Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Not connecting to internet
I have a linksys 4 port router attached to it is a 16 port liksys switch every line that is connected to the swith will go online via ip 10.0.1.1 but the lines connected directly to the 4 port router will not connect to internet the switch is new
  • JDTec
    JDTec May 11, 2010
    Do you have the router set for DHCP?
    Scholar:
  • 62 Answers
Do you have QOS on the router to be ON?
Or have you set up Access Restrictions?
Posted on May 24, 2009
I want to add a LINKSYS workgroup switch EZXS55W behind my wireless routher LINKSYS BEFW11S4 v2 via uplink cable connection. When hardwiring my anything to the switch port 1-4 does not get internet access
Are those 4 ports in different Vlan ?
If you connect your wireless access point to the 1st port are you able to access the internet through 2nd port or 3rd port ?
Are the ports 1-4 admin down ?
Dec 23, 2010 | Linksys Bundle: BEFW11S4 802.11b Wireless...
My router stopped communicating with modem
LinkSys Wireless-G WRT54G 2.4 GHz Broadband Router with 4-Port Switch:
Go to LinkSys Login. wrt54g_back-panel_mini.gif Resetting the Router will erase all of your settings (WEP Encryption, Wireless and LAN settings, etc.) and replace them with the factory defaults.
There are two ways to reset the Router's factory defaults:
The Internet port is where you will connect your broadband Internet connection.
Please Rate Me
Nov 17, 2010 | Linksys WirelessG Broadband Router with...
Hi i am chinni working in a bpo company. i wanna configure dhcp network in my office. can any body helps me
Hi, by default the Linksys router is set to DHCP... So all you have to do is connect an ethernet cable from your modem to the WAN/Internet port of the router and then connect a PC to one of the ports, see if that will be able to connect to the Internet if not, try to do a power cycle (turned off everything and then turn on the modem first and wait for all the lights to be stable and turn on the router and then the PC) once the computer gets online you may connect the rest... should you require to connect more than 4 PCs, you may need to have a switch but with this setup the physical connection should be
Modem to WAN port of the Router to Switch port and all PC should be connected to the Switch's ports
Mar 27, 2010 | Linksys EtherFast 10/100 16-Port Workgroup...
Linksys EZXS16W Issue
Hi There, first of all you need to connect from your modem or router's port a link. Use a cat5 ethernet cable from the modem to the switch or if you also use a router from a port in back to the switch. Then when you plug in other computers it will see the internet connection. Good Luck...
Oct 28, 2009 | Linksys EtherFast 10/100 16-Port Workgroup...
How do I configure a BEFSX41 to be an access point (router only)? I've given up on using it to access the internet due to connection problems. I switched my Belkin 54G from an access point to the main...
If you have a modem and a router the two needs to have seperate Ip address. For exmaple I have a westell 6100 G modem with a wrt54g speedbooster router. I have my modem local ip set at 192.168.1.1 and my router local ip set at 192.168.9.1. I got my router on to do the dchp starting address with 192.168.9.15. Plug your cable from the modem into the wan port of the router and it sould work.
Oct 04, 2009 | Linksys EtherFast BEFSX41 Cable/DSL...
Need to connect my old Linksys modem to a new Motorola SBV5121 cable modem.
THE MAIN LINE GOES INTO THE WAN PORT FROM THE MODEM PROVIDED FROM YOUR MOTOROLA .....THEN THE 4 PORTS ARE TO CONNECT THE COMPUTER ....HAVE FUN
Jun 02, 2009 | Linksys Wireless-G WRT54G Router
Where does the phone line go in the lynksys box.
Phone Line?
You need a cable or dsl modem to connect to the internet. From the modem you run an ethernet cable to the "broadband" or "Internet" port of your router.
Also make sure your lynksys is a router, not a switch
Hope this helps
Cor
Dec 31, 2008 | Linksys EtherFast 10/100 16-Port Workgroup...
I cannot install the CD for my router
u can simply connect connect modem to internet port on router and connect no 4 of linksys to computer and u will be able to go online ....
Oct 22, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
81 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
