Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
My laptop screen has turned pink and green and grainy
Hp g6000 notebook pc
my laptop screen has turned pink and green and grainy...happend before a few months ago but it seemed to fix itself
Hi sonny my laptop is a dell inspiron 14 r 4010 and its doing the same thing as well. How do i fix that?
Posted on Aug 02, 2012
2 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi hd 1080p
The DM is not completeing the boot sequence which is caused by the DM capacitors needing replacement heres a link to the repair kit for your model. The kit contains the replacement capacitors plus free instructions with pictures.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v23-dm-repair-kit/cName/repair-kits
Posted on Jun 13, 2009
Screen pink vertical lines
Probably the tft screen, this can be easily tested by plugging an external screen in. If they both give the same issue, you have a GPU issue.
Dec 14, 2013 | HEWLETT-PACKARD Hewlett Packard HP ProBook...
Pink screen
Is it Intel or AMD? Do you have the correct graphic card driver installed?
Go here, http://www8.hp.com/us/en/drivers.html locate your product and download the right driver..
Nov 14, 2013 | HEWLETT-PACKARD Compaq Presario CQ56-110US...
Green & pink dots screen
This is most likely hardware issues. Take in to replace or reconnect. gl
May 09, 2013 | HP Pavilion dv6000z Notebook
I have a hp g6000 power coes on but screen is
1. If you have it plugged to a power adapter it could be that the AC adapter is not charging the battery.
2. Try removing the battery with the AC adapter plug in and see if the PC will. if so then you may need a new battery.
3. You will need to get new AC adapter and battery frome the manufacturer or authorized dealer. Third party device are not recommended because they usually are not up to specifications.
I hope this helps.
Mar 16, 2010 | HP Pavilion dv6000z Notebook
Turned off after froze in use, now it won't start up again
Plug the power cable and press the power on button.
Mar 07, 2010 | HP Pavilion dv6000z Notebook
HP G6000 laptop wont start
Extract your battery from your laptop for 12 min, then start your computer using your power cable (don't use your battery), if not try pressing F2 rapidly when opening, after you open your operating system try changing your graphics card drivers.
Jan 31, 2010 | HP Pavilion dv6000z Notebook
Toshiba Satellite L35 screen color turned to pink.
If you have a LCD-screen, not an old-style CRT-screen, it is the data-cable, and its connections, that are not transmitting one of the 3 "primary" colours, e.g., mix red & blue & green to get white,
but mix only two of those colours, and you could get pink,
because the mixing is an "additive" process.
If you mix NONE of the 3 primary colours, you should get BLACK.
If you see GREEN, you're seeing ONE of the primary colours.
Sep 19, 2009 | Toshiba Satellite L35-S2366 Notebook
Pink screen
Pink and grainy almost certainly means CRT coolant leak on
signal PCBoard. Unplug set from AC, then take off lower front
cabinet. With good light, look for liquid spill on PCB.Touch it,
feels heavier than water,but not oily,clear color.Repair would be
expensive,requires replacing at least one CRT + clean PCB.
Most likely,the green tube is the leaker.........T.
Oct 23, 2007 | Sony KP-51HW40 51" Rear Projection...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
2,004 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
