Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Hotpoint WMD740 Ultima --- I need to change the language and get the child lock to open machine please
SOURCE: error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Posted on Dec 15, 2008
SOURCE: how do you remove the child lock off the washing machine
Great Thanks for that
Posted on Apr 20, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Posted on Jan 10, 2010
barkencoa
  • 3463 Answers
SOURCE: hotpoint ultima washing machine showing fault code
Error code F05 indicates pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Make sure there is no water in drum before you start.
Please rate my solution.
Thankyou.
Posted on Jan 27, 2010
SOURCE: how do i change the language on my washing
Press and hold the drying,delay start/temp select buttons altogether for 5 sec untill you hear a beep, then release all 3. press the dely start button to scroll through the available languages then select your chosen language by pressing the drying button once.
Posted on Nov 07, 2010
My washer is French how do I change it back to English
1. Turn the power on at the wall socket.
2. Select ON/OFF at the console so that there is nothing showing in the display - ie: machine OFF.
3. Press & hold the 2nd, 3rd and 4th function buttons until the machine BEEPS (approx. 5 seconds). (centre 3 buttons below the display).
4. Select ON/OFF at the console to turn the machine ON so that the display is ON - it should now show language options scrolling through.
5. Wait until the language you want is shown or scroll through them manually using Spin Speed or Temperature then press Child Lock to select it.
Hope this helps
Mar 18, 2015 | Hotpoint Washing Machines
Wv 344 child lock need this turned off please
Press and hold the 'Child Lock' button for 2 seconds. You will then hear a beep and the child lock should be off..
Mar 03, 2014 | Hotpoint Ultima WF860 Front Load Washer
Hi,how can i reset the language on my wmd960 hotpoint ultima,thanks
1. Switch on the power and when the language is displayed - press the child lock+ temperature+ spin buttons simultaneously for about 5 seconds. Release the child lock button when other languages appear. Scroll down using temperature button-until English is dispalyed. Select using child lock button.
Jan 14, 2011 | Hotpoint Ultima WF860 Front Load Washer
Door lock symbol showing on screen and door will
Assuming child lock is not on...Water not fully going away/ blockage @ filter.
Nov 02, 2009 | Hotpoint Ultima WDM73 Front Load Washer /...
Hotpoint WF865 Child Lock Button Stuck 'On'
you should be able to turn it off by holding it in for a while longer,5-10 seconds, unless the circuit board is at fault.
Jan 07, 2009 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint ultima 840
hold child lock button down for 2 seconds you will then hear a beep done.
Jun 10, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima baby icon flashes/beeps
the icon means that the child lock is on.
if you switch on the power to the appliance and hold down the child lock button untill the icon disapears the you will be able to select a program.
Apr 15, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
12 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
