Question about Sewing Machines
Bernina virtuosa 153
Could you please advise if it is possible to retro fit a BSR to a 153QE. My boards are currently in need of replacing and I was hoping it would be possible to upgrade at the same time?
RickE1
  • 202 Answers
SOURCE: Timing for Bernina Virtuosa 153
Timing these machines gets pretty involved such as in just removing the covers. You need a grounding ******** your wrist as the cables all need to be unplugged and you don't want to send a static charge from yourself to the circuit boards. They are expensive. Then you need special sized metal pins to pin several pinning points so the needle, hook, stepping motors and feed dogs all co-ordinate with each other. Also several places need certain guages to set less than .1 millimeter size distances between different places to avoid other problems. You also need several sized torx screwdrivers and the knowledge to adjust the upper and lower tensions. The upper tension alone has at least 3 or four places that need to be in the correct position.
All of the above has to be done in a certain order also.
Its complicated enough. If someone is going to walk you through this over the phone expect it to be complicated. Even if you had a copy of the manual (which could be a copywrite infringment on newer machines) you can expect it to be difficult.
My advice is to leave it to the professionals to have it done right.
Posted on Jun 20, 2008
RickE1
  • 202 Answers
SOURCE: Bernina Virtuosa 160
First the simple solution. Make sure your needle is inserted flat side to the back and all the way up.
The only other thing I can think of is that your hook is out of time and this will take a technician to re-time it. You may need to take it in for a servicing.
Posted on Jul 27, 2008
SOURCE: Bernina Virtuosa 153 QE Won't turn on
If you've got bad luck like I do, you probably blew out the circuit board! It took my Bernina dealer 4 months to get another from Sweden; thank goodness they gave me a loaner.
Unfortunately, it happened again right after I picked it up from the dealer, and they have to find another circuit board for it! It's not a problem with my electrical wiring because the loaner ran just fine.
It's very, very frustrating because I'm a small business and need my machine running!
Posted on Aug 17, 2009
SOURCE: Bernina Virtuosa 153 Quilter's Edition sewing machine jams
Bernina Virtuosa 150 pressure foot does not go down quite all the way. The stitches don't go straight and are not even. PrewettOE
Posted on Dec 13, 2009
  • 980 Answers
SOURCE: I need a new electronic board for a Bernina
Only from a Bernina agent or direct from Bernina.
Posted on Mar 10, 2010
Can a Bernina Virtuosa 153 still download stitches into its CPS system with Windows 10?
The Virtuoso was pre-Windows 10, so a Windows 10 system will probably have some issues. You might want to contact Bernina. They can tell you if your machine can be upgraded to Win10.
Jun 10, 2017 | Bernina Sewing Machines
Please supply a WORKING LINK for the Bernina Vertuosa 155 Owners manual PLEASE PLEASE
The manual is not available on Bernina's web site. So far, the only thing I've found is the Bernina Owner's Workbook (for several Berninas including the Virtuosa) that may be helpful:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=10&ved=0ahUKEwjGs4PZjKXRAhXlllQKHfR_BnAQFghSMAk&url=https%3A%2F%2Fsiterepository.s3.amazonaws.com%2F01182201109290548032081.pdf&usg=AFQjCNFjtpMlQlwF0PF3JJ0c6pcJSiGiyg&cad=rja
or
https://www.manualslib.com/manual/803468/Bernina-Virtuosa-153-Qe.html#manual
You may also try checking out some Yahoo Bernina Groups. You'll need a Yahoo email account, then search the Bernina Groups, and request admission. From there, you can post your questions as well as view the various documents that have been stored. Some groups have great manual libraries and very knowledgeable, helpful individuals.
Jan 03, 2017 | Bernina Sewing Machines
The feed dogs on my Bernina Virtuosa 153 are stuck down
Consult your owner's manual. Are the feed dogs mechanical? If so, perhaps they need oil?
http://www.berninainstitches.com/pdfs/Sewing_Machine_TLC.pdf
Mar 06, 2016 | Bernina Sewing Machines
Bernina frozen, nothing moves
it's possible that something has broken or come loose inside the machine and the machine needs to be checked..
Jun 26, 2013 | Sewing Machines
Bobbin thread tangling into knots on my Bernina QE 153
Its possible, refer to your machine manual to adjust the tension. You might need to change your needle to fit the thread you are using.
Feb 01, 2013 | Bernina Virtuosa 150
How do I service/oil my virtuosa 153 Bernina sewing machine
You can only oil the moving parts that you can see unless you want to take the machine apart which I do not recommend.
Mar 24, 2010 | Bernina Virtuosa 150
Apr 07, 2009 | Bernina Sewing Machines
May 13, 2008 | Bernina Virtuosa 150
Sewing Machines Logo
118 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
