Question about Pioneer DEH-P410
Buttons won't work
I have a pioneer DEH-P410 Head unit in my car. The buttons stopped working. It still displays the time and track for the CD and plays the CD. I cleaned the contacts on the back of the faceplate, but it still won't work.
5 Suggested Answers
tech48
  • 624 Answers
SOURCE: pioneer DEH-p4600
In the top right corner of the display is a small button that you push in and the face will drop down, this is for putting a cd into the unit and also for taking the face off. Once the face has dropped down you just pull it off. It will come right out. To put it back on again just place it back into the holder with the right side going in first and push it until it clicks into place. It doesn't take a lot of force to put it on or to take it off. If you are still having problems with it you may need to take it in for repair. But usually if the face is having problems with how it is attached, the problem is that the face will not stay on.
Posted on Dec 12, 2008
MNfisherman
  • 11896 Answers
SOURCE: Another one with Faceplate buttons not working?
The capacitors in these plates tend to burn out quickly for being so hot and lack of air cooling circulation. You can test all connection pins on the deck and faceplate with an ohmmeter in ohm setting to see which pins is not sending 25-30 ohms or 5 volts of power
Posted on Oct 23, 2009
  • 122 Answers
SOURCE: I am unable to reset my pioneer deh p4100. I see
remove the unit and disconnect the battery+red and yellow cables.check the front unit for derfomed plastics or stucked somehow microswitches!someone stucked from the heat!
Posted on Jun 06, 2010
kenw392
  • 2226 Answers
SOURCE: Where can I purchase worn out buttons on my
you can try pacparts.com
Posted on Dec 17, 2010
I have a pioneer DEH-P31/3100 would replacing thenfaceplate fix the issue of time displaying but no buttons working
Depends if the problem is with the face plate or the unit do you have someone with the same stereo that you can try otherwise you need t get it in to a service centre
Aug 25, 2014 | Pioneer DEH-P3100 CD Player
Hi, I have a pioneer DEH-P5500MP which always worked just fine but now when there is no cd in the radio it won't play so i try the source button but that doesn't work so i put a cd in and it starts...
It sounds like you may have a bad switch. If you have a multimeter you can check the switches for resistance. If the reading on any of the switches is less than a few megaohms it is probably bad.
Oct 30, 2011 | Pioneer DEH-P5500MP CD Player
My Pioneer DEH-P3500 car stereo is having problems. The front panel buttons will not work at all... the radio was working, but the head unit would not let me change stations or make any adjustments. I...
if its under warranty just return that on the store or in the authorized service center.if not just bring that on your local repair shop. because there is no serviceable parts inside the unit. ty
Jun 21, 2011 | Pioneer DEH-P3500 CD Player
Worn out rubber button's
Hello, That`s not a big deal. I pruchased the part, and mounted it myself. Worked out fine. The only problem I have now, is that the OEL-display doesn`t work any more. That sucks big time....
Best Regards
Mr.Thorn / Norway
Jan 31, 2010 | Pioneer DEH-P8000R
How do I set the clock on my Pioneer DEH-1900MP Head Unit
Turn the unit off with SOURCE, then push and hold SOURCE until it powers up and the hour flashes... Then use the up/down directional buttons to adjust hour, and left/right directional to move to minute.
Dec 15, 2009 | Pioneer DEH-1900MP CD Player
Clock setting on Pioneer DEH-P77DH in dash cd player
Setting the Time
This is the mode for setting the time on the unit’s clock display. (Refer to page 51 for
details concerning the clock display.)
As soon as you switch to “Minute”, the seconds start counting from 00.
1. Press the FUNCTION button and select the Time setting mode in the InitialSetting Menu
always select “OFF”.
2. Select “Hour” or “Minute”
with the < / > buttons.
3. Set as desired with the ^ / v
buttons.
Jan 04, 2009 | Pioneer DEH-P77DH CD Player
Changing the time pioneer DEN2000MP
The solution that worked for me is:
1) turn off the radio.
2) Push and hold the power button down (the dial). DON'T release the button.
3) The unit will display the time on the lcd screen with the numbers flashing, (only hr or min).
4) use the up/dwn, right/left buttons to set the clock.
5) turn off the unit by pushing the power button (again, the dial).
That is it. the clock should be set.
Hope that helps,
Nov 11, 2008 | Pioneer DEH-2000 CD Changer
Pioneer deh 6700
hello, my front panel doesn't work. Only volume is working but nothing else. Any fix? Do I need to buy a new front panel? Thanks.
Jul 04, 2008 | Pioneer DEH-P6700MP CD Player
Cant change the time
I don't have the manual, but I can tell you how to set the clock. This was a doozy to find out exactly how to do this! This technique probably will work with most other Pioneer receivers too.
Either start your car or turn the ignition key to the ACC position (so that the radio is receiving power). With the radio/CD turned off, press and hold the function button (the one in the upper right hand corner) for about 5 seconds, the hours on the clock should start to blink. Use the volume +/- buttons to change the hour, use the track up/down buttons to switch from hour to minutes. Press the power button to get the new time to set.
Jan 17, 2008 | Pioneer DEH-17 CD Receiver
Changing the time
Here's a link to the manual Pioneer's web site.
Here's how you set the time (from page 16 in the manual):
1: press SOURCE and hold until the unit turns off.
2: Press AUDIO repeatedly until the clock appears in the display
3: Press (left arrow) or (right arrow) to select the segment of the clock display you wish to set (hours, minutes)
4: Press (up arrow) or (down arrow) to set the clock.
- To cancel clock settings, press BAND
- to save clock settings press AUDIO until the display stops blinking
Dec 25, 2007 | Pioneer DEH-1500 CD Player
Pioneer DEH-P410 Logo
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
