Question about Garden Treasures 29.5-in Black Steel Wood-Burning Fire Pit SRFP153
Fire pit replacement screen - Garden Treasures 29.5-in Black Steel Wood-Burning Fire Pit SRFP153
I need a replacement lid for a 42 inch gas fire pit made by Wilson & Fisher
lid 42 inch gas fire pit.thats all I put in to ebay,and it did come up with some,but you would need to go and have a look to see what one you are after.
Nov 07, 2016 | Fisher Dishwashers
How do I keep my gas fire pit lit?
My guess is hold in the button for 30 seconds and the slowly release the button. The thermocouple has to first warm up before you release the knob. Remember wait and then release slowly. Just a guess.
Nov 28, 2014 | Woodard Outdoor Cast Aluminum 42 Square...
Can anyone recommend a bronze fire pit that isn't too expensive?
My friend and I picked this model up, and we love it!
http://www.hayneedle.com/product/rubbedbronzeoutdoorfirebowlfirepit1.cfm?srccode=cii_10043468&cpncode=33-134042763-2&source=channel_intelligence_shopzilla_hayneedle
Jan 24, 2013 | Garden
My pit bike 125cc wont fire up
Try unpluging the cutouts.they are usally on 2-3 places on these bikes ,brakes,also check the fuse that is on the red wire comming off the battery it will be blown or end of fuse holder will be pushed in and not touching the fuse.
Apr 13, 2010 | RTO Pit Bikes
Gas seems to be jumping around the gas fire pit
A gas appliance is not something that one should be self repairing without the proper knowledge and training.
If you think it has a problem with gas "jumping around the gas fire pit" it could indicate a leak somewhere that could build up and cause an explosion and fire with serious or fatal consequences.
I would turn off the gas supply and contact a qualified service person to have it checked out properly.
Oct 24, 2009 | Forest Natural Gas Fire Pit Black Marble...
I cant start a pull start mini pit bike. Its pull
Spray a small ammount of starting fluid into the aircleaner. It will fire much easier and should start if your ignition is ok.
Aug 28, 2009 | Pit Cycling
I have a pit bike 125 its not starting wot so ever got good spark but still not start
If you have spark them it must be gas. eather no gas or to much gas. Put it on chock, be sure the shut off valve is in on position.Now crank it over a few times , if it wont fire. Check the plug , is it wet or dry .If its wet then it may be flooded and needs to dry out and air out the cylinder.Try starting when dry. If its dry try putting a 1/2 oz of gas into the spark plug hole. replace the plug and turn it over . This will get them to fire up. Good luck DFD
Apr 22, 2009 | RTO Pit Bikes
Garden Treasures 29.5-in Black Steel Wood-Burning Fire Pit SRFP153 Logo
61 people viewed this question
Top Garden Treasures Home Experts
Donni Steen
Tom Chichester
Are you a Garden Treasures Home Expert? Answer questions, earn points and help others
