Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Konika minolta c350 code list - Konica Minolta bizhub 350 All-In-One Laser Printer
  • Konica Minolta Master
  • 6,161 Answers
  • 214 Answers
SOURCE: Konica Minolta biz hub c350 malfunction code c-0b4c
C0B4C Finishing option Exit Motor malfunction
Try reboot holding utility key down and do trouble reset, if it doesn't help then there is something wrong with exit motor, call for service
Posted on Dec 07, 2007
Nicolomd
  • 84 Answers
SOURCE: I want cd for instale KONCA MINOLTA PAGEPRO 1300W (driver)
Try this driver (choose the operation system)
http://crm01.konicaminolta.eu/openmind/technic/kmpsdwl.nsf/psearch?OpenForm&ch=PRI&dist=BPE&ui=en&dg=sw&prod=PagePro%201300W&dsg=&os=&lang=&ml=0&rid=41256849005CE173&sub=Printer%20Driver&pcat=B%2FW%20Printer&pcc=1
don't forget to vote!!!
Posted on Jan 19, 2008
Nitrotrike
  • 589 Answers
SOURCE: copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
Posted on Feb 10, 2008
firecontrol7
  • 6161 Answers
SOURCE: KONICA MINOLTA BIZHUB C350 WITH ERROR CODE C0960
Check your bypass tray, the tray is on the right side of the machine, the tray flips out for legal and 11x17 paper sizes. Check that there is nothing jamed inside, code says that the tray can't lift. so check for anything jamed inside down there. As to reset the code open then close the front door where you put the toner. Turning the machine on and off will not reset the code. but open and closing the front door will clear about 80% of the service codes.
Posted on Jul 25, 2009
  • 5 Answers
SOURCE: error code c0520 konica minolta c350
How to clear a fuser error code (C0500, C0501, C0510, C0511, C0520, C0521).Solution To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
2. Insert a suitable object into the hole to actuate the reset switch .3. The code should clear and a message to close the front door should appear.
Posted on Feb 19, 2010
How i replace waste toner of c350 konika minolta
its on the side of the machine I believe its the left theres a little door that swings open its in there
Jun 18, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Code error 0060
Fusing drive motor failure check the fuse the hot section of the machine REPLACE the fuser first if not that then the fuser took the motor out worse case the fuser took the motor and the control board.
Konica minolta bizhub c350 error codes c-0510
eror code c-0098 meaning ??????????????pls tell me the solution
Jul 31, 2012 | Konica Minolta Bizhub C350 Digital Copier,...
C350 is printing is not clearly other color is over lap and shade
Clean the LED assy with the jig that you have inside the front cover.
Jul 03, 2009 | Minolta C350 Printer
Konica Minolta C350 colour copier T096 error code??
Transfer belt code C096 mite try open and closing the front door where you put the toner. Also remove the image transfer belt and then reseat it.
Apr 10, 2009 | Minolta Office Equipment & Supplies
Error code on Konica Minolta C350
There is not a C0876 listed in the service manual. Perhaps it's a C0B76 - Finishing option Punch Unit Board Malfunction.
CAUSE: The shaft on which the gear rides is deformed. The punch unit cannot be driven from front to rear.
SOLUTION: Reform the shaft toward the punch unit rail. This will allow the drive gears to mesh properly so the punch unit can be mechanically driven from front to rear.
Aug 28, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
20 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
