Question about Neff K9724X4GB
Sels req fridge freezer
Seals require changing
Looking for a replacement seal measures 1040mm x 600mm
probably the best idea is to contact a local fridge/ freezer person that replaces seals on the doors of fridges and freezers (yellow pages for a start-fridge repairers)
they have an assortment of seal profiles on board and they make the seal to suit the door on site
The cost is about 75% of new price
ask the service agent spares for a seal, because although the freezer may be old , seals didn't change all that much and you may still get a seal from them
From the size I am guessing that it is a chest freezer probably an electrolux/email product and you may be lucky if it is
Mar 31, 2016 | Freezers
My freezer on top of the fridge makes a lot of ice on bottom of freezer floor,(under the plastic tray) and after defrosting it reoccurs a month or two later. which component needs changing?
this could be a faulty thermister. this tells the defrost cycle that ice has built up and needs to be melted. A ohm meter can test this component when the ice builds up the resistance of the thermister should change in value . Google how to test a thermister in a freezer.
Mar 28, 2016 | Refrigerators
My bottom freezer gets cold but the top part (fridge) does not. Why? I have an older first addition style
Its defrost problem.When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
May 19, 2011 | Amana ABB1927DE Bottom Freezer...
I have an Amana refrigerator, TR25VW. There is water, ice formed on the ceiling of the bottom part, not the freezer lately. Is it the sealing rubber issue?
freezers are frost free but not fridges.if the seals are bad(look along the edges with the door shut)ice will build up very quickly.adjust doors/rubbers as req.
wipe out regurlarly/syringe drain holes with clorine bleach/vaccuum vents,(most people complain of water under the veg tray,dont they see steam on bathroom mirrors.....same thing)
Jul 02, 2010 | Refrigerators
Water leaking from the bottom of the freezer door on a frigidaire side by side (water and ice in the door). any suggestions?
Check the connection to your water filter and check to see if the door seals completely when closed. To do this gently rub colord washing up liquid on the sels and close the door, then open it and look to see of the seal left a soapy mark on the frame of the fridge. it is often the case that the door can warp and this leads to the ice crystals and subsequent melt water around the area that is not sealing.
Jun 20, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
I found a water pool on the floor...
a coupltle thinges ,ur het plate to evaporate condensation it out, ur low on collant, or door sel is not sealing
May 30, 2010 | Magic Chef CTB2125 Top Freezer...
Freezer/Fridge not cold enough
check see if compressor on check control if on
Apr 05, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer door opens
its air pressure between the wo doors that cause it to open the freezer door.take some soapy water and clean the sels aroundboth doors to see itf thet dosent help use dish soap and a little water to clean the seals with it should stop it
Jan 07, 2009 | Frigidaire FRS3R5EMB Side by Side...
Neff K9724X4GB Logo
18 people viewed this question
Top Neff Refrigerators Experts
John Tripp
John Tripp
richie46
Rabbit Brains
Rabbit Brains
Are you a Neff Refrigerator Expert? Answer questions, earn points and help others
