Question about Precor 956i Experience Series Treadmill (Used)
How do i replace the red stop button on the 956 I
I have a Model 2000 Chamberlain 1/3HP garage door opener manufactured 02/91 with a round yellow "learn" button, lost remote. Bought a replacement chamberlain remote, Model 956 which is supposed...
If the learn button is 'amber' the model 956 remote should work with it. Try this method for programming just in case your aren't.
Hold the button down on the remote while your press and immediately release the learn button. Main light should flash.
There is always the possibility that the receiver has quit working.
Nov 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
On my Precor 956 i the Stop Key prompt appears
There is a micro switch under the red "Stop" button. The switch is stuck and needs to be replaced.
Oct 24, 2010 | Precor 956i Experience Series Treadmill...
Printer lexmark C510," 956 service TCSD system board"
With that " 956 service TCSD system board" error message, the only you can do is to replace the Rip/System Board. Hope I can assist you more on this.
Apr 06, 2010 | Lexmark C510 Laser Printer
Hi, my sega game gear has a very dim screen, what can I do?
A weakness of all Sega manufactured Game Gears is a particular type of electronic component used in various parts of the internal circuitry; the SMD (surface mount) electrolytic capacitor. Many years ago these components were a common cause of camcorder faults. Now, as Game Gears getting to be 15+ years old, they are suffering from the "bad cap's" phenomenon too.
The symptoms of faulty capacitors include:
  • LCD Screen only looks good when viewed at an unnatural angle (anything other than 90 degrees).
  • Bright parts of the picture create 'ghost lines' in the dark parts.
  • Screen looks washed out, dim, and lacking in contrast.
  • Turns itself off (in extreme cases).
  • Problems are alleviated when unit has warmed up a bit.
Further confirmation can be had by opening the unit and examining the board area around the capacitors. Faulty capacitors will often (but not always) leak their corrosive electrolyte onto the surrounding board. This is a clear, oily substance which can may attack the cap's legs and surrounding components, leaving a green corrosion behind.
If one is faulty, the rest won't be far behind. Replaced them all at once!
These capacitors are glued and soldered to the board. To remove one, carefully rock it from side to side with a small pair of pliers until to feel the glue break, then desolder each leg from the PCB. When they're off, take the opportunity to clean up any leaked electrolyte and corrosion. Metho (rubbing alcohol to the Yanks) is good for this.
There are two versions of the Game Gear, the main difference being the main board layout. The later model also combined it's two ASICs (custom chips) into a single IC. There are other board layouts out there, if you have a Game Gear whose capacitor collection doesn't match the table send me a list and I'll update the page. Here is a list of all electro capacitors on the main board.
Mainboard
ONE ASIC GG TWO ASIC GG VALUE C68
C43
C45
C55
C54
C48
C49
C1
C4
C14
C48
C11
C31
C49
C35
C45
C44
C38
C39
C1
C3
C14
C48
- 100μ 6.3V
22μ 6.3V
4.7μ 35V
0.47μ 50V
0.47μ 50V
68μ 6.3V
100μ 4V
33μ 6.3V
10μ 6.3V
10μ 6.3V
10μ 6.3V
10μ 6.3V
Audio Amplifier Board
DESIGNATOR VALUE C1
C2
C3
C5
C7 100μ 6.3V
100μ 6.3V
100μ 6.3V
47μ 4V
47μ 4V
Some things to consider when shopping for replacement capacitors:
  • Replacements should have the same capacitance (in μF - micro farad) and the same or higher voltage rating.
  • Standard RB/Radial (both legs poke out from the bottom) electrolytic capacitors are fine.
  • Sub-miniature types are even better.
  • If you cannot find the correct value then connect two small caps in parallel. Tolerance is typically +/- 20% so no need to be too precise. E.g. 47μ // 22μ in place of a 68μ value.
If you find the sound from the internal speaker to be missing or distorted then a faulty C7 (47μ) on the audio board is the likely cause. If there also distorted audio on from the headphone jack then you many need to replace all capacitors on the audio board.
Capacitors on the power supply board are generally reliable, not being of the surface mount type.
Jan 10, 2010 | Sega Game Gear Console
Tv turns on then off
hold the menu and input buttons simultaneously for 5 seconds. the tv will blink an error code
Error Code Probable Cause
12 Normal Operation - No Error Detected
21 X-Ray Protect
22 Short Protect - likely convergence IC failure
23 Loss of Horizontal Deflection
24 Loss of Vertical Deflection
Fast Blink for 70 sec. After AC is applied = Normal - DM μPC is booting up
Fast Blink (doesn't stop) After AC is applied = TV μPC is running, but DM failed to boot up
Slow Blink Set is Off = Normal - Timer is set for Automatic Turn ON
Dec 05, 2008 | Mitsubishi WS-55511 55" Rear Projection...
I have a Toyota Landcruiser Prado SX 3.0 1994 Turbo Diesel, Engine No 1 KZ-0065839. The Electric Switches for the 4WD and Hub Lock light up when they are pushed on but the car does not go into 4WD. I...
το προβλημα ειναι ενα μικρο συρμα που κανει επαφη σε ενα απο τουσ δυο τροχουσ μπρωστα
Jul 17, 2008 | 2006 Toyota Land Cruiser
Blank Screen
Many have replaced caps on the SMPS board, with success:
2662 is a 1000μF 25v 85°C with 2663 and 2664 both 25v 100μF 25v
Another model: http://www.hotelkaveka.com/9944CU.jpg
Some other pics of different caps: http://i121.photobucket.com/albums/o229/garafrax/TV%20Repair/HPIM1458.jpg
Once you get it on, there are adjustments to the VS voltage to cure the speckle.
Jul 12, 2008 | Philips 42PF9630A 42 in. Plasma Television
Red Blinking Light/No Picture
7 blinks? Many have replaced caps on the SMPS board, with success: 2662 is a 1000μF 25v 85°C with 2663 and 2664 both 25v 1 00μF 25v. Another model: http://www.hotelkaveka.com/9944CU.jpg
Jul 08, 2008 | Philips 42PF9630A 42 in. Plasma Television
Mkjhjgjuhbvggggjbhnbfgdgdgfhbvyfy
Hmm..Its all Greek to me.
παρακαλώ να είστε πιό συγκεκριμένος. τι μπορούμε ακριβώς να σας βοηθήσουμε με; εάν ήταν ακριβώς ένα αστείο, παρακαλώ κλείστε αυτό το νήμα με την ανάθεση μου μιας εκτίμησης fixya.
ευθυμίες!
IrishDruid
Apr 29, 2008 | Computers & Internet
Precor 956i Experience Series Treadmill (Used) Logo
20 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
