Whirlpool wfs1276aw Stops in the middle of the program, always shows clean pump.i cleaned filter but problem not fixed.
  • 86 Answers
SOURCE: cant locate ''pump'' on whirlpool awo/d 5556
Hi, Whirlpool manuals do say that but they only mean the filter not the pump as this is self cleaning!
Hope this helps.....
Posted on Feb 27, 2009
localwonder
  • 6784 Answers
SOURCE: Kenmore washer he3t F2
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Posted on Jun 22, 2009
  • 141 Answers
SOURCE: i have philips whirlpool awo/d 4605 model and its
The unit front portion either right side or left side you will find the small door you just open the door and remove the filter in anticlockwise direction it will come out just clean the filter and then close it safely
If you want to clean the pump you are suppose to open the back door of the unit and trace the outlet valve it will be connected to the pump after finding the pump just remove the hose from bothe side of the pump and clean the drain pump neatly and refix it
Posted on Jan 05, 2010
SOURCE: Whirlpool washing machine "clean pump" error light.
take top off machine. look down right side and you will see a disc about 50 mm in diameter, attached to this is a small flexible rubber pipe, take this off at the disc and blow through it,( you will need some type of pipe to connect to the rubber pipe).this worked for me with the very same problem.
Posted on Mar 13, 2010
  • 119 Answers
SOURCE: How do i clean a filter of a whirlpool awm 5080 front loader
If you are talking about the drain pump strainer, you need to remove the lower front panel. should be 3 screws on the bottom facing forward. Once you have that off, the pump strainer is almost in the center, facing you. unscrew it counterclockwise to remove.
Posted on Apr 26, 2010
My whirlpool washing m/c 1400rpm awo/r 5406 will not complete the wash cycle it washes until it gets to spln and drain then the service light comes on (spanner)washer stops working but water still flo
locate the dranage water pump, screw it ou nd clean or check on the filter cuup,,always situated next to the water pump below,,u can trace the pump along with the outlet
drainage tube
Jan 26, 2015 | Whirlpool Washing Machines
I have a whirlpool wfs1276aw. It suddenly stopped working displaying the error F06.
pl.check the current and voltage with the meter and continuity test after unplugging the mains chord,which may give some iferrence
Dec 02, 2014 | Whirlpool Washing Machines
Why does my whirlpool frontloader stop in the middle of a cycle and read f 02
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Sep 06, 2014 | Whirlpool Washing Machines
I have a Whirlpool LSR5132JQ1 top load washing machine. It washes fine but stops when it comes to draining the tub and starting the spin cycle.
A very possible cause of it not draining is because the filter screen on the pump is clogged and needs to be cleaned. This tip i wrote will show ya how to clean the screen on the drain pump,
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
I hope i have been able to help ya fix your washer,
GENE
Oct 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool front loader...not sure of the style number at the moment...but about a month ago the clean pump light came on...so my partner and dad drained the filter at the front down the bottom and...
did they remove the bottom panel and remove the middle part of the pump and clean out the pump?unplug it,with the bottom off reach up and at the bottom of the door lock assy. there's like a tear drop shape tab made of plastic that you pull down,you'll hear a click and the door can be opened.to clean the pump,with a shop vac vac out all the water in the tub,then go to the pump,turn the middle piece counter clockwise until water starts to leak out,vac it up as it leaks out until it stops and then turn the middle piece all the way and remove it,you can stick the vac in the pump and vac out anything that's in there and then stick your finger in and feel around to make sure nothing is stuck in with the impellar,put the pump back together,add some water and put it on drain spin,if the water drains out you're all done if not you have to install a new pump.part number 280187 and it's around 120 sollars
Feb 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washing machine stops at the middle of the cottons and pre-wash programme and the timer shows different times most of the time e.g. For the cottons and pre-wash cylce it sometimes shows 1hr47mins and at...
Check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long. Below is given a procedure not exactly for your machine, but it could be a lead.......(its for the whirlpool duet)
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 19, 2010 | Washing Machines
Mar 09, 2010 | Whirlpool Washing Machines
Washer not spinning/draining and it's showing me a code (F21)
clean the drain -here are a few postings i used to fix my Whirlpool ****-eettt (Duet)10 minutes ago. google whirlpool duet there is a 5 min video by jim that walks through the whole gig. 3 screws a twist & you're done your correct so lets fix it...take bottom acess panel of ..theres three screws,,,ok ready clean that pump filter it right in front of you twist it out always unplug first unplugged good,,now while your down there with the filter out,,check booth black hose to make sure theres no coin or hair clips while you have it open,,onthejob
Mar 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool dishwasher ADP905
Depress start button till start light goes out. Close door, drain pump should run for a while. Wait for end of program, rer-try a new program start. This process is re-setting memory.If this fails to sort problem then start checking components, ie: fill valve water on? heaters open circuit/down to earth, drain pump, is it emptying, wash pump.
Jul 31, 2008 | Whirlpool 24 in. ADP6940 Dishwasher
Washing Machines Logo
Top Washing Machines Experts
