Question about LG LS-K2430HL Heat Cool Mini Split Air Conditioner
We have 2.0 HP inverter wall mounted LG aircon, when we turn on the ac, the indoor unit only is running and shut down after 3 mins. What is the solution?
bobotfel
  • 236 Answers
SOURCE: LG LST243C-2
- Check your air filter at the indoor if clean.
- Check your evaporator fins if clean.
- Check if no icing in your evaporator and outdoor pipes.
- If your air filter and evaporator fins is clean and icing is present then your unit is under charge.
- When your indoor drips check your drain pipe if there are water comes out. If no water drain from your drain pipes then your drainage is restricted.
- Flush your drainage with water using your garden hose to flush out dirts from your drainage.
Posted on Jan 14, 2008
crouchdash
  • 83 Answers
SOURCE: LG 18000 ac leaks water in the front of unit.
the drain pan is either clogged or the unit is not mounted properly. If the drain pan is clogged simply clean it and the problem goes away. In the case of the unit mounting, check the angle of the unit and the drain pan inside, if it tilted to the front even just a little then water would leak. the drain pan should lean toward the drain and away from the front.
I hope this helps.
Posted on Jun 05, 2009
  • 81 Answers
SOURCE: Noisy indoor air conditioning units
Ok. So first things first. LG have a reputation with all their products. THEY ARE ALL BAD! If you remember GoldStar, they are now LG. GoldStar had horrible products. Now this is what LG has. The fact that the filters are cleaned and the units are serviced is an abosulte plus and will provide the units with extra longevity. Now are these drains are they used for water drainage. If so the upstairs units shouldn't need them unless there is some sort of rise in the drain pipe.
Now to the noise. It seems like there is something which is causing the fan to make a noise. It could be loose bearing or a piece of the fan which has broken away causing it to hit the inside of the unit. Since it is on both units, it would be a generic problem with this series and unfortunately is what you are stuck with now.
To combat this problem, I would: ring LG and the company who installed them and demand that they be repaired and have a warranty on the repairs. Just a heads up, LG are really bad to contact should you have a complaint, so keep persisting that they be repaired free of charge since that they are still under warranty.
If you are not happy with LG or your installers response, I would remove the units and have another brand put in. I recommend Mitsubishi Heavy Industries and Panasonic. Both units are whisper quiet. In fact they are quieter that the LG.
Oh and that only reason why LG boast about their "whisper quiet-ness" is because that is probably the only good going for them - and thats' not even right!
I hope that I have helped you in some way. Good Luck!
Mat
Posted on Jul 16, 2009
  • 81 Answers
SOURCE: LG split AC keeps displaying CO and wont't turn off with remote.
The "CO" indicates cleaning operation and can be switched of via remote button under flap, labelled AUTO CLEAN.
Mat
Posted on Jul 20, 2009
  • 9 Answers
SOURCE: problem with compressor
Normaly on this units the problem is the PC boards if i'm not mistaken they have censors this censors give problems sending the unit to a Protection mode when the units works too hard sounds like thats your problem room 2 big and the High preasure presostat it's telling the unit to stop.
Posted on Jun 03, 2010
Hi Marie, does the green indicator light on the front panel flash after it shuts down? If it does...count how many times it flashes this will refer to a fault code diagnostic.
Keith.
Jan 02, 2014 | LG LS-K2430HL Heat Cool Mini Split Air...
LG ac remote is not working, batteries have been replaced
Probably the fuse to the indoor unit must replace it. It's on the pcboard and it's from glass. Turn of the power and replace it.
Dec 31, 2013 | Heating & Cooling
When I turn the heat on my wall unit the air door closes and the cooling light flashes 7 times. Will cool but will not heat.
Pls check indoor to out door 6 wirings. May be interchanged by mistake.
Example- Black wire in N with indoor but connected in C with out door.
And also check whether the sensor wire from indoor to out door has connected.
Tnx
Nov 15, 2013 | LG LMU187HV LMN096HVT LMN096HVT 21 SEER...
Aircon runs for a few minutes then shuts down and timer light flashes
when we start the AC indoor working and out door unit compressor working but fan motor not working and indoor timer light blinking
Dec 16, 2010 | Mitsubishi MSZ-A24NA Split System Air...
Problem with compressor
May 27, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Apr 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
My aircon unit turns on runs for a minute then indoor and outdoor unit switch off
If this is a LG Airconditioning unit.
It has reached the set parmeter of the safety switch point.
1 The unit could be running on too low refrigerant charge and cuts out on low temperature on the indoor unit coil (-5°C longer that 30sec switch off)
2 The unit might be drawing to much current, to much refrigerant, cutting out on high pressure.
Check the refrigerant charge and check the indoor pipe temperature thermister (calibrated at 5kΩ @ 25°C)
Mar 18, 2010 | LG Heating & Cooling
TOYO TA-09CHS aircon problem
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
Jun 09, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
LG LST243C-2
Jan 14, 2008 | LG LSC121PMA Split System Air Conditioner
LG LS-K2430HL Heat Cool Mini Split Air Conditioner Logo
15 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
