 mm wrench on the tensioner arm bolt and rotate it forward to relieve the tension on the belt. Do not release the tensioner arm.
  • Step 4 Pull the belt off of the pulleys and slowly rotate the tensioner arm back into its original position.
  • Read more: How to Change the Serpentine Belt on a 2004 Vibe | eHow.com http://www.ehow.com/how_6195672_change-serpentine-belt-2004-vibe.html#ixzz0r59RR9UO
    May 20, 2010 | 2004 Pontiac Vibe
    My maytag mdb8600aws jet clean 2 only cleans dishes in bottom
    The seals that the racks "plug" into need replaced. Ours had the same issue and replaced the seals and it works fine now.
    Nov 23, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
    Later LG model, I don't remember # upper arm doesn't spray/rotate, just trickles water
    The Lg D/washers normally have a fascility that allows one to choose either the upper arm or the bottom arm or both to run as you choose. there is an actuator that can stick which would cause this problem. Otherwise simply, your rotor needs a good clean.
    Sep 24, 2009 | LG 24 in. LDF 7811 Stainless Steel...
    Karcher 2.642-188.0 Pressure Washer T-Racer Wide Area Surface Cleaner Logo
    14 people viewed this question
    Top Karcher Garden Experts
    John Trevino
    Are you a Karcher Garden Expert? Answer questions, earn points and help others
