Question about Dryers
Kelvinator ktd600w wiring diagram
Heating coil doesn't heat but it gets power and it test 29.8 ohm.
docjohn174
  • 943 Answers
SOURCE: Whirlpool LER5636EZ3 dryer won't heat
hi If it reads 0 hms yes thats te problem Thanks the appliance doc
Posted on Sep 12, 2008
TheMobilian
  • 8220 Answers
SOURCE: the wires on my heating
the 2 wires that go to the element are largest. Does not matter which one goes where. The other 2 wires are smaller and imposible to get on the wrong terminal.
Posted on Dec 31, 2008
TheMobilian
  • 8220 Answers
SOURCE: Kenmore Dryer Model 110
If all of the components are reading ok then you need a timer. Touch your 2 leads together. 0 ohms rght. That means you have a complete circuit.If you get the 0 reading then the element must be otay. Bad timer. Take that fancy meater of yours and atttach one of them leads to the timer leg marked RH. Yank the wire off the terminal beore you test. Move the timer around. You should get the famous 0 reading along the way. If you don't then that means you have the bad timer.
Posted on Feb 05, 2009
jumptrout51
  • 3361 Answers
SOURCE: Dryer gets warm at first but then cools down
Check the hi limit thermostat and the cycle thermostat. They may be opening too soon.
Remove the connecting vent on the rear of the dryer exhaust and see if it cycles normally.
The flame sensor may be malfunctioning.
If the gas valve coils are good, these are the only other possibilities.
Posted on Mar 28, 2009
  • 207 Answers
SOURCE: blower doesn't blow and no heat
With these GE Harmony Profiles, the blower is the problem in same situations about 95% of the time.
First use the dryers service mode and see what trouble code you are receiving.
It's called "Field Service Mode"
1. Press the POWER key to turn the dryer on.
2. Press HELP. The main help screen is displayed.
3. Press and hold MY CYCLES and BACK simultaneously for 3 seconds. Press EXIT to return to the HOME screen.
There's a 95% chance that it is your blower and your dryer should confirm that.
I just recently replaced the blower in my GE Profile Harmony as well. While I had my dryer apart, I also cleaned the heck out of it. Excellent opportunity to take your vaccum cleaner and get all of those dust bunnies out!
I purchased the blower from www.applicancepartpros.com for about $146 S&H included.
Part No. AP3791484 Item: Motor asm-blower Price $133.05 Plus Shipping.
Posted on Apr 16, 2009
How do I tell if the heating element is burnt out?
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
This is a FREE answer, Please rate me
Sep 26, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do i get to the heating element of my dryer
Sep 25, 2010 | Speed Queen AES28AWF Electric Dryer
My dryer is not heating
For this FREE answer, Please rate me
Sep 22, 2010 | Whirlpool WED8500S Electric Dryer
My dryer runs but isn't heating up
Please rate me
Sep 18, 2010 | Amana DLE330RAW Electric Dryer
My dryers not heating up
Please rate me
Sep 18, 2010 | Whirlpool Dryers
My dryer is not heating but everything else seems to be operating normally. Is it the heating element
Please rate me
Sep 10, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Not heating up
Please rate me
Sep 10, 2010 | Kenmore 63942 Dryer
Not heating up
Please rate me
Sep 10, 2010 | Kenmore 2666814 Dryer
My roper dryer is not heating only blosing cool air rex 3614pwd
Please rate me
Sep 10, 2010 | Roper Dryers
The dryer is running fine but is not heating at all. does the heating element need replacing
Please rate me
Sep 10, 2010 | Frigidaire FER641FS Electric Dryer
Dryers Logo
Top Dryers Experts
