Question about IBM ThinkPad T20 2647 Notebook
Errors My notebook keeps booting but I never get to the main screen because it's always saying errors. Then it gives a list of errors like 161,190, and 163. Then it just stops, not allowing me to doing anything except turn the power off.
  • IBM Master
  • 4,806 Answers
Hi there.
161 and 163 mean time and date not set
any error like this is a dead giveaway you're cmos is dead.
Its a really common problem.
192 seemed to be incorrect voltage or fan the fan blows out the side to the left and cannormally be heard or felt,
You need to do a check which is achieved by holding down F1 and powering it on, keep F1 held down and wait and you should get the config come up.
Run the system board check.
On systemboard check you get
dev001
err 91
fru3610 or fru 3810
or something very similiar
It means the cmos battery is dead, you will need to change the battery, in some laptops the cmos battery is different so you'll have to check.
To do this you need to take the memory cover off on the
bottom of your thinkpad undo it with a screwdriver and youll see a white connector to topright or bottom left depending how your looking at it with a red and a black wire.
This is connected to the cmos battery which is tucked under the black plastic of the case.
You have to wiggle it round a bit and pull it out but its not connected.
The original one has a yellow shrinkwarap thing on it.
heres a link so you can see exactly what its like,
http://www.sabahoceanic.com/SearchResult.aspx?CategoryID=213
Undo the plastic with a pair of scissors and prise of the metal clips soldered in place with pliers or something
making sure you remember if red is positive or negative
Flatten the clips and then tape your cr2025 battery onto them
with electricians insulating tape and then push the white connector back and tuck the new battery back in position.
Good luck and thanks for using FixYa!!
Posted on May 21, 2009
  • Lee Hodgson
    Lee Hodgson May 21, 2009
    Oh and i forgot to tell you, if you want to use the computer before you replace the cmos battery just set the date and time in the bios, save the changes and exit, the computer should restart and boot up, please make sure you have AC power connected as it may forget the date and time again and show you the errors.
    Regards
    Problem Solver:
  • 10 Answers
Before it boots up hold the f8 button down then you will get a list of options try to boot it up manually from there did you create a back up disc by any chance if you did boot form disc
Hp mini "unmountable boot volume"
I ran across the same problem. I used chk disc utility on a hiren's bootable usb. It found and fixed the errors on the main volume and it rebooted up without a problem after that.
Jan 27, 2012 | HEWLETT-PACKARD HP Mini-Notebook...
My Hp probook 4510s cannot boot it gives error of PXE failure after startup screen it says media cable check error.
Your computer tries to "boot" from several devices:
* floppy disk
* CD/DVD drive
* internal disk-drive
* USB memory-stick
* over the network, if it can find a "boot-server" on the local network.
So, the 'PXE failure' and 'check cable' errors occur either because there is no cable connected to the network-port, or because there is no "boot-server" on your network.
Enter BIOS setup, and check the "order" of possible boot-devices,
to ensure that the "network-boot" device is set to the _lowest_ priority.
What this could mean is that the computer *TRIED* to boot from the disk-drive, but *FAILED* to do so, i.e., you have a problem with the disk-drive in your computer. Ouch!
Aug 28, 2010 | HP 4510S C2D226 156 4GB 320GB DVDR BT CAM...
Will not boot says operating system not found
if it was working before that message, then probably the operating system is corrupted.
insert the windows cd when you boot your pc and when the message "Press any key to boot from dvd" appear press enter.
Follow the screens to repair Windows. the sytem files will be restored.
Jan 25, 2010 | Toshiba Satellite A105 Notebook
Can't reload windows xp. Keeps shutting down???? Acer 2700 Laptop
this happens when you have errors with the hard drive not responding to the new boot or drivers not responding. is this a clean install or a restore? if you are not using the original xp disk the machine came with you may get these errors. the blue screen usually has a message in it. let me know what it says if you get a second.
Jul 18, 2009 | Computers & Internet
Armada 7400
What operating system do you have and what exactly does the screen say?
Aug 23, 2008 | Compaq Armada 7400 Notebook
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
Post Erros
well...the error codes are usually from MSoft, if on boot up...most are operating system related..
Mar 23, 2008 | HP OmniBook XE3 Notebook
Windows will not boot
Just turn-off network boot in your bios
Nov 15, 2007 | Acer Aspire 5100 Notebook
Press (F1) to resume, (F10) to setup
I need a bit more info to try to give you an accurate solution
Does the screen change after you press "F1" ?
Do you have access to an external keyboard, if so try plugging that in while the computer is off and then using that to press "F1"
Nov 15, 2007 | Compaq Presario M2000 Notebook
IBM ThinkPad T20 2647 Notebook Logo
113 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
