Question about Midland Radio Communications
Midland 38 low receive
Low audio on receive
    Genius:
  • Midland Master
  • 1,795 Answers
Sounds like a football game
Posted on Sep 13, 2016
2 Suggested Answers
SOURCE: hi i have a midland
there is but if u get it wrong then you are stuft. i would just try the earth first cause altho the swr is good if the grounding is poor this will effect sigal.depending on mounting will depend on earth solution
Posted on May 01, 2011
Wiring for Adonis desk mic to midland 8001
http://www.adonis.ne.jp/e-desktop.html click the PDF link for the mic you have. 1 audio, 2 shield, 3 receive, 4 transmit
Sep 09, 2014 | Radio Communications
Midland 75-785 gets very hot within minutes of powering on
The radio is either stuck in transmit or the RF power output section has a short in it. If there is no RECEIVE audio and the squelch is open, and the radio is not in transmit, the chances are pretty good that the audio power amplifier is shot.
Apr 22, 2014 | Midland Radio Communications
could be a number of things from your final and driver to your audio IC .you may need a transistorchecker to find a problem with the finals and driver and a vom meter to check the IC but it could be a resistor in the area of the audio IC that is burnt. To find out what the problem is you will need a schematic of the radio. As I have a number od midlands I can tell you that if you don't have a service manual you may not have one.I have looked several time for my radios and I can't find anything. www.cbtricks.com has a few.
Jan 02, 2014 | Midland 40-Channel CB Radio CB Radio
Midland 38 plus won't transmit
did you check for broken wires to the mic.?
Jan 15, 2013 | Midland 75-785 Handheld CB Radio
Hi i have a midland 38 plus cb but the recieve is poor i have an excelent swr is there anything i can do to turn the receive up inside?
May 01, 2011 | Midland 40-Channel CB Radio CB Radio
Trying to get our Motorola (yellow/ black) to communicate with Midland two way radios. They Midland will receive messages from Motorola, but they can not send to it Motorola.
Most likely your CTCSS tone codes are not turned on on the Midland radios. The CTCSS codes are also known as "Privacy Codes" or similar.
They will be from 1 to 38. Your Midland manual will tell how to set the codes on the radios. The Motorolas usually show the selected tone code below the channel number.
Alternately, you may be able to turn off the tone code on the Motorola radio(s) by setting it to "0" or "off". Then you will not need codes turned on on any of your radios and they should all communicate fine.
Dec 16, 2010 | Motorola Walkie Talkies 2-Way Radio
Receivers complain about squeeling noise from my midland 1001z when I transmit. Is this an RF Gain setting problem?
I had the same (squealing) problem on transmit with the Midland 1001Z when I used it indoors as a base unit. The problem was my power supply: it broke into oscillation when drawing more than 150 mA at 13.8V. The 1001Z draws about 150 mA on Receive, and much more (but only about 900 mA) on Transmit. If using the 1001Z as a base unit, I suggest you power it with a fully-charged car battery indoors, or test your power supply to check if it can't supply the required 1 Amp, approx., on Transmit. It's a GREAT radio, just give it a good power supply. My power supply was defective out of the box, but now I have a good one and get great reports on signal strength and audio quality. Remarkable, for the low price and 3 year warranty. Good luck!
--Sky Junkie / Tucson, AZ / USA
Sep 27, 2009 | Midland 1001Z 40-Channels Base CB Radio
75-822 cb that has extremely low audio output
Hello..if you can try to connect a external speaker or phones..if the volume is ok..than i think it is time to replace your internal speaker..pse tll me....good luck...Ron
Mar 14, 2008 | Midland 75-822 40-Channels Handheld CB...
Radio Communications Logo
127 people viewed this question
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
