Question about HP Office Equipment & Supplies
Won't scan it will print and copy but will not scan.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 166 Answers
You may have to load the software for the scanner to work easily. You should be able to download it from HP's website. Here is the download site:
HP Download Site
http://welcome.hp.com/country/us/en/support.html
Just put in your model number and select drivers and downloads. Make sure you select the correct software and Operating System version.
Posted on May 21, 2009
Won't scan, error message -scanner door is open
Simple solution. I just had the same problem. Make sure the top cover on the left side is snapped in. It wasn't obvious that it was open. They should probably give a better code because it is not the scanner door that is open.
Apr 16, 2013 | Samsung New-scx-3405fw Wireless...
Barcode scanner won't read printed labels
1. The printhead in your printer might be scratched (evidenced by thin white streaks through your print). This is common, and the most likely cause. Printhead must be replaced.
2. Material might be stuck on your printhead (usually evidenced by wide white streak vertically through print). Printing surface of printhead can be cleaned with rubbing alcohol and cotton ball.
3. The ribbon might be wrinkling due to uneven tension, producing intermittent diagonal streaks in your print. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment and/or proper media loading solves ribbon wrinkles.
4. Poor pressure and/or printhead alignment. Evidenced by grainy, light or no print on one side or the other of the media. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment solves printhead pressure and alignment issues.
Dec 11, 2012 | Datamax E-Class E-4203 Label Printer
Kyocera CS-C2525 won't scan
Do you have the option installed on you copier??? Also, there is another ether connector for scanning. If it is installed it is right above the print PCB.
May 22, 2012 | Kyocera Copystar CS-5035 Copier
Hp 380 allinone won't print or copy but will print something i scanned in
it is better dont purchase HP series.. its all waste... they are simply selleing by advt. No customer service. Useless....
Dec 14, 2011 | HP DeskJet F380 All-In-One Printer
How to put printer in print mode
Actually, it does not matter what mode your printer is on when printing from your computer. Whenever your printer detects a print job sent to it, the printer will automatically acknowledge the signal and print the file - no matter if it's on Copy, Scan or Fax Mode.
Aug 26, 2011 | Lexmark X5070 ALL-IN-ONE InkJet Printer
Does not copy or scan. light flickers
everytime i try to print something it goes to this box and won't print
Jun 23, 2011 | HP DeskJet F380 All-In-One Printer
How do I copy documents?
Unfortunately you won't be able to copy directly from this machine since it's only a printer. If you have access to a scanner you can use it to scan your document, save it to your machine, and then print it on this device. Otherwise you'll need to purchase a Multi-Function machine that includes a Scan/Copy feature.
May 05, 2011 | HP Hewlett Packard LaserJet 1018 Printer
Printing problem
how can we print a booklet on this printer
Mar 15, 2009 | Lexmark X1240 All-In-One InkJet Printer
Officejet 6110 all in one - printing problem with Mac Os X 10.5
I suspect this is not the printer problem. The problem may be the operating system issue. (Memory management)
Regards
Rafique
Jan 22, 2008 | HP OfficeJet 6110 All-In-One InkJet...
35 people viewed this question
Seeker5211
Seeker5211
