Question about Linksys Wireless-G WRT54G Router
My son wants to do xbox live but cannot gain access to our wireless router. I have a vista pc connected to the router and 2 other computers in the house that connect fine. Help me please...son driving
How do I open or allow my sons xbox360 to join my wireless network on a lynksis?
    Scholar:
  • 58 Answers
Please open your router page and open the DMZ page give an IP address.
Then open X-box page and force the same ip address it will allow your x-box to communicate with the router.
Posted on May 21, 2009
Wireless not working
Run the network tests from within the 360 menus - looking especially at the result for network address translation (NAT). If this is either limited or fail, you will need to change your router for one which is compatible with xbox live. Try xbox.com to work out which routers are recommended.
As far as your router kicking him when you connected your pc, then you must have altered the access permissions of the router maybe by accident.
If all else fails, turn off the pc, router, modem and 360. Find the reset button on your router and press/hold this for at least five seconds. Turn on the modem, then the router. Let that settle for a minute, then connect and setup 360 and laptop.
Apr 10, 2009 | Pelican PL-2050 XBOX EDGE 2.4 GHZ WIRELESS...
Xbox live connection keeps crashing.
problems usually happen, when the signal strength drops.
I,d suggest hard-wiring the 360 to the PC or router, for optimal performance.
Thankyou for using fixya.
Mike @ compurepair.
Jan 05, 2009 | Microsoft Xbox 360 Console
My xbox live doesnt work
the reason for this part to fail differs along with the difference of the type of connection you are using to connect your Xbox 360 console as follows:
a. Direct connection to modem:
1. Make sure first no other devices connected to the modem at the same time as some modems has an Ethernet port along with a USB port so, you might think you can use both at the same time & connect the PC through USB with the console through Ethernet & that's incorrect so, we need to disconnect the PC first.
2. Turn the modem off then turn it back on after couple of seconds (by turning the modem off I mean to unplug it from the wall outlet even if you have a power button for it), then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Restore to Factory Defaults" and when it ask you to Apply Settings select "Test Xbox Live". 3. If it's still not working we need to get the Physical Address of your PC to put it on the dashboard of your Xbox 360 console as some cable companies are preventing any unknown MAC Addresses from connecting, to get the Physical Address of you PC connect the PC only to the modem then follow these steps here, the physical address will look like this 00-E0-98-C1-88-C2.
4. Go on the dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Edit Settings” then “Additional Settings” tab then select “Advanced settings” & put the Physical Address of your PC without the dashes on the “Alternate MAC Address” part and select "Done", when it asks you to Apply Settings choose “Test Xbox Live”.
b. Wired connection to router:
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore To Factory Defaults", when it ask you to apply settings select "Test Xbox Live".
2. Turn the router off then turn it back on after couple of seconds, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
c. Wireless connection to router:
2. Go on the Dashboard of your Xbox 360 console to the "system" area then "Network Settings" then "Edit Settings" then select your wireless settings part down there "Wireless Mode, Network Name,..." the console will automatically then search for your wireless network and when it find it and you select it, it will ask you to enter your wireless key which is called WEP or WPA key - you can find it written on your wireless router or then you need to contact your ISP (Internet Service Provider) to get it from them - when it ask you to apply settings select "Test Xbox Live".
3. Just a kind of higher security that some router may use than the WEP & WPA key, you have also to accept the Xbox 360 connection to your wireless network on the router settings, you have to access to your router settings as mentioned before to check on the wireless security part whether your router apply a MAC filtering option, which is an option that blocks any unknown MAC address (the ID of any device) from accessing to your wireless network, and if it applies that kind of security you’ll find your Xbox 360 MAC address on the list there so, allow the Xbox 360 to get connected to the network, or even you can just turn off the MAC access control option instead of that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
4. If it's still not working, you can put the Xbox 360 console - as a trial - in a closer position to the router to see wither it's going to pick up an IP address or not.
5. If even after you turn off the MAC filtering option on your router settings your Xbox 360 can't still get connected to Xbox Live you need then to update your router firmware (The router software) and if you don't know how to do so then call your ISP (Internet Service Provider) to assist you with that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
d. ICS (Internet Connection Sharing):
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore to Factory Default" when it asks you to Apply Settings choose “Test Xbox Live”.
2. Allow the ICS option on the PC as mentioned before, then test Xbox Live.
3. If it's still not working, set the IP Settings manually to be:
IP Address: 192.168.0.2
Subnet Mask: 255.255.255.0
Gateway: 192.168.0.1
Then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
4. If it's still not working, you can get the IP address of your connection from the PC as mentioned before then set your IP manually on the Dashboard of your Xbox 360 console using this IP address, when it asks you to Apply Settings choose “Test Xbox Live”.
If you faced any other kind of troubles with this part failing even after you tried these steps please check me man
Jan 03, 2009 | Microsoft LIVE ONECARE 2.0 XP/Vista for PC
My wireless XBOX 360 says ''not connected'' when I test XBOX LIVE
hi,
in this case you need to do a port forwarding,which is something like opening the specific ports on router so that xbox will communicate with internet
for that we need to know the ip address of xbox and port numbers for xbox.contact microsoft for knowing the port numbers and their range,so we can do a port forwarding on your router
Dec 29, 2008 | Linksys WRT160N Wireless Router
Xbox 360 live on wireless router
In theory you should be able to "share" your internet connection. I use a Linksys WRT54GS wireless router and I have a Linksys Game adapter on my son's 360. He has not complained about lag or slow server times unless other intensive bandwidth is being used.
Nov 09, 2008 | Microsoft Xbox 360 Console
I am trying to set up xbox live for my son but when i try to go live on the xbox dashboard it says that wireless network not connected but i have a wireless network running in my house and need to know how...
  1. Connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
  2. Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
  3. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
  4. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
  5. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
  6. Save your settings and verify the network is functional.
    On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.
    On the Xbox 360, use the "Test Xbox Live Connection" option instead.
Tips:
  1. Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
What You Need:
  • Active Xbox Live subscription (to access services)
Source: About.com
Sep 29, 2008 | Computers & Internet
Xbox 360 to wireless laptop
Make sure ethernet cable from XBOX 360 is connected to one of the 4 access ports on the back of the router.
Mar 16, 2008 | Microsoft Xbox 360 Console
Xbox 360 wireless connection
If you already have wireless router you will need something like this:
http://www.xbox.com/en-US/hardware/x/xbox360wirelessnetadapter/
Or you can always buy a third party wireless device that is capable with Xbox 350.
Nov 16, 2007 | NetGear WGR614 Wireless Router
Linksys Wireless-G WRT54G Router Logo
122 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
