When I started the washing machine INDESIT WT82 EX, she began to receive water and then turns off idikator that the machine is turned on and begins to turn the program selector without interruption. How to solve the problem?
SOURCE: taking off the shutter on indesit wt82 washing machine
What do you call the shutter and then | can help you.macboatmaster
SOURCE: Hi,I've got a Indesit WT82
Hi
My Indesit WT82 It start fill with water ,,the water don't stop and the program buton run to the start position and stops .Any ideea what is wrong .???
Thanks in advance
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
