Question about Zanussi Washing Machines
My Zanussi ZWF1231W drum wont turn. I recently emptied and cleaned the drain filter. The machine fills with water and drains okay but no turn or spin during cycle.
5 Suggested Answers
  • 101 Answers
SOURCE: zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Posted on Apr 23, 2008
SOURCE: Whirlpool Model LSV6234AWO
door switch bad?
Posted on Oct 18, 2008
  • 135 Answers
SOURCE: Wont drain, wont empty, wont go onto rinse, drain or spin during
The filter on this machine is behind the flat at bottom right of machine. Tilt machine back before unscrewing to avoid spillage. If filter is clear get back to me and will explore other possibilities.
Posted on Nov 16, 2008
SOURCE: My Zanussi F1245W Wont Drain or Spin
what you do mate is make sure off,take out the drain pipe from the back.,lay down drain pipe flat to the floor as possible..i use a paint roller tray to drain in to..have a bucke t near by 2 put excess water in..hold up drain pipe whilse doing so,repeat untill drained as much as..then lock will release..set program back 2 spin if working.should work for you!
Posted on Nov 17, 2012
Zanussi fle 1416w wont fully drain the water out and final spin leaves clothes quite wet. When i turn the drum manually i can hear the water below the drum sloshing about. What's wrong with it?
Hi.
Check for drain blockage, check position of the drain hose and check the pressure switch.
1) Access the drain filter and look for drain blockage. With Zanussi front loaders this located in front at the bottom right hand corner, there is an access door in there.Open the door, unscrew the cap and use a container to collect the water. Disconnect power before starting maintenance.
2) Check the position of the drain hose. Make sure that the height of the hose elbow is as specified in the manual or you get siphoning (water getting back from drain hose inside the tub) and drain does not end.
3)The machine has a pressure switch. It is a sensor connected to a long thin rubber hose. The pressure switch is located in control assembly. Clean pressure hose and switch. One way to test the pressure switch is by blowing into the switch, but manufacturers say this must not be done as you can damage a good switch.
The pressure switch is difficult to test in full. Testing is done either reading voltages while machine is cycling or reading Ohms at the switch with tub empty and full. For safety reasons I suggest users to avoid performing tests or maintenance that must be done with power on.
Here a page about drain/spin problem.
Start checking drain hose and drain filter.
Regards.
Ginko
Aug 18, 2011 | Zanussi FLE1416W Front Load Washer
Fills with water, drains, will not spin. sometimes will not fill
This is almost certainly the filter to the empty pump blocked. When you power up the machine, the first thing it does is make sure there is no water left over in the tub, if it can't evacuate any water it finds there, it won't go any further. Same on a spin, if after a set time the water hasn't emptied the empty cycle will stop but the spine cycle wont start because there is still water in the drum.
Locate and clean your empty pump filter.
Jun 29, 2011 | GE Washing Machines
ZWF1630W
I trust that the drum can be turned by hand.It seems like the filter is blocked you will have to drain the water and remove the filter check that it is clean and the pump is free,with filter out put to spin or drain and see that the pump blade is spinning if not then something is jammed in pump try to free and then replace filter and check for leaks.Check also drain hose not kinked or drain blocked.Hope this helps.
Apr 28, 2010 | Zanussi ZWF1630 Front Load Washer
Washer won't spin and drain
Sounds like your drain poump is failing. It's spinning lighter loads but not able to take a full load. I woule definately replace the drain pump,
Feb 28, 2009 | Frigidaire Washing Machines
Nov 16, 2008 | Washing Machines
Zanussi washing machine wont spin
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Filter can be clogged, pump can be dead or water outlet clogged.
Apr 11, 2008 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
