Question about Panasonic PT-D5700U Projector
When projector is first turned on, picture is frozen with lines through it. No buttons on remote or projector will work. If I let it warm up for 5-10 minute, then turn it off, then on again, it work
When I turn on Panasonic PT-D5700U first thing in the morning, it shows a frozen image on the screen and no buttons on the projector or remote control will work. If I let it run for 5 minutes, then manually turn it off, then turn it back on again, it works. Any idea what it causing this?
SOURCE: PT-LC50E LCD Projector
With power available at the projector and the lamp off (projector off) - hold the input button on and press the power button on and hold for 5 secs. This will reset the lamp timer to zero.
I wish they could have stuck this in the operators manual.
Posted on May 27, 2008
  • 4234 Answers
SOURCE: cannot access menu screen on Panasonic PT-D3500U projector
If memory serves me correctly, there is an OSD button on the projector itself. Press that once. You may have turned off the OnScreen Display feature. If that fails to resolve the problem, please let me know and I'll look up your specific model.
Dan
Posted on May 28, 2008
SOURCE: Panasonic PT-AE700E HD Projector, Has A Colour Problem
the filter on your projector has gone bad the same needs to be replacerd
Posted on Jan 04, 2009
SOURCE: Panasonic PT-AX200 lamp problem
I have the same problem (cycling between 2 brightness levels). I contacted the shop and the salesman (who is an expert in home cinema installations etc) told me that it has to be the last hours of my lamp's life... I don't know yet, I'll find out soon though...
Posted on Feb 05, 2009
SOURCE: Panasonic projector PT-L78 lamp reset
Press the MENU button. Use the < > arrows to get to the OPTION menu. Press the ENTER button. Select LAMP RUN TIME. Press and hold the ENTER button for about 3 seconds. The 'lamp time reset' will display. Press OK and press the ENTER button. This will reset the lamp hours as well as turn off the projector.
Posted on Feb 25, 2009
What causes picture to freeze?
the t-con board memory, it can also be the main av board as some have a pause screen feature that can sometimes be accessed from the remote, but some remotes dont have the button. but the memory failing is the cause. so its either the memory in the t-con board or the memory on the main av board. to find out what one it is you will need to remove the t-con board lead and plug back in a second later if the screen works its the t-con board if it stays frozen its the main avi board.
Aug 09, 2017 | Sony KDFE60A20 60" LCD HDTV
I cannot turn on 3d mode on my lg projector pa70g cause it doesnot see this mode. And when i click 3d button on the remote it doesn't change the picture. Help me please!
you need to be connected to a 3d source when you try and switch and it must be playing 3d media before the projector would even try and im sure you know you need to be connected via hdmi for this to work, so grab a 3d dvd player and a 3d capable hdmi cable and a 3d dvd and then try it--Good Luck.
Jan 28, 2013 | Televison & Video
I my projector is new one used for 4 hrs, when i try to turn it on it just has a blinking green light. Please help Solve It! .
The blinking green light means the unit is either Powering On (Warming Up) or Powering Off (Cooling Down).
Powering On the Projector
1. Remove the lens cap.
2. Securely connect the power cord and signal cable. When connected, the ON/STANDBY LED will turn Amber.
3. Turn on the lamp by pressing " " button either on the top of the projector or on the remote. The ON/STANDBY LED will now turn Green. The startup screen will display in approximately 10 seconds. The first time you use the projector, you can select your preferred language from quick menu after the startup screen displays.
4. Turn on and connect the source that you want to display on the screen (computer, notebook, video player, etc). The projector will detect the source automatically. If not, push menu button and go to "SETUP". Make sure that the "Source Lock" has been set to "Off". If you connect multiple sources at the same time, press the "SOURCE" button on the control panel or direct source keys on the remote control to switch between inputs.
If you are still unable to get the unit to turn on, try unplugging it for 10 minutes and plugging it back in. If it still ceases to work, contact Optoma here: http://www.optomausa.com/rma_policy.asp
Their Technical Support line is 1-888-887-5001
Feb 25, 2011 | Optoma HD20 DLP Projector
The advance and reverse button is frozen. the auto focus is also frozen my kodak carousel custom 840H projector is 35 years old. should I just buy new?
You may have trouble buying new. Kodak stopped manufacturing slide projectors in 2004. There are qualified repair dealers that you can send your projector to & get it fixed. What you describe is a pretty common problem with the Carousel Custom line as they age...
Sep 27, 2010 | Kodak Office Equipment & Supplies
Remote won't turn on Eiki EIP-2500 projector
Try cleaning the IR port on the projector (and the remote itself). These can get enough of a dust layer build up that they can't "see" the infrared signal being sent.
Feb 08, 2010 | Eiki EIP-2500 Multimedia Projector
The projector comes on.but there is no picture.lens not opening
Press and hold the two Keystone buttons on the top of the projector. Turn the projector ON and continue to hold down the two Keystone buttons for 15 seconds.
Release the Keystone buttons.
Turn OFF projector.
Turn ON projector, lamp should strike.
Sep 23, 2009 | InFocus ScreenPlay 4805 Multimedia...
I have SP4805 bulb does not fire up "New"
push and hold both volume up and volume down for 10 seconds.
Mar 03, 2009 | InFocus ScreenPlay 4805 Multimedia...
Remote control and lines in picture
Hi there
If I were you I would take the Projector back to where you purchased it from - because the remote makes out a vital part of this unit and secondly - lines on the image is normally a faulty Mainboard that is very expensive to have replaced.
Mar 18, 2008 | Kodak Digital Projector DP1050 Multimedia...
VW10HT screen filled with horizontal lines until unit warms up (5-10 minutes!)
I have a similar problem with our projector. It help to reverse the output for some reason. When reversed, all horizontal banding disappears.
Jan 22, 2008 | Sony VPL VW10HT Multimedia Projector
Panasonic PT-D5700U Projector Logo
57 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
