Question about Waterway Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge
My wet end is leaking from the backside. - Waterway Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge
I have a executive 56 frame 4 hp water way motor - PF-40-2N22C. Wet end was leaking at shaft, had it fixed and now the motor won't rotate at all. shaft is free it just hums. Checked supply voltage and the voltage at the connector. All is ok, what do i do now.
Posted on Jun 05, 2009
Water condensation is missing the drain pan and getting my floor wet. How do you access the drain or the drain pan to check for leaks?
before you try to access the backside, check inside if the drain is not blocked and the water is not leaking from inside the fridge.
Normally you have to access everything else from the back, so you have to move the whole fridge forward. The leak pan is most of the time visible from the back, without removing the (under part) of the back plane.
Aug 24, 2014 | Amana AFI2538A Bottom Freezer French Door...
Keeps running out of oil
Put the car on a hoist and look for an oil leak. Here are the common places to find a leak. 1) Valve cover gasket, can leak down on the backside of the engine. You should find the back of the engine wet with oil all the way up. 2) Leaking drain plug or oil filter. 3) Leaking oil pressure switch. 4) Leaking front or rear main seal around the crankshaft.
If the motor and underneath is dry and has no oil present, check the inside of the tailpipe. You may have a broken oil ring on one of the cylinders, or bad valve stem seals inside the top of the cylinder head. Be blessed.
Jan 02, 2014 | 2001 Pontiac Montana
Xp 2 wet end leaking
Probably seals are worn behind the impeller.
It is recommended to replace the pump motor as well as the wet end. Be sure to get a pump with same 1.5HP, frame size (48 or 56), pipe size (2" or 3") and an XP2e wet end (replaces the XP2).
Option 2 is to replace the XP2 wet end with the XP2e ($60-$80). Make sure the shaft is not rusted to assure a good seal.
If you want to replace the seals (online $7-$25), you'll have to remove the wet end and then the impeller which may be difficult. I just figured out how to do this. See "http://www.fixya.com/support/t6782638-remove_impeller_aquaflo". Again, check the shaft for rust.
May 18, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Just bought last week have an oil leak in driveway the oil is light brown in color what could it be..
oil cooler lines, transmission pan, power steering leaking or axle seals. All are pretty common.
IF you open up the access cover for the oil filter you will see the cooler lines. If they are wet with oil you found the first leak.
The trans pan will be wet if the gasket is leaking
the front axle seal will be wet right where the axles go in the front end.
The power steering pump, lines, gear box will be wet if they are leaking.
Feb 25, 2011 | 2001 GMC Jimmy
2001 saturn sl1 coolant leaked out at right front tire.
Hello, You probably have a leaking water pump, The water pump is on the backside of that end of the engine. You need a special tool to change the water pump. Thank you.
Sep 06, 2010 | Saturn SL1 Cars & Trucks
Rear wheel locks up when appling brakes
Hi, check wheel for bad/leaking brake wheel cylinder. An easy way to do this without removing wheel is to look at the outside of the drum from the backside for any brake fluid. If the backside of the drum looks wet, replace wheel cylinder. If it looks dry, remove tire and drum to inspect wheel cylinder for any brake fluid. If rubber boots on end of wheel cylinder appears to be dry, adjust rear brake turning adjusting screw (long bar on bottom with a "star" in center), replace drum, if you cannot put the drum back on easily, back up the screw you turned until the drum goes on easily but without too much slack, start car, apply brake, check drum to see if it can come off easily, if not, repeat until drum is snug, but not tight.
New rear wheel cylinder part avg.: $25-$35 ea.
Jul 08, 2009 | 1989 Lincoln Town Car
I have water leaking on the right rear floor passenger side
Sounds to me like your issue is with condensation from your air conditioner. The condensation isn't properly draining, probably from a damaged or clogged drain hose.
Jun 16, 2009 | 1990 Toyota Camry
REASSEMBLED WET END OF WATERWAY PF401A22C-LEAKS- NEED DIAGRAM
I've never seen a reassembly diagram for this particular pump but I'm guessing that you've installed the mechanical seal incorrectly.
Where is it leaking from exactly?
Kind Regards,
Ian Kime.
http://hottub.synthasite.com
Apr 03, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
Refrigerator moisture
hi there your fridge has whats called a wet wall evaporator where it freezes up then turns to water and runs down the wall , if you are getting water sitting in the base of the fridge check the drain hole which is sittuated at the bottom of the wet wall evaporator for any blockages ie. bits of food or paper labels.
hope this is of some help
Dec 13, 2007 | Marvel 24'' Outdoor Beverage Refrigerator...
Waterway Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge  Logo
1,265 people viewed this question
Top Waterway Garden Experts
Ian Kime
Ian Kime
Mike Raino
Level 1 Expert
john h
Are you a Waterway Garden Expert? Answer questions, earn points and help others
