Question about Convair Portable Air Conditioner
Replacement Drain Plug required for Convair Supercool NR
I am looking for a replacement 'Drain Plug' for a Canvair Supercool NR. Can you assist me ?
flatech
  • 111 Answers
SOURCE: Hello
You can download the PDF owners manual from here just go to service and pick your Model type.
http://www.convair.net.au/Convair_Service.htm
Good Luck!
Posted on Nov 13, 2009
  • 289 Answers
SOURCE: I've just bought a second hand convair supercool
nead to know mod#.
Posted on Nov 22, 2009
hvac1960
  • 2133 Answers
SOURCE: how do i reset the
E-2..(Thermostat sensor)This error means that the unit has gone into a protection mode.
Check indoor coil sensor circuit closed. Check with ohms testing two ends, should read something. If it doesn't read any thing, replace the sensor.
Posted on Dec 16, 2010
  • 59 Answers
SOURCE: Free standing Convair Supercool leaks
The water is being generated from humidity inside the air. The air conditioner also acts as a dehumidifier. The black line is the drain. The drain line needs to go to an outside line or to a container to collect the condensated water. With low humidity levels, the water will evaporate back into the air. With high humidity, the water is removed from the air at a higher volume than can evaporate back into the air.
Posted on Jan 29, 2011
  • 114 Answers
SOURCE: Re: Convair Supercool Fan is functioning
Is the compressor running?
Posted on Aug 03, 2011
My portable con air supercool air on Is saying the tube sensor is damaged can I fix it myself and where is it locaated
This is a dealer specific part and should by no means be repaired by a home handyman, even with decent welding experience. there are many complicated steps involved with multiple specialized tools. please call your local HVAC tecnician.
Dec 31, 2014 | Convair Portable Air Conditioner
You know, it smells stale. What can I do about the odor? I didn't want to come out and say it "smells like ****."
Pull the panels on the unit look at the drain pan you will probably see a lot of stagnet water turned moldy you can remove this by flushing the drain pan. Also using simple cleaner to freshen up the unit. You can buy some evaporator coil cleaner that requires no rinsing to clean the coil that will freshen it up a bit.
Jun 27, 2011 | Convair Portable Air Conditioner
Free standing Convair Supercool leaks like a sieve! We have no manual. Does the small black hose pipe drain the water from the white pipe at the bottom rear of the unit [ where most of the water is coming...
Jan 29, 2011 | Convair Portable Air Conditioner
How do i reset the E2 code error on the aircon the model is convair supercool portiable unit
Dec 16, 2010 | Convair Portable Air Conditioner
I have a Convair Westwind air cooler that you fill with water. I have lost the plug that holds the water in. Can you send me one (or two) of these plugs?
Howdy, we have no affiliation with Convair corp. As we are a general solutions and technical assistance with everything website.I have, however found the contact info for them :
CONVAIR COOLER CORPORATION
I hope you found this useful, thanks for using fixYa.com. Farmerbear
Sep 02, 2010 | Samsung AW1203B Air Conditioner
Convair  Portable Air Conditioner Logo
78 people viewed this question
Top Convair Heating & Cooling Experts
Pete Norton
AJMAL KHAN
David Payne
David Payne
Are you a Convair Heating and Cooling Expert? Answer questions, earn points and help others
