Question about Samsung Televison & Video
Samsung LE26R74BD. Screen briefly comes on 1-2 seconds then goes blank. Took back off and all capacitors seem ok.
Any further ideas?
SOURCE: Samsung LTP326w
After few years of service with different TV providers I have problem with my TV. Last night my Samsung LTP326W just did the same think on HDMI connector and no mater what you do it will not turn HDMI video... it's connected to Verizon/Motorola DVR I called Verizon and they promptly replace DVR and HDMI cable but it didn't help at all, also sometimes when you power on/off I get message: The HD Content Protection of your display has been compromised Please use the YPBPR outputs for your HD connection...
When I switch to component cable it works just fine.
Posted on Apr 08, 2008
  • 109 Answers
SOURCE: X20G-Naga III screen goes blank after 1-2 secs
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
Posted on Jun 01, 2008
  • 6 Answers
SOURCE: screen only stays on for 2 seconds at a time
just an update...I have fitted a new cable (pc to monitor) and it has been on for 2hrs now so fingers crossed!
Posted on Sep 23, 2008
SOURCE: fujitsu/siemens scenicview e-19-1 model 900p
Please excuse me posting this as a 'solution', which I rather think demands one knows what was wrong in the first place! Anyhow, I have fixed my problem with this monitor. As previously mentioned cutting JP13 didn't restore the blank display. BTW: JP13 is on the component side of the first power supply printed circuit board (PCB), its under the steel plate in the back of the monitor case, remove both plate and board mounting screws to get at it. But responding to someones previous suggestion, I went about replacing all electrolytic capacitors (caps) on this board, did this rather than just replace C10/C11 as its a bit of a fiddle to open/reclose the monitor case and I'd already done it twice by this stage and wanted to limit possible damage to cables/connectors etc by repeated dismantling of case. ANYHOW! result is that monitor is fixed (so far!), had it on soak for a week and am using it right now, so hopefully it will stay that way. Its fairly easy job to do if you have some PCB soldering experience, you'll need a small iron and a 'solder remover/******' (when removing old caps). Recommend you look at www.badcaps.net/forum for info on the capacitor values you'll need. I used recommended good quality capacitors - Nichicon and Panasonic. If anyone is interested I'll post the list of values I used but its pretty easy to extract the old caps and get the values from them. Hope this is of help, regards Phil
Posted on Nov 01, 2008
sys_admin
  • 829 Answers
SOURCE: screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
Posted on May 10, 2009
Samsung 50" led un50h6350. The TV is about 18 months old and the picture went out, the audio and back light are working. I've replaced the t-con board and that didn't fix it. Someone please help!
Samsung LED TV Screed goes blank periodically for 1 sec - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - Lately, my Samsung LED TV's screen will black out from 1 -2 seconds then come back. The TV has been ... The TV is about 6 months old. .... I've only notice this when I'm watching in HD. ... by Stlouib / January 13, 2012 11:18 PM PST ...Mine does the same thing - picture goes black for 1 - 2 seconds and then comes back. Samsung Series 3 (330), won't show any picture/no sound?
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
More results from www.cnet.com
Are there still capacitor problems with Samsung TVs?
Dec 21, 2015 | Samsung Televison & Video
Samsung le40d503f7w only displays samsung logo on screen for a few seconds after switching on and then goes blank
have the same problem, one or more of the flourecent light bulbs in the back panel got broken, looking for a supplier who may keep these bulbs in stock, or other wise will see if i can get a used one off ebay for spares.
Jan 24, 2012 | Computers & Internet
Picture keeps blacking out. Sound is ok. Removed back and removed power supply board and tested capacitors. All capacitors seemed to be ok. Is if possible that all capacitors are ok and I still need to...
Seems as if you back light strips are malfunctioning or your power supply board is kaput. See:
http://www.partstore.com/Model/Samsung/Samsung/HPT5054.aspx
for an idea of the cost you may be facing
Nov 30, 2010 | Samsung HPT5054 50 in. HD-Ready Plasma...
Monitor goes blank, turn power off and back on, screen pops up for a few seconds and goes blank
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 02, 2010 | Samsung SyncMaster 731B 17" LCD Monitor
My SyncMaster 710N comes on for only a few seconds then the screen goes blank. if i turn it off ,then right back on, the log on display is there , but then it goes blank again after a couple of seconds , ...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
May 16, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
The monitor powers up and the analog icon blinks on and off and nothing else happens...no colors...when connected to computer.. the images show for a few seconds and goes blank...turn monitor off and on...
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 29, 2010 | Samsung SyncMaster 204BW LCD Monitor
When turn on, get a picture for a fraction of a second then blank
you need your power supply repaired. you have bad capacitors.
Jan 01, 2010 | Samsung 225BW Monitor
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
FIXED!
Device : Spectra X20WG-Naga
Problem : monitor comes on then flickers then goes off
solution: Replace Capacitor C101 (150uf, 35V) and Fets U101 and U102 (4511GM)
Comments: This is a common problem with this monitor.
Oct 02, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
May 31, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
Open Questions:
Televison & Video Logo
27 people viewed this question
Henry  Thomas
Henry Thomas
