Question about Intel Motherboard
MotherBoard won't power on (Could be LED placement issue)
I have a MSI P45 Platinum and Everything seems to be connected properly but the motherboard or fans wont turn on, the motherpower power light is red but no LED lights are on, I think i may have connected them wrong and I don't know the correct way of putting them. Someone help me please, I'm using 650 Watt power supply so thats not the problem ^-^.
  • mike_p06 May 21, 2009
    I've tried all the possibile inputs and the Lights still fail to light up. Still no power up
  • Intel Master
  • 4,806 Answers
Hi there.
On the motherboard look for the front panel, it should be marked PWR and coloured green, also the plug that connects to it should be marked PWR_SW.
Have a look at these pictures for an idea >>>>>>
Good luck and thanks for using FixYa!!
Posted on May 21, 2009
MSI P45 NEO Board does nothing when power1 is pluged in shows only a few red lights when its unplug from power1 there's power but no display
go to www.youtube.com/how_to_setup_front_panel_connectors
you mite have to re range the wording to get the front panel light setup
you mite have to use motherboard type, various type of word and to the point but they will be able to help you resovle the issue
ps if the photo on the screen diplay is correct, the words mite be on the motherboard, it mite be abbrivated but just remember try the connector one way if it doesnt work than flip it 180 degrees, the board should also give you the side of positive [+] side, you put the color wire to the [+] side most of the time. the photo shows you the placement of connector and the connector are printed on the cable match the colors of the board to the connectors
Apr 17, 2015 | MSI Computers & Internet
Is it possible to use intel duel core E5400 processor with MSI B75MA-P45 Motherboard? or any other motherboard support DDR3?
Hello here is the cpu list, for the asus board:
http://www.asus.com/Motherboard/P5QLCM/#support_CPU
Here is the msi site:
http://www.msi.com/product/mb/B75MA-P45.html#/?div=Basic
Your current cpu will not fit on the msi board, because it is a different socket.
The asus board has socket LGA 775, and the msi board has socket 1155.
You have to buy a new cpu for the msi board, to make it work.
Here is the cpu list:
http://www.msi.com/product/mb/B75MA-P45.html#/?div=CPUSupport
If you want to keep the socket 775, you probably have to find a used mainboard, because this socket type is phased out.
Some online stores still have this mainboard type available, but a new mainboard will have the DDR3 ram socket.
Good luck
Feb 13, 2013 | EliteGroup 945GZT-M (V1.0) Motherboard
I have a K9n Platinum motherboard, the harddrive led and power led just blinks and when i push the power butten nothing happens, and after maybe one hour the blinking stops or it could take days. and when...
This issue sounds like a possible defective power supply. Possible PSupply fan failure or PSupply is under powered for all you're devices. Re-check all internal connections.
Use the link provided below to see if you're PS output is sufficient for all you're connected devices; http://extreme.outervision.com/psucalculatorlite.jsp
Cheers'
Mike
Feb 03, 2010 | MSI K9N Platinum Motherboard
MSI P45 Diamond motherboard not booting up
First check the power suply. If it is ok then check the processor.
Jul 19, 2009 | MSI P45 Diamond Intel P45 Core 2...
I have a msi p45 platinum motherboard my cpu fan speed keeps jumping back down to 0 back and fourth and sounds off alarm can someone Help Me PLEASE?
Check that the fans leads are not loose. It can only be that else if the leads are tight then u might have to change the processor fan & then see if its working properly,,,,,,sodeep
Jun 12, 2009 | Intel Motherboard
Power button hookup confusion
hey there
It easy to insert the connector of Reset, Power, And LED
Becuse everything is used to be properly written ur motherboard,
Checkout for the lower left corner of ur motherboard.(Behind the FDD Connector's right corner)
Hookup the connection by reading on down of the every PINs on your board.
Gimme
Aug 03, 2008 | MSI 651M-L Motherboard
MSI motherboard
First check thru visual if there are signs of burnt transistors and bulged capacitors. Check for open fuses and resitors, broken lines. And reheat the motherboard if necessary. Hope this gives you hint.
Best regards,
Rosener
Dec 14, 2007 | MSI P45 Diamond Intel P45 Core 2...
Intel Motherboard Logo
350 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
