Question about Dishwashers
Bush wqp12 9270
Won't drain
Hi my dishwasher switches on but then does nothing ...The on/off button was faulty for a while before this happened...The machine is just over 3 yrs old
Posted on Sep 14, 2014
Bush fridge freezer water not draining away
Not draining away from where? There is probably a plugged drain hole or hose somewhere.
Jan 03, 2017 | Bush Refrigerators
I have downloads Avast anti virus on my Bush Tablet 2 but the file won' t open
Are you sure you downloaded the correcto version for Bush Tablet 2. Should be Avast for Android.
Jul 03, 2014 | Computers & Internet
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
Bush 32ODTR DIGITAL TV RECORDER WON'T SWITCH ON BUT STANDY BY LIGHT IS ON
there might be a slight loose connection have a look and make sure all cabels are plugged in .
Jun 06, 2012 | Bush Televison & Video
Machine pumps and drains, but the drum won't go round in wash, rinse or spin cycle. I have checked the bushes and they are ok. I cannot see any error code. Bosch WFX145SGB
Bosch WFX145SGB This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jul 21, 2011 | Washing Machines
My car sounds like ship in ocean every time i go through smaall umps on road can i put oil in the rubber bushings or is there something else i can used to lube the rubber bushings on my front suspension
I would not recommend oil, but a silicon based lube would be much better and won't eat the bushings. Sooner or later they need replaced because when the start wearing they actually start getting smaller and cause more slop and even lube won't help and you will start wearing out suspension components.
if this was helpful a vote with the thumbs up for the free advice would be greatly appreciated. Thanks for using fix Ya
Apr 24, 2011 | BMW 525 Cars & Trucks
What would stop a bush a126q washing machine draining, it just stops in the middle of a wash cycle?
hi i have a BUSH A126Q model W/M .Spin and Drain dosnt work. I clean the FILTER but same problem. Error code is Err 03. The start light & program ready light is blinking when M/C go to spin / Drain.
Its looks pump dont work //////
Please advise me what to do ???????????
Thanks
Mar 19, 2011 | Washing Machines
I have a bush dvd2039 and have put a dvd in and it won,t play and open and close won,t work either, have rebooted, unplugged and plugged back in and checked cables etc still nothing can you help please?
i take it your talking about a pc dvd burner if its not opening or closing i wouls say the cog/ruber band has broken you need to replace the driver (dvd burner)
Sep 21, 2010 | Bush DVD2038 DVD Player
We have 1997 mitsubishi verada and underneath the front of car where the bottom wish bones go through a rubber bush there is a clear fluid dripping out can u tell me if there are some bushers with silicon...
No silicon in the bushings chances are you have a coolant leak or some other liquid is leaking from the engine onto the bushing, look for the leak it should be directly above the bushing.
Dec 07, 2009 | 1987 Mitsubishi Passenger
Dishwashers Logo
110 people viewed this question
Top Dishwashers Experts
Owen Barnes
