Question about LG Washing Machines
Lg washing machine wth6506 sensor problem - LG Washing Machines
Hi i have a lg washing machine wft8061dd,can u please tell me why PE appear when it turn on
Water level sensor fault This fault code is fairly self-explanatory and tells you that the washing machine has detected an error with the pressure sensor or pressure switch. It is rare to see this error code on LG washers.
On non-display panel models this fault code can be shown by the lights for fuzzy, heating and speedy or super, normal and hold being lit or flashing.
  • Check water level sensor
  • Check wiring to water pressure sensor
  • Check connections to water level sensor
  • Check main electronic controller
Jun 13, 2016 | LG Washing Machines
Lg front load wm conversation moto type le error pls
Hi Jilu, The link below is a list of error codes for your washing machine..... CHEERS..
LG Washing Machine Error Code = LE
LG Washer Error = Drive Motor Locked Error
CHECK / REPAIR / FIX = Check the wire harness connections on the motor and the hall sensor (tachometer). Repair any wiring issues. If the wiring connections check good then check for damaged motor components. Replace if needed. If motor is good the replace the hall sensor.
LG Washing Machine Error Codes Washer Fault Codes
Apr 03, 2016 | LG Washing Machines
Where is the door sensor of a LG 8.2kg fuzzy logic washing machine
Most of the LG door sensors are fitted into the door lock mechanism.
Dec 20, 2015 | LG Washing Machines
I have lg wf-f7061dn washing machine when start the machine it starts for 5 to10second and then stops and then the inlet water magnet coil starts even I have change the watersensor.
Check if the air hole to the sensor is clogged, if you have replaced the sensor with the correct one and there is no sensor fault.
Mar 29, 2015 | LG Washing Machines
LG washing Machine
Yes , you can use the full assembly from the old machine provided it is of the same make and model.
Removing and fixing without damaging must be the priority,
Jan 25, 2013 | LG Washing Machines
LG washing machine loud and error code LE
Here is a tip that explains what the LE error code means.....
LG Washing Machine LE Error Code or Fault Code
heatman101
Jul 02, 2011 | LG WM2301HW Front Load Washer
LG WD-14401TB SE error code
the motor position sensor or the hall sensor part number is
6501KW2002A
May 05, 2017 | LG Washing Machines
Error code se
can you check the temperature sensor , i know thats not the same fault , the fault to the sensor is be but check the sensor , at the bottom of the tub between the heather connections
Jun 18, 2009 | LG WM-2277HW Front Load Washer
LE on LG washing machine
More than likely, the motor sensor has failed and needs to be replaced.  You will need to purchase the motor sensor from LG.
To replace the motor sensor, remove the 4 screws in the back panel to gain access to the motor.  Using a 17mm socket, remove the center bolt holding the rotor.  Remove the rotor.  Using a 10mm socket, remove the 6 bolts holding the stator assembly.  Holding onto the stator, allow the stator to come down and you will see the sensor located on the bottom of the stator.  Replace it and you should be good to go.
If this is too complicated, call a qualified LG technician.
Jul 12, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
71 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
