Question about Philips Televison & Video
General problem with Philip's DVP 3020
Hi. If plugged in (and DVD in the machine), the DVD player will start to load spontaeously without being turned on. But it also will turn itself off spontaneously while playing, which is really annoying. This usually happens after about 7 minutes, and happens with all DVDs.
    President:
  • 846 Answers
The problem isn't with your dvd's itself, it's your player. There is really no fix for it as its hard to determine the problem. Seems like a power fault, you may need to replace as having it repaired would not be worth the money or time.
Post back with any further info if you have any more questions. Thank you for trying Fixya!
Posted on May 21, 2009
I bought some DVDs at amazon.com, but I live outside the region code area witch the DVDs are supposed to work. I live in code area 4. I need someone to find a code to region 1. I have a Phillips home...
This player is relatively easy to change to region free. Please complete all of the steps below to unlock your DVD player.
Please note: Unlocking any DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
Unlock sequence for the Philips DVP 3020:
1. Switch on your TV and DVD player;
2. Make sure the TV is set to the correct input for the DVD player;
3. Remove any disc from the DVD player and close the disc tray;
4. Press the "SETUP" button on the DVD player remote control;
5. Use the LEFT/RIGHT arrow keys to highlight "PREFERENCE";
6. Enter 1 3 8 9 3 1 using the numerical keys on the Philips DVD remote control;
A pop-up menu will appear on the TV screen.
7. Use the UP/DOWN arrow key and choose "0" for all regions;
That's it. You should now be able to watch DVDs from all regions on your player. It is also a good idea to switch the player to standby and then switch it back on before trying any discs.
This is a verified unlock sequence for the Philips DVP 3020. If it doesn't work the first time, switch the power off and start again at step 1. If it still doesn't work, it is likely that you have updated your Firmware to a new version and this unlock sequence does not work with your firmware version
If you need further assistance, please reply to me from within this page and let me know which firmware version you have installed in your DVD player.
Regards,
BElectric.
Jan 28, 2011 | Philips Televison & Video
Unknown disk error on philips dvp 3020
I would guess that it's an incompatible disk format. If your burning software allows you to pick different types check the Philips manual for a compatible format
Mar 06, 2010 | Philips DVP3020 DVD Player
Where can i get a manual from & can this machine be reprogramed to take region 2 dvds thanks ****
Click Sony Support to download instruction manual of DVP-CX985V and region code can not be changed in this model.
May 31, 2009 | Sony DVP-CX985V Multi-disc DVD Player
Universal Remote code for the Philip DVD player
ring philips and tell them ur problem....look under customer help line...u will find in ur instruction booklet
Mar 07, 2009 | Televison & Video
Philips DVP 3020 Wrongly set to Component
Use the yellow composite plug to connect to your tv..this always gives out a signal..
Jay
Feb 02, 2009 | Philips DVP3020 DVD Player
Hi benimur
Appreciate the direct "Ask Me",.
There might be more than 1 version of this player depending on country of origin or intended marketing region hence the solution posted that you are referring to might not be applicable to your concern.
Offhand, I would suggest that you try a hard reset, that is unplug from the mains for an extended period of time (perhaps even overnight). The idea is to dissipate whatever residual power is inside the unit and hopefully thereafter, it will revert to factory defaults. Then try again. On the first power ON, wait till "NO DISC" is displayed, then try a known good disc. Alternately, you can also try, unplug, wait for a minute or so, press & hold the STOP button, plug the unit to the mains. You can also try that with the other buttons.
Should the above be not corrective, am afraid that the a firmware update/flash/reset is required by an authorized service center.
Hope that this be of initial help/idea. Pls post back how things turned up or should you n
Oct 12, 2008 | Televison & Video
Region codes
3020
Press "Setup"
Scroll to "Preference" using the LEFT/RIGHT arrow key
Press "138931" and a pop-up screen will appear.
Use the UP/DOWN arrow key to choose the desired number ("0" for any region)
Aug 26, 2008 | Philips DVP5140 DVD Player
Philips dvp 3020 dvd player will not play, the "no disc" sighn keeps coming on.
Try this. Wait for the "no disc" sign to appear, and only after that load the dvd. The 3020 I have works alright when I use this method.
Jul 29, 2008 | Philips DVP320 DVD Player
Region codes
Philips DVP 3015K / DVP 3020 / DVP 3040 / DVP 3040K / DVP 5140 / DVP 5960
  1. Method 1:
  2. Open the disc tray
  3. Press SETUP
  4. Navigate to the preferences page
  5. Enter 138931
  6. Select the region using UP/DOWN
  7. Press PLAY
  1. Method 2:
  2. Open tray
  3. Press 9, 9, 9, 9, 0
Dec 19, 2007 | Televison & Video
Televison & Video Logo
96 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
