Question about Brother IntelliFAX 4100 Laser Fax
Dum problem my fax shows me a message that i have a problem with the drum and i have to change it soon
  • 1 more comment
  • mickeymo Dec 19, 2007
    says change drum soon. changed it and still says, change drum soon. how do you get it to reset?
  • aleuin Dec 08, 2008
    Changed the drum and message continues to read "change drum soon" I have turned off and unplugged to try and clear the message to no avail.
  • Anonymous Feb 14, 2009
    does not work for me
1. Open the drum/toner door on the front of the machine.
2. After the beeping stops, press the button on the line of buttons that says Menue Left arrow set richt arrow and clear button.
3. The menu will say replace drum? 1. yes 2. No
Press the number 1 on the number pad and close front door.
Posted on Jan 30, 2008
The actual button you push to make the message go away is clear and then select yes. The rest looks good.
Posted on Jan 17, 2008
  • Brother Master
  • 1,113 Answers
Normal consumable life end alert, buy yourself a Gen Brother drum for your machine, and replace and reset counter (with front cover open press set I think, and select change drum YES. then ok) anyway should be instruction inb drum box when you get it
Drums wear out, they do a lot of work with little reward!   It will keep going for a while then you will experence a loss of print qualiy dark/light,marks,lines etc
Posted on Oct 19, 2007
Change drum soon
Open the front panel.Press and hold the clear button.When "Drum replaced"shows on the lcd panel select yes.The message will be reset.If you experiece any lines in the future you will have to replace the drum catridge.
Mar 12, 2010 | Brother IntelliFax-2820 Laser Fax
Message reading change drum soon permanently on screen. changed the drum as no printing could be seen, ie paper blank. however, still got the change drum message on the screen. how do i get rid of this?
7 Wait until the time, date and answering mode appear on the display. Then press the SELECT FUNCTION key. ecblank.gif ecblank.gif ecblank.gif ecblank.gif 8 Press the 7/COUNTER DISPLAY One-Touch key. The display will show DRUM COUNT. ecblank.gif ecblank.gif ecblank.gif ecblank.gif 9 Press 2.413c?openelement&fieldelemformat=gif to clear the image drum unit
counter. ecblank.gif ecblank.gif ecblank.gif ecblank.gif 10 Press the SELECT FUNCTION key to finish. ecblank.gif
Dec 03, 2009 | OKIFAX 4500 Plain Paper LED Fax
How do i reset the message change drum soon on
Press Clear.
8 Press 1 and when the LCD shows ACCEPTED,
and then close the front cover.
Jun 05, 2009 | Brother IntelliFAX 4100 Laser Fax
Open the front couver as if you are about to change the drum unit. With the couver still open, press the options button for a while and in the display will apear a message asking if you want to change the drum unit. Choise the yes option and close the front couver. GOOD LUCK.
Nov 13, 2008 | Brother IntelliFax-2820 Laser Fax
Fax Problem
Once you have changed the drum unit on Brother 4100 you will need to keep the front door open and then press the option button. Your dispay should give show you a drum change option. press 1 to change drum and the machine should show "accepted" after a few seconds. Afterwards, close the door.
Oct 28, 2008 | Brother IntelliFax-4100e Fax
Drum intellifax 4100 Brother
some faxes will shut down if it senses toner low/out
you must replace and maybe reset counter
Jul 30, 2008 | Brother IntelliFAX 4100 Laser Fax
Change Drum Soon still shows after changing the drum unit
After changing the Drum, open front cover and press "clear" then press "1" to reset.
Jul 22, 2008 | Brother IntelliFAX 4100 Laser Fax
Continous 'change drum soon' message after I change the drum.
5750e fax machine: To reset the drum counter follow the instructions listed below :
Get the message to appear in the LED
1. Open the front cover.
2. Remove and Re-insert Drum/Toner unit
3. Press the CLEAR key.
4. Press 1 to reset.
5. Close the front cover, pressing firmly on each side until they click
into place.
Jul 08, 2008 | Brother Office Equipment & Supplies
Change drum soon will not clear after new drum inserted
Reset of the drum counter
Press the Options key on the control panel.
The display will show "REPLACE DRUM - 1.YES 2.NO".
Press 1 to reset the drum count.
Close the front cover.
Hope this helps...
Jun 10, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
460 people viewed this question
James Cagle
James Cagle
Jim Keysor
