Question about Santai TD-V26 Portable Mini Digital Speaker with Micro SD / TF / USB /FM - Golden
Cant tune in radio stations on td-v26, stays on P01
Why only 50 station can bee stored
Limited to the size of the memory within.
Jun 29, 2014 | Santai TD-V26 Portable Mini Digital...
Td v26 speaker is not bringing all of the radio stations
Hi Rishabh.
Something wrong with internal USB power supply unit.
if you can.please remoove the cover and inspect a diode close to the usb power circuit.
if you are comfertable to repair please let us know.
regards,
nuwan
Jan 10, 2014 | Santai TD-V26 Portable Mini Digital...
2008 ford edge - two radio stations stop working on my radio but others are fine. Not a radio station issue, could this be a battery or electrical issue?
does radio allow you to tune to stations number ?
if it does but it won't stay there for more than 30 seconds radio is telling you that station is not sending a strong enough signal out for radio to properly recieve it ,also ck roof antenna for damage automatic car washes kill these all the time
won't allow you to tune it there no way, then radio is in parental control mode obtain code and reinstate station permission read owners manual for this feature
Oct 29, 2013 | 2008 Ford Edge
Manual pdf com
free manual for santai td-v26
Jul 20, 2013 | Santai TD-V26 Portable Mini Digital...
How to load music on to my mini digital speaker td-v26
you must have a micro SD/TF card..... it comes with an adapter
Apr 05, 2013 | Santai TD-V26 Portable Mini Digital...
Santai TD-V26 user manual
The device has an on/off toggle switch and four control pushbutton switches (left ro right) are:
1. Menu (FM Radio or MP3 Player) select
2. Play/Hold
3. Back/Previous
4. Forward/Next
Inputs and output are:
1. 1/8" External Source Input Jack
2. Micro SD Slot
3. Mini USB 5v External Power Input
4. 1/8" Headset/Output Jack
5. USB Memory Card/USB Cable Input/ (Right Side)
The Menu switch has two functions, MP3 Player and FM Radio as indicated by the display. If the Play/Hold switch is pushed in and held for a few seconds the radio will automatically sweep and put the available local stations in memory. The back and forward switches are used to select the desired station. The display indicates station channel number and broadcast frequency (MHz).
In the MP3 Player function Menu function the Play/Hold Switch starts and stops the player. Back and Forward switches select the previous or next track. Simple as that. The player automatically plays the next file if left alone unless the Play/Hold switch is pressed. The display indicates file number and play time. No other functions, like folder selection, were found. If a 5v dc supply is connected to the Mini USB connector the battery will remain charged and it can be used as a small table radio/player. No tests were made to see how long it would operate on its internal battery.
The sound is good and better than expected for a device its size. Enough sound output to hear it in any part of an small house (With some distortion of course). The volume is controlled by holding the forward or back switches in for a couple of seconds and it will switch to volume level control. The display is LED rather than LCD and easier to view. It is on continuously when the player is working with the charger attached.
Aug 23, 2012 | Santai TD-V26 Portable Mini Digital...
How come i cant find the radio for my Phillips go gear vibe?
From the main menu, select the icon that looks like a little radio
To search for the next stronger signal, press and hold the up or down arrow
To fine tune the frequency, briefly press the up or down arrow
From the main menu, select to enter
radio mode.
• The earphones cable acts as FM
antenna.
Manually tune a radio station
While in mode, you can manually tune to a
radio station:
1 To search for the next stronger signal,
press and hold / .
2 To fine tune the frequency, briefly press
Auto-tune preset radio
station
The auto-tune feature of GoGear Vibe helps
you find radio stations and save them under the
preset numbers.
1 While in mode, select [Auto tune] >
[Yes].
»» The radio automatically tunes radio
stations and saves the frequencies to
presets.
»» There are 20 presets available.
»» To stop auto tuning, press .
»» To exit radio, press and hold for 2
seconds.
EN
Jan 09, 2011 | Philips GoGear ViBE Digital Media Player
Radio
Hello george_nutti,
The model number you posted is for a center channel speaker which has no controls, and not knowing the exact model number it's difficult to be specific.
Some Kenwood KDC models allow you to select one of 3 "tuning modes", 1) AUTO1 - Automatic search for stations; 2) AUTO2 - Search Preset stations; 3) MANUAL - Normal manual tuning control. If your Kenwood is one of these models, you need to set the tuning mode to MANUAL. For Kenwood Excelon HD receivers, direct access tuning is done by using the included remote. 1) Press DIRECT button on the remote; 2) Press number buttons to enter desired channel number; 3) Press DIRECT button again to exit direct tuning.
Hope this helps.
Sep 08, 2009 | Kenwood KSC-310CCS Center Channel Speaker...
I can't preset radio stations
this is how i preset my stations, im not sure if you have done this before.
fm can save 20 stations and am can save 12
1] chose your desired station
2] press & hold the play/memory button until P01 pops up and flashes
3] to save the station, press & hold the play/memory button
if you'd like to save another station, then repeat steps 1 & 2,
then press the play/memory button again until P02 pops up,
repeat step 3.
to listen to your preset station, all you have to do is press the play/memory button.
hope this helps
Mar 12, 2009 | Starlite Next Play Clock Radio with iPod...
How to manual tune the radio to a station and not use the scan
i have the exact same problem. i bought a fm transmitter, so i need to tune to a unused fm station in my region wich i cant do because the audi concert tunes up automatic and skips the unused stations ... HELP !
Nov 23, 2008 | 1997 Audi A4
Santai TD-V26 Portable Mini Digital Speaker with Micro SD / TF / USB /FM - Golden Logo
128 people viewed this question
Top Santai Computers & Internet Experts
David Payne
David Payne
Are you a Santai Computer and Internet Expert? Answer questions, earn points and help others
