Question about Sharp AL-1641CS Laser Digital Copier
DARK SPOTS WHEN I GET A COPY MY COPIES HAS SEVERAL DARK SPOTS IS A KONICA, WHAT CAN I DO TO FIX IT.?
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
Correct dark spots with our clinically-proven serum treatment. Contains Activated C to fade age spots, prevent skin discoloration for even skin tone.
Posted on May 02, 2017
  • 41 Answers
Are the dark spots random and moves location with every copy or are they at exacly the same place on every copy? Random you will need to remove the drum/toner and use a blower to clean the inside of the machine,failing that replace the drum unit.If the spots don't move clean the top glass.Let me know
Posted on May 22, 2009
Konica 1212 copies to dark
1st the basic cause of dark/grey copies DUST. Clean w/ alcohol cloth then dry cloth totally all mirrors and the platen glass both side. If still dark check the "Optic slit " right in the upper of your halogen lamp remove it, still dark Check your halogen lamp maybe it already oxidized. The last solution adjust the CVR .
Nov 27, 2014 | Konica Minolta Konica 1015 1120 1212 Toner...
I an getting light copies on konica minolta bizhub 362 what is the adjustment to make copis dark
Normally light copy comes out when mirrors are dirty. Before any adjustment clean the slit glass and mirrors.
Dec 17, 2012 | Konica Minolta Bizhub 362 Copier
Prints and copies coming out with dark spots
Please replace the cartridge /toner with a new one and see what you get.
Jan 31, 2012 | Canon iR1510-1670
Its me again,after the user changed a new toner cartridge after few copies there is a dark back ground in copy.before replacing the toner the copy was perfect pls help me in this problem
Hi, After a few copies, the toner supply unit pulls more toner, which results in dark copies. To fix this, you have to reduce the contrast (to minimum). Also, make sure that there is no excess toner within the toner supply unit.
Hope it helps! Good Luck! Thanks for using Fixya! CreativeTECH
Sep 27, 2011 | Panasonic Workio DP-4530 Copier
Our Gestetner DSm645 gives Dark Copies..........
Sounds to me like the drum needs replacing, and likely the developer too. There is probably a haze of toner still on the drum. You can check by opening the right side cover and looking at it. Is there toner on the drum (green cylinder). It may not be too obvious depending on how dark the copies are. GENTLY wipe a tissue across it after making several copies - it should be clean if the drum is functioning properly. If it is, it could be the fuser that is wearing out, but I'm leaning toward the drum. As I said, if you need to replace this, it is a good idea to do developer at the same time, because these machines tend to be a little sensitive.
Mar 18, 2009 | Office Equipment & Supplies
On the konica 2223 when printing it leaves a dark thick line down the center of the paper.
Konica 2223 copiers are analog meaning the image that comes out on copies is a direct reflection off of the copy. Dirty mirrors in the optic section can cause a dark band, but it is more of a shading effect. Drum assembly's can be removed.The image drum has a cleaning section that uses a urethane blade to clean excess toner off of the drum after the copy passes through.It is simply called a "Cleaning Blade" these blades can be ordered through most online copier part stores. Last but not least is the "Upper Fuser Roller". this is the hot roller the paper passes through to "set" the toner to the paper. These are coated with teflon to prevent toner from sticking to them. They have "seperator claws" that keep the paper from adhereing to the roller, and they sometimes gouge the teflon. this exposes bare metal, and the toner can come off of the copies and stick to the roller.
Jan 16, 2009 | Office Equipment & Supplies
Question
1) For a copy to be blurred: either you need to add more ink (Toner) or you need to increase the toner density
2) When you have dirty copy: Try to clean your glass and the glass cover and also clean the mirrors inside and the zoom/lens.
3) a dark dot: you have to bring out the drum unit and roll it round you may be able to see a spot on, clean it with a fry cloth and fix it back to its position.
May 08, 2008 | Office Equipment & Supplies
Konica 1216 copier makes black dark copies
dear sir i have information P 27 on my konica copier. how do i solve the problem..?
Apr 15, 2008 | Ricoh Aficio 1013F Copier
Sharp AL-1641CS Laser Digital Copier Logo
196 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
