Question about Panasonic DMR-HS2 DVD Recorder
Problem about turning on
I hope that you could help me about my problem with dmr-hs2 dvd recorder.
When i try to turn it on, white screen appears to my tv set, and  a display of device indicates play function. HD starts to turning (i hear it).
Device don't react on any command including "OPEN/CLOSE"
After 15 seconds device displays command  "BYE"  and  turns off.
HD was checked on PC and it's working but partition is unlocated. I think it's proper.
What is the type of partition on HD and should i format it?
Please answer to me and give me solution of problem.
Thankfully,
Alexander
spasojevicaco@gmail.com
Hi, seems that the ribbon cable, which connects HDD & DVD & video-processing card isn't properly fixed to the stripe contactors. If one of both drives isn't connected, ( even on some contacts only) the other doesn't work, resulting in the described fault. The unit won't boot up.
Had this fault atime ago and had to push the ribbons a little harder into the connector and glued it.
Works since then about a year or so.
By the way, I have a 80 Gb replace-HDD, different brand, as the original one failed. NO problems at all, just louder than before, as it isn't the superquiet Maxtor.
If you try to read the unmounted HDD in a PC, the filesystem is changed or disturbed, resulting in the need to FORMAT, when putting it back into the Pana. Done this just by curiosity, all videos gone then. Even with a HDD, that works properly in the Pana.
Alka
Posted on May 15, 2008
Hallo, I'm new here, I hope someone can help me with my problem. I have a Panasonic DMR-HS2 DVD recorder, and I've had no problems yet, till recently. I had programmed several TV programs. W
It might well have crashed!
I suggest you unplug or turn off the power to the unit and leave it off for a while to see if it corrects itself when you power up again.
Keep a look out for any codes in the display when it powers up. Was there a disc in the drive when you shut it down? That might be contributing to the problem if there is.
If the hard drive has failed it still might be possible to remove it and recover the contents, before fitting a new one. There are the same ones you buy for home PC's afterall.
Mar 08, 2017 | Panasonic DMR-HS2 DVD Recorder
Won't recognise DVD Ram and non-finalised discs from own recordings.
Usually, the U11 error code in a Panasonic DVD player indicates an optical problem. You could of course try doing a cleaning using a CD cleaner normally readily from computer parts stores. Alternately, you can open the unit up and do a manual cleaning with soft bristle brush and/or cotton buds. Other than that, it could be indicative of a weakening laser eye which of course would require parts replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you
need additional information.
Good luck and kind regards.
Thank you for using FixYa..
May 24, 2008 | Panasonic DMR-HS2 DVD Recorder
I want to reset the reorder but i don't know how.
If you do not have your original instruction manual, you can download a free pdf from:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-HS2
(right-click and save link/target as... - it is a 3.2MB file (total size))
It may or may not help. Either way it's free.
Apr 25, 2011 | Panasonic DMR-HS2 DVD Recorder
Panasonic DMR-HS2 RF out is not outputting signal CH3 CH4 off
The most likely cause of this is the unit being in progressive scan mode. In progressive mode, the composite output is disabled. If you can, connect the DVD using the component output connections. If your TV does not have component input, connect the green connector to the yellow on the TV. If the unit is in porgressive scan, you will see a garbled picture on the screen. The only way to fix this is to turn off progressive scan. The manual will tell you how to do this.
Dan
Apr 10, 2009 | Sony STR-DG510 Receiver
Dvd player split screen
I had the same problem. It turned out to be my cable that went from the dvd player to the TV. I replaced with new cable & everything worked fine again. Hope this helps & please remember to rate my answer. Thanks.
Feb 06, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Remote control doesnt work
Go to the manu and try new remote code, Hopefully by changing remote code, from Codeset 2, to code set 1
will solve your problem.
Jan 17, 2009 | Panasonic DMR-HS2 DVD Recorder
My panasonic dvd recorder dmr-hs2 keeps switching to standby mode
I have the same problem, but it takes a while longer...just get the circle rotating in the LCD on DVD!
tried unplugging HDD...still does it.
Jan 13, 2009 | Panasonic DMR-HS2 DVD Recorder
Overseas dvd playing in black & white instead of colour
Hi
Your DVD is in Pal mode change the system settings Thanks@!
Nov 27, 2008 | Panasonic DMR-EH57 HDD Recorder Player
Locked DVD Tray
I'm pretty sure the force disk eject is the same across all Panasonic models - however I couldn't find anything specific for your model number. Still worth a shot, though.
With the unit in standby, press and hold the 'Stop' and 'Ch up' buttons together. It should power up and force the tray open. If this doesn't work, try changing up your timing by pressing and holding 'Stop' first, then a half-second later, press and hold 'Ch up' and keep them both held together. You can also try the opposite.
If none of these work, it will have to be taken apart to get the disc out. If you aren't comfortable trying, it will have to go to service.
Mar 09, 2008 | Panasonic DMR-HS2 DVD Recorder
Panasonic DMR-HS2 DVD Recorder Logo
301 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
