Question about Xerox WorkCentre M-24 Color Copier
Color registration on HP 7425
The registration of the four colours needs to be adjusted. Can the user do this themselves?
How to adjust color registration
user tools/ maintenance/color registration if fails will need to call a copier technician. something that need experience on this adjusting it
Jul 02, 2014 | Ricoh Toner for Aficio MPC2800, MPC3300,...
Color registration
In user tools there is a maintance button press and then try color reg adjustment. If it doesn't sink color back in alignment it will say fail will need to call a tech . Could be anything from transfer unit bar that is shiny usually toward exit side cake with toner to laser failure
Jan 15, 2014 | Ricoh Aficio AP3800C Laser Printer
Define 54.18 ERROR code on a Hp Laserjet 5500
According to the HP Service manual, there is no 54.18 error.
The listed errors are:
54.1 Temperature error
Check the fuser. See 50.X fuser error.
54.3 Image density sensor error
Check the connections. Replace the color registration detection assembly.
54.5 Colour registration sensor error
54.6 Image density error
54.7(Y), 54.8(M), 54.9(C), or 54.10(K) Drum phase sensor error
Check the connections. Replace the drum phase sensor for the indicated color.
54.11(K), 54.12(C), 54.13(M), or 54.14(Y) Toner sensor error
Check the connections. Check the cartridge and replace it if necessary.
54.19 Transfer Belt error
Check the ETB connection. Replace the ETB. Replace the DC controller.
It is most likely that you have a faulty Toner Cartridge.
Jun 21, 2010 | HP Color LaserJet 5500 Printer
Color print does not line up blue is printed off center of red but black is fine.
Make sure you have the latest Firmware installed on your printer, this can be found at HP.COM/SUPPORT/CLJ2605. It sounds as though the problem you are experiencing is Colour Pane Registration problems. If you have the latest Firmware, then tryturning on Registration (Configure Device>Print Quality>Optimize) and perform 3 calibrations in a row. If the calibrations take more than a few minutes each, check the error log (Diagnostics>Print error log) for any CPR errors. You may need a replacement Laser unit.
Nov 19, 2009 | HP LaserJet 2605DTN Color Printer
Registration of colors. The magenta and cyan are alittle offset from the black. I can get into registration mode but do not know which keys to hit to adjust.
When you get to registration mode, press enter, then execute will appear, then press enter. Then display will say adjusting. Remember magenta, cyan and yellow register to black. If registration is still bad you need to remove the four drums and transfer belt. To the left you will see a plastic move it to the left and you will see a white plastic with two sensor one at each end. This clear plastic get dirty and then you have bad registration. Clean it with a Q-tip. This two sensors are locate just below the left of the transfer belt, one at each side. This usually get dirty with residue of toner.
Jul 06, 2009 | Xante Ilumina Digital Color Press Printer
HP 1600 Colour laserjet Double image
Colour registration problem (some printer loose their registration from time to time).
There will be an option somewhere in the menu system of the printer, or the HP 'Toolbox' to correct this.
Apr 04, 2009 | HP Color LaserJet 2600n Printer
Register Problem
It needs a service call to do the color registration adjustments.
Dec 05, 2007 | Xerox DocuColor 12 Color Copier
Colour and black and white
Colors registration need to be adjusted. It's a long procedure to describe. But if you are close to PA or NJ PhillyCopiers.com can do it for you.
Sep 17, 2007 | Ricoh Aficio AP3800C Laser Printer
HP 9500n Colour Laserjet
The printer software should include a realignment tool,check the manual and E-mail HP Support
May 08, 2007 | HP C4170-90959 Service Manual -15754
Xerox WorkCentre M-24 Color Copier Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
