Question about Indesit 24 in. DE73 Evolution Free-standing Dishwasher
Error code a05 - Indesit 24 in. DE73 Evolution Free-standing Dishwasher
Comfort zone infrared heater keeps flashing A05 what does this mean?
A05 code is over heat error, unit has to be cleaned thoroughly. take unit apart and clean, I use a rag,brush,vacuum and compressed air. .
press the helpful button and check links below on disassembles.
Comfortzone CZinfrared removing cabinet how to
Comfortzone CZinfrared panel removal How to
Comfortzone CZinfrared bulb replacement How to
Jan 30, 2016 | RTO Comfort Zone Electric Portable Space...
I need hepl to error A05-303 , Riso 230
A05-303 Master disposal error - clean master trash bin and check to see if sensor lever in master disposal path is pushed back
May 30, 2015 | Office Equipment & Supplies
I have a code A05. What does that mean?
Hold the two buttons on right with power on to reset.
Dec 19, 2012 | Comfort Zone CZ1500WC Infra-Red...
Hotpoint Aquarius error code a5 Problem
A05 - Pressure switch has not been reset
Check in the user guide the reset procedure (generally, just need disconnected of power few minutes).
Hope helps.
Jun 16, 2011 | Dishwashers
Led states A05 problem and machine stopped working
"Error A05 - Pressure switch has not been reset "
This is centered around the filter and drain area not working properly.
It is possible it just needs the filter cleaning and the hose flushing out, but also possible the pump needs to come out to clean it properly.
Drain it by putting the hose low down, and clean the filters of debris.
If this does not fix it, then remove the unit outside, lie on it's back and remove the pump to clean it.
Feb 09, 2010 | Indesit 24 in. DE73 Evolution...
A05 code
Indesit Error Messages and Error Codes Indesit Dishwashers
  • F10 - Fill or empty time out. Check that the hoses are not kinked, that the taps are on or whether the drain pump or hose is blocked.
  • F11 - Heater timed out. The heater has not reached the required level. Book a service engineer.
  • F20 - Temperature under range. Book a service engineer. .
  • F21 - Temperature over range. Book a service engineer.
Fault codes for Indesit LCD Dishwasher Models
  • A01 - Float switch operated - Book a service engineer.
  • A02 - Open/Short circuit heater relay - Book a service engineer.
  • A03 - Short circuit on thermistor - Book a service engineer.
  • A04 - Unable to reach or sense temperature within 70 minutes - Book service engineer.
  • A05 - Pressure switch has not been reset - Book a service engineer.
  • A07 - Open/Short circuit wash motor triac - Book a service engineer.
  • A08 - Open/Short circuit auxiliary wash motor triac - Book a service engineer.
  • A09 - Open/Short circuit with main wash traic - Book a service engineer.
  • A10 - Open/Short circuit fill valve traic - Book a service engineer.
  • A11 - Half load valve traic or alternating motor action - Book a service engineer.
  • A12 - Open circuit heater rely - Book a service engineer.
  • A13 - Open/Short circuit dispenser traic - Book a service engineer.
  • A14 - Drain hose too low causing syphoning. Check drain hose and re-adjust.
  • H20 - Check tap and pressure of incoming water.
_uacct = "UA-1207243-4";urchinTracker();
Sep 14, 2008 | Indesit 24 in. DE73 Evolution...
A05 code
ao5 is showing on the display of my indiset de73 dishwasher
Aug 19, 2008 | Indesit 24 in. DE73 Evolution...
Hotwpoint not working
  • Mar 07, 2008 | Dishwashers
    Indesit evolution de 73 dishwasher with an AO5 error code
    a05 is pressure switch not reset. check for blockages in the drain pump, filters and sump
    May 06, 2007 | Indesit 24 in. DE73 Evolution...
    Indesit 24 in. DE73 Evolution Free-standing Dishwasher Logo
    23 people viewed this question
    Top Indesit Dishwashers Experts
    Ken Johnston
    Ken Johnston
    Level 1 Expert
    Eric Taylor
    Level 1 Expert
    Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
