Question about Exercise & Fitness
Trojan cardio coach 460 - gives e7 error message
My tredmill trojan cardio coach 460 gives an error message e7
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: The treadmill gives a E7 error message and the belt is not moving.
this error has 2 options:
1) The display board see the diagram attached,adjust the reed switch , clean and tigh the wires connector.
2) The elevation motor problem a) adjust the potentiomenter b) lube the gear and shaft c) test the motor if need replace or repair.
try to run the software calibratin for diagnose, troubleshooting.
Posted on May 08, 2012
My sharp copier AR-5316, is showing error message E7. How do I clear it and solve the problem. Please I need urgent assistance.
For proper understanding of the error meainig it is necessary to obtain a Subcode of the error by pressing START at the moment of displaying error. E7-02 and E7-16 means Laser unit problems, E7-01 problem with memory, E7-10,11,12 Scanner problems
Jul 29, 2016 | Sharp Ar 5316
How do I clear the E 7 message on a Trojan cardio 450 treadmill?
If you wish to get some details; check the site http://electro-medical.blogspot.com/. Pull up older posts. Surf the site with patience.
Mar 05, 2016 | Exercise & Fitness
I have a insight treadmill DK 616 with error code 7 . What does the e.c. mean and how do I fix it.
hi i have a DK616 tredmill and i need i new drive motor can any one help
Sep 10, 2012 | Exercise & Fitness
Error Code E7
To fix the error you have to put the safety key in start it it and wait for it to say E7. Now press stop and incline( up) together and hold for 20 seconds. Your treadmill will start to incline up. Take out your safety key. You just restarted your treadmill and can now put the safety key back and your problem will be fixed.
Apr 22, 2012 | Exercise & Fitness
I have an Insight DK614 Tredmill that will not run. It displays an error message "E6" and the running deck will not lower. The motor is still running albeit at a much lower rate. No movement...
E6 or E7 An E6 or E7 error code is an incline error code. The E7 code means the potentiometer value the console is reading from the lift motor is out of range. This can happen when there is a bad wire harness connection or a damaged wire harness. It could also just mean the incline motor needs to be adjusted back into range. If all wire connections look ok, the incline motor will need to be adjusted.
  1. Turn the power OFF, wait for 5-seconds and turn back ON.
  2. Get into test mode and enter through the I/O testing step. This screen will display the potentiometer value of the incline motor. Different models will have different values. Check to see if the running deck is raised to high incline level or if it is at the low level. If the running deck is at a low position press the incline up button. This will cause the incline motor to raise the running deck up. When the deck gets to a mid-level position, press the incline up button a second time to stop the deck. If the running deck is in a high incline position, use the incline down button to adjust the deck to a mid-level position.
  3. Once the unit is in the mid-level position, power the treadmill off for 5-seconds and then power it back ON.
  4. Start the treadmill.
  5. Once the treadmill starts the running deck will move to the level 0 position. If this does not resolve the issue or it will not adjust please contact customer service.
Also, note that not all models will have the ability to adjust the incline motor. If the adjustment procedure is not found in the Owner's Manual then contact customer service. Treadmill Error Codes Troubleshooting
Oct 26, 2017 | Exercise & Fitness
Error E6
kindly download the below file... it explains ur error and how to rectify it
http://www.body-solid.co.uk/body-solidUK_download/pdf_docs/tr-20(1)E6+E7(XT-27_33_56_57_7600).PDF
thank you have a nice day
May 04, 2009 | Exercise & Fitness
Error message on elliptical machine
Try unplugging for 5 mins plug back in might reset .
Jan 23, 2018 | Kettler Mondeo Elliptical Trainer
Exercise & Fitness Logo
226 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
