Question about Car Audio & Video
Pioneer error 02 9e - Car Audio & Video
I HAVE A PIONEER MODEL XV-DV151 AND HAS OC ERROR
while stad by bottan pressing oc error coming on display
Jan 19, 2013 | Pioneer Televison & Video
I have a pioneer car radio and i am receving and error 12 message
I found the following information on Page 28 of the Pioneer manual for your DEH-P2900MP through the pioneer website:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/370967683DEHP2900MPOperationManual1027.pdf
ERROR-11, 12,
17, 30
Dirty disc Clean disc.
ERROR-11, 12,
17, 30
Scratched disc Replace disc.
ERROR-10, 11,
12, 15, 17, 30,
A0
Electrical or me-
chanical
Turn the ignition
ON and OFF, or
switch to a differ-
ent source, then
back to the CD
player.
I hope that helps
Jun 22, 2010 | Pioneer DEH-P2900MP CD Receiver...
Pioneer cd player errors
replace your disc and get the player service
May 21, 2010 | Pioneer CDJ-100S CD Player
What is Error 9101, on the pioneer MK2 800. and how can it be solve
Error 9101 is a Disk-Read error. More than likely either your traverse assembly, or your loading motor is damaged - or both.
In either case, you'll have to take it to a qualified service center for repair.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
Aug 10, 2009 | Pioneer CDJ-800MK2 Turntable
E-8310 error code, will not play discs and intermittenly will not eject.
This is a Traverse Assembly error. More than likely it will have to be replaced.
The part can be found here: Pioneer CDJ800MK2 Part
But I do not recommend self-repair for something like this.
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Apr 21, 2009 | Pioneer CDJ-800MK2 Turntable
Error 70 / 60 /50
Those errors mean that there is an electrical or mechanical system fault. The pioneer website suggests to turn the car ingition off and on again, or press the power ON/OFF button on the display unit and try to play the CD again.
That seems like the obvious solution to me, which Im sure you have already done. You can try to contact Pioneer for more info.
Dec 05, 2008 | Pioneer CDX-FM687 6-Disc CD Changer
Error code 11 - pioneer avic 1r
From Pioneer;
"Error code 11 is more specific, however, indicating that the player’s read laser cannot focus properly, most likely due to a fault with the disc."
Try a different CD, or you may have to have the laser cleaned.
Best of Luck.
Nov 17, 2007 | Pioneer GPS AVIC-X1 car radio
Pioneer DEH-P6900UB iPod Control
My suggestion is that the ipod-connector is bad. Try changing the ipod connector. If that doesn't work, unplug your Pioneer device for 24 hours, and then plug it back in. This will reset all the configuration options and should reset the devices that it recognizes. If that doesn't work, try calling Pioneer's support.
Nov 13, 2007 | Pioneer DEH-P6900UB CD Player
Pioneer KEH-P6600 diplays "error-11"
use your user guide to read the problem related to error 11 .. most probably your wire connecting your changer witht he head uint is either cut or not functionall ... hope that answers the question
Jun 25, 2007 | Pioneer KEH-P6600 Cassette Player
Car Audio & Video Logo
52 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
