Question about Panasonic Genius Prestige Nnsd997s Inverter Microwave Oven 1200w Stain
H98 on display
Won't let me heat anything and h98 shows up
3 Suggested Answers
  • 297 Answers
SOURCE: I HAVE MIC. NN-SD997S ,IT DOES NOT WORK ,MESSAGE SAYS "H98" .
This displaying indicates a
problem with the microwave
generation system
This is for your dealer to resolve
Posted on Apr 17, 2009
caroldon
  • 17129 Answers
SOURCE: h98 shows on display and
This error can be due to a failure in the output.Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean,solder and reset the board.
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced.
See link: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Thank You for using FIXYA.
Posted on Aug 18, 2011
Trouble code H98
H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
R
Oct 03, 2014 | Panasonic NN-H765BF 1250 Watt Microwave...
Model NN-ST659W works for about 30 seconds then displays H98 on the display panel how do I fix this problem
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
May 31, 2012 | Microwave Ovens
My Panasonic NN-ST657W microwave has suddenly come up with an H97 code on display panel. Switches off after about 6 seconds before displaying this code. What has happened?
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
There is not a lot the layman can do except maybe to try a new magnetron.
It is a job for an experienced Panasonic Microwave repair man.
Dec 31, 2010 | Panasonic Microwave Ovens
Microwave will not work...display reads H98
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
In Canada, you can find an authorized Panasonic servicer here.
Dec 14, 2009 | Panasonic Microwave Ovens
H98 error message. Micowave not heating, stops after 37 seconds
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Sep 28, 2009 | Panasonic NN-H965 Microwave Oven
generation system
Mar 11, 2009 | Panasonic NN-SD997S Microwave Oven
MESSAGE DISPLAY H98
The H98 fault on a Panasonic can be a bad magnetron, inverter or control panel.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 27, 2008 | Microwave Ovens
Panasonic Genius Prestige Nnsd997s Inverter Microwave Oven 1200w Stain Logo
47 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
