Question about Coleman Powermate Premium Plus 6250W Portable Generator
No output from my generator
My generator runs fine but doesn't produce any output voltage. It did wirk when I first got it but within about 2 hours it stop putting out power.
  • dalebartelds May 22, 2009
    Thanks for the reply. I did check the breakers. When the generator first started to loose output, I was able to make it work again by resetting the breakers but now that does not have any effect.
    I tried to flash the field also according to the information I found at PER Notebook by back-feeding an electric drill. That didn’t work either.
  • Juan Gonzales May 22, 2009
    No power to output 120/240 4500 watt colman subaru
Check the capacitor in the generator head. Will onpen or short cause loss of excitation voltage. Just checked my GENERAC ( no output) and sure enough the cap is shorted.
Posted on Mar 22, 2010
Check breaker, your outlets should be like a gfi
Posted on May 21, 2009
  • jhallen58 May 21, 2009
    check breaker, your outlets should be like a gfi
Generator low voltage
It could be several things but it sounds like it just running too slow. I would the engine rpms first. Depending if is a two pole or four pole and if your 60hz or 50 Hz on the needed unloaded rpms.
Example: 2 pole 60 hz. Engine needs to be running at 3600 rpm loaded and 3750 rpm unloaded; unless, it has a fuel saving mode.
A 4 pole 60 hz would running half this rpm. The 2 pole producing 50hz would have the engine running at 3000 rpm loaded (about 3100 rpm unloaded)
Now in order for the 50 hz system to produce the same output voltage it requires a different alternator than the 60 hz version; otherwords, You simply can't convert a 60 hz to 50 hz version without changing the alternator by changing the engine speed.
Dec 29, 2014 | Electrical Supplies
Honda eu3000is generator surges
Inverter Generator Benefits
  • The EU3000 series generators are inverter generators. The generator features an alternator, which produced high-voltage, multi-phase AC power. This power is converted to DC power and then converted back to AC. This process is controlled by a microprocessor and is necessary to provide stable, consistent power capable of running equipment sensitive to power surges. This type of generator provides higher fuel efficiency and lower operational noise ratings in a lighter model than home and work generators produced by Honda.
EU3000i Handi Specifications
  • The Honda EU3000i Handi is a 3,000-watt inverter generator that features wheels, folding handle and a recessed convenience light. The engine is a Honda GX160, which features a 163-cc displacement. The AC output is 120 volts, with an average rating of 2,600 watts and a maximum production of 3,000 watts. There are three receptacles to include a 20A, 125-volt duplex and a 30A, 125-volt locking plug. The DC output is 12 volts and 100 watts. The EU3000i can hold 1.56 gallons of unleaded fuel, which will provide consumers with 3.6 hours of run time at 25 percent load for 7.7 hours.
performance chips of BMW.
May 31, 2012 | Honda Eu3000is
Generator runs fine- does not produce any power- checked breakers all ok
The voltage regulator for the generator is not work, replace it. Why, if there no dc voltage to excite the stator it won't any output. GB...stewbison
Aug 31, 2011 | Northstar Generator 9 Hp, 5500 Watt,...
GENERATOR WILL RUN BUT DON'T PRODUCE ELECTRIC
Hi and welcome to FixYa, I am Kelly.
Without a model number... I am guessing about what type / brand and MODEL of generator you have. I have to assume it is a Coleman Power mate.
Try flashing the field. Do this.. take and electric drill and plug into the outlets of the generator. Turn on the output power GENERATOR ON. Squeeze the drill trigger and rotate the chuck as fast as you can. This will induce voltage into the stator and they usually will start producing power. When it does produce power it will try to yank the drill chuck head out of your hand so keep that in mind.
If the above does not work...
Remove the small cover from the center of the endbell. It covers the end of the rotor shaft and has 2 brushes under the cover.
INSPECT the brushes visually (do not remove them yet)
(Generator OFF!)
Use a meter to read resistance by probing the electrical contacts of the brushes. You MUST read LOW resistance. This is the rotor winding.
No resistance or high resistance
Remove the brushes inspect for damage. Try to probe the slip rings of the rotor. (You might have to make a 14/2 Romex electiral wire extension to get some solid copper wires to touch the rotor slip rings) Again you must read LOW reistance.
If you have low resistance and the brushes are good.....
Reinstall the brushes. (TEST for AC) Start generator
STILL NO OUTPUT?!!!!
Use a meter on DC to read AVR voltage output to the brushes by probing the brush terminals. You should read 3 - 7 VDC. No voltage.... hmmmm Possibly an AVR problem but...
Try this.
Rig up a 9 Volt battery that you TAPE the wires to the battery terminals and the case of the battery
Just loosely connect the 2 wires to the brushes. Wrap the battery with a rag it might explode if you don't remove it fast enough. Your going to yank this off as soon as it produces power QUICKLY.
Plug in a light or a small fan so you can see that power is being produced. Let it run a few minutes before shutting it down.
To do anything else I need to know your generator model number to do winding and voltage regulator checks.
Thanks for choosing FixYa,
Kelly
Aug 30, 2011 | Coleman Electrical Supplies
7 hp brigs engine on my generator runs two fast producing 127 volts. how do I slow it down?
Hi and welcome to FixYa. I am Kelly. Since you did not mention the make or model number of your generator I will respond in generic terms. If your generator is at 127 volts with NO load it is adjust at the very top end of the manufacturers limits. There is a 10% tolerance so 120 VAC + 12 is 127 VAC. Under an electrical load above 500 watts the generator should drop the output voltage slightly so your generator would still be within factory limits. Personally on any generator as a repair person; I set the output voltage at 126 VAC no load so that when the user puts the generator to work the output voltage is good. If your generator is running at 127 VAC under load then you can adjust the governor screw on the governor plate CCW about 1/2 turn to drop the voltage. Without a generator model number or engine number I can not tell you exactly where the governor plate is on your engine / generator. The screw will have a lock nut that you must loosen 1/4 turn then turn the adjustment screw CCW to drop the voltage. Just make sure to re-tighten the lock nut when the adjustments are complete. Mind you by decreasing the output voltage you also drop the output freqency at the same time you decrease the output voltage. It is better to have 125 -127 VAC under a no load condition as the more electrical load you add the more voltage drop you will notice. It is best to adjust the generator to 122.5 -123 VAC under a medium load. (50% of output capacity) A bread toaster is 1400 - 1600 watts and is a good load for a 3000 watt generator. Also a good hand held hair dryer will use around 1600 watts. If you use this type of load and the voltage output is 122.5 to 123 VAC I would not adjust anything. I have been working on generators since 1970 so this is nothing new for me. I hope that you understand everything I posted. If not, feel free to ask as many questions as you wish in any future response.
Kelly
Jan 08, 2011 | Craftsman Electrical Supplies
Black max 7kw generator high voltage output
Those voltage readings MAY be normal.
The AC waveform may cause your meter to read inaccurately. You would need to use a TRUE RMS meter to accurately read the voltage.
The siple meters actually read the AVERAGE voltage and then are calibrated to mulltiply it by the "form factor" for a sine wave. OFTEN these generators don't produce a clean sine wave. A square-ish wave will read higher on the garden variety meters.
Compare the brightness of a lamp comparing to when run on your utility.
The frequency depends on engine speed ... yours is running a bit fast...check it under at least half load and if off, adjust the govenor slightly.
May 01, 2010 | Briggs & Stratton Power Products 5,550...
Generator runs, but produces no power
If it's still under warranty take it back to the retailer and tell them it quit working - don't offer any other information.
If you must fix the E/G yourself - On the generator there's a cover on the back; take the cover off so that the back of the windings are exposed. You should see 4 to 6 diodes mounted to the rotor and stator...those diodes are most likely burned out because of temperature failure, due to overload. You have to take them out to isolate them...they should read .6 Ohms one way; reverse the leads and they slhould read about 1.2 Ohms. If there shorted you'll read 0 Ohms and open infinety.
Anyway, replace those diodes and you should re-establish your field winding voltage which develops you A/C output.
Good Luck,
Mike...
Nov 22, 2009 | Coleman Powermate Proforce 2500 Generator
5500 generator stopped producing eletric after
First check with the dealer and see if it is still under warranty. If it is not, make sure nothing is blocking the air flow around where the control modules are located. This could cause the voltage regulator and other electronic parts to overheat. Next check the brushes and make sure they are free of any dust or build up preventing them from making contact.
If everything is OK the next thing I would do is change the voltage regulator.
Nov 17, 2009 | Coleman Powermate Powermate 5000W...
Battery Light on and the Battery is fine but will not keep charge
RECHECK the New Alternator This is Not Unheard of as I Have Experienced it Myself Several times.
After RULING it out and the Fallowing,Main relay box Power terminals, Corroded Loose fit nuts Etc.
Consider Voltage Regulator, Read the fallowing "CAREFULLY"
CIRCUIT OPERATION
The Electronic Voltage Regulator (EVR) is not a separate component. It is actually a Voltage regulating circuit located within the Powertrain Control Module (PCM) . The EVR is not serviced separately. If replacement is necessary, the PCM must be replaced.
Operation: The amount of DC current produced by the generator is controlled by EVR circuitry contained within the PCM. This circuitry is connected in series with the generators second rotor field terminal and its ground.
Voltage is regulated by cycling the ground path to control the strength of the rotor magnetic field. The EVR circuitry monitors system line Voltage and battery temperature (refer to Battery Temperature Sensor for more information). It then compensates and regulates generator current output accordingly. Also see Charging System Operation for additional information.
FOR Detailed Diagrams,on Entire Charging system they Must be Emailed,as they are too Large for the Formatting that "FixYA" uses my Email add. is My nickname here but add @aol.com By all Means If this is of Help to you , Then PLEASE RATS Me Thank you and have a Blessed DAY rejakwilson
Jan 21, 2009 | 1997 Dodge Caravan
Powermate PM0496500.02 No voltage output
Here is a simple test to check field and other wiring. With engine off apply 12v ac 1 amp to 110v outlet plug on generator. This will energize the field windings and should cause the armature to produce dc voltage at the brushes and produce a nice magnet. If there is a short in the field or broken wire or shorted capacitor there will be no dc reading at the brushes. . This test is the opposite of what actually occurs when the engine is running. That is the armature produces a magnet fed thru the windings, regulator and brushes. If dc voltage is present at the burshes, remove 12v ac and start engine to check for output. enjoy
Oct 23, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
1,286 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
