Question about Admiral AAV7000A
Wont heat up
The dryer goes allright but wont heat
    President:
  • 1,197 Answers
Unplug the dryer and the first thing to do is check for the presence of 220 volts at the wall outlet. If you lost one leg of the 220 volts, it is possible for your dryer to run but there will not be any heat. Once you verified there is definitely 220 volts at the wall outlet, remove the rear cover. On the lower right hand side you will see a silver canister which contains the heating element. Remove the lower two wires directly from the heating element and check this for continuity. If it is good, on the left hand side of the same canister they often install a thermal safety which may have tripped. Do the same test as with the heating element. Remove the wires and test the thermal safety for continuity. If this is good, move to the blower housing on the left side of the exhaust vent and look for a white piece of plastic which has two wires on it. Remove these two wires and check this item for continuity.
you can follow this link below to find out how to test for individual components to find out what part is faulty...
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
You can also order for any replacement part from the following Websites
www.PartSelect.com
www.SearspartsDirect.com
If you found my solution of any help ... please do not forget to rate the solution
Posted on Oct 09, 2010
Why wont whirlpool duet dryer model WED8300SW1 heat?
Is the dryer gas or electric? But you can also try cleaning the vent tube the pipe that goes outside also the pipe that goes into the dryer it's a good chance it's full of lint.
May 07, 2014 | Whirlpool Dryers
My dryer ia crosley and wont heat,the clothes wont dry,she activate but dont heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;'
Jul 22, 2011 | Dryers
Dryer wont trun off wont heat at all
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 05, 2011 | Dryers
The dryer wont dry. it wont heat up
heatman101
+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_
Jan 31, 2011 | Roper REX4634KQ Electric Dryer
Dryer wont heat up just spins keeps spinning with timer set. replaced heat element and still wont dry
heatman101
l;
Jan 03, 2011 | Roper RGX4634KQ Gas Dryer
Dryer takes longer to dry than before. appears to be heating allright .
this maybe cuased by restricted vents. clean vent and try again.
Oct 04, 2009 | Whirlpool LER4634J Electric Dryer
Wont heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
kllk
Aug 03, 2009 | Roper RGX4634KQ Gas Dryer
Wont turn on
Deppends where it arc too, short at the case
just pops a fuse . short in side could need
new output trans ,they are screwed
to the heat sink , check output trans , and
all fuses.
Jul 05, 2009 | Kenwood KAC-728S Car Audio Amplifier
Dryer will light and heat for a minute or so then goes out and wont relight again until it sits a while-
check your vent going out through the wall and be sure its not stopped up
Apr 23, 2009 | Dryers
Ge dryer wont stay running
start switch is bad,it is stuck inside,get the model number inside dryer door or on top panel,call local appliance parts store to get new part,only a few bucs,replace and you should be allright,let me know-mike
Jun 15, 2008 | GE DBSR453EBWW Electric Dryer
Admiral AAV7000A Logo
117 people viewed this question
Top Admiral Washing Machines Experts
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
