Question about Exercise & Fitness
Jtx sprint 5 error code E07 - Exercise & Fitness
5 Suggested Answers
  • 19 Answers
SOURCE: Keep getting error code E07-27
E07-27 is a problem with the finisher tray lift motor. Make sure that a trash can is not under the tray. Have also seen screws work there way loose causing the tray to bind. If neither is your problem, you will have to call a service provider. Temporarily you can turn the power off, separate the finisher from the machine, unplug the connector, and turn power back on. You will not have a finisher but you can make copies until it is serviced.
Posted on Feb 06, 2008
  • 990 Answers
SOURCE: Error Code E07-12
HEllo sir; Try to make a copy without the cover,see the exposure lamp is on or not if not check the thermo fuse and exposure lamp.
Posted on May 25, 2009
  • 19 Answers
SOURCE: Error Code E07-27 How can I fix it myself ???
That error is a finisher tray lift error. If you do not see anything binding the trays, service will have to be called or finisher disconnected. Pay attention to the screws, they can loosen causing the trays to bind.
Posted on Jul 19, 2009
  • 45204 Answers
SOURCE: Error Code on Maytag MHWC7500YW O, Getting the error code E07
not sure it will help but I found this Error Codes on Maytag Washers eHow
Posted on Apr 30, 2015
The machine shows E07 error upon entering the service menu.
Door latching or lock error
·Door not detected closed
·Check door is closed
·Check door catch and latch
·Check door lock wiring
Check door lock
Dec 11, 2015 | Blomberg Washing Machines
Electrolux Cooktop Hybrid error E07- sometimes, cooking gets interrupted with E07 code and shuts off the panel. On next turn on, usually works okay. Could you describe me the error code? Thanks!
I appreciate your post, friend!
I see that you are having an issue with your Electrolux cooktop displaying a "E07" and shutting off. An "E07" code stands for an issue with your key sensor timer and this could be a potential problem with your right, left, or center board. This may not be a simple DIY job and I would highly recommend having a professional technician come out to diagnosis your cooktop. The technician will have the appropriate tools needed for properly diagnosing your cooktop. This step will help you to avoid any unnecessary part purchases. Hopefully this information is helpful. -Matt
Feb 19, 2015 | Electrolux Cooktops
Error Code E07
  • Open the drawer the printer is currently pulling from when the error message "E07" appears on the display. Verify that the paper in the drawer is the correct size and close the drawer firmly!
  • Oct 23, 2014 | Copystar CS-1500 Copier
    Screen on JTX V 5 monitor has gone so dark I can not see anything. Besides it flickers on and off in the dark .
    The back light is failing, and possibly the power capacitors for the HT circuit are failing to store the voltage necessary to power the screen, which would explain the flickering. This needs tested by an expert in monitors and TV's to confirm the actual source of the issue
    Jul 26, 2011 | Microtech JTX V5 15" Flat Panel LCD...
    Error E07 on Carl Lewis Treadmill
    does any1 know how to fix the e07 error on the carl lewis tredmill or why is has appeared?
    Feb 06, 2011 | Sport & Outdoor - Others
    Error Code E07-12
    May 23, 2009 | Panasonic Office Equipment & Supplies
    May 11, 2009 | Panasonic Workio DP-3520 Copier
    Jan 30, 2008 | Panasonic Workio DP-4530 Copier
    Exercise & Fitness Logo
    162 people viewed this question
    Top Exercise & Fitness Experts
    Electro Med Services...
    Howard
    Howard
    Tom Chichester
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
