Question about DeLonghi Coffee Makers & Espresso Machines
Delonghi ESAM5450 stuck on heating up cycle after switch on
Delonghi ESAM5450 goes through start up self check then goes to 'heating up' then defaults to general alarm cycle and never makes it to the rinse cycle... so no functions become active.. and no coffee. Has anyone had a similar problem. Machine has been cleaned fully.
  • 421 Answers
SOURCE: Coffee machine Delonghi Magnifica grinding function not working
There are two reasons for this usually. Either the grinder is jammed or the grinding wheel or wheels have broken. Your machine needs to go to a repair shop to be looked at.
Posted on Jan 13, 2010
  • 109 Answers
SOURCE: Gaggia Titanium stuck on RINSING CYCLE
Let it rinse it may run for some time.
you will not be able to remove the brew unit as it is engaged to be rinsed.
Posted on Feb 22, 2010
EwingElect
  • 276 Answers
SOURCE: Delonghi coffee machine making an aweful noise,
Hi. Husband asks: When you first turn the machine on at the power point, does it make a motor sound and then stop, or is the awful noise apparent at that time.
If the awful noise starts as soon as you turn it on, then most likely there is a motor problem which will need to be seen by a Service Center.
To locate information about De'Longhi in your country, refer to http://www.delonghi.com/
Posted on May 24, 2010
Dane1234
  • 25 Answers
SOURCE: eam3500 delonghi coffe machine
From page 21 of the owner's manual: Message: general alarm. Meaning: The inside of the appliance is very dirty. What to do: Clean the inside of the appliance thoroughly, as described in section 15. If the message is still displayed after cleaning, contact a service center.
Hope that all your machine needs is a thorough cleaning; it's not that difficult.
Posted on Jun 29, 2010
mnwarfield10
  • 452 Answers
SOURCE: The machine is making strange noises when grinding
when first started up turn the steam valve open to get out air ... job done i hope or you need it repaired ... bsc appliances 07779933829 we repair via postal service anywere .
Posted on Feb 27, 2011
My whirlpool oven model RBD245 is locked after the self cleaning cycle, it does not heat up even if i open the latch with a tool?
Whirlpool have the self clean latch assembly solenoid go bad and wont return back to unlock the switch to tell the control is is no longer in self clean. Replace the self clean latch assembly or make sure the switch on the assembly is in the non self clean mode, If the oven starts working then you know the problem if it still doesn't work then there may be other issues.
Feb 13, 2014 | Whirlpool RBS245PDS Electric Single Oven
My Delonghi Propane Heater will not stay lit.
this sounds strangely like a safety switch problem , ill bet the device that confirms the pilot lite lit before going to main burner has a problem
Jan 19, 2013 | DeLonghi SafeHeat Heater
My delonghi perfecta plus esam5450 tells me to descale when the last descale was only 3 weeks ago. It is 18 months old and I usually only need to descale every few months. However, the last 3 times i have...
Marion, mine does the same and is around the same age. Did you ever get advice regarding this. I don't use rain water, I use tap water, but same problem
Aug 16, 2011 | Microwave Ovens
After self clean cycle completed........oven not heating unless turned to 550 degrees. will not heat from 350 degrees up or down.
Hi
These kinds of issues are usually caused in ovens if a self cleaning cycle is used after a long time. The issue can either be a bad door switch/lock assembly or the oven temp. sensor itself that has gone bad. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then that then check the control and door switch and replace the part that is bad. Hope this helps...please post back for further assistance.
Daniel
Dec 28, 2010 | Maytag MER5530 Electric Kitchen Range
After self cleaning cycle, oven door will not open. the lever won't move.
in the rear of the stove there might be a wax motor that has melted not allowing the stove to be unlocked. or a stuck switch.
all too common with self clean ranges.
unplug stove, remove rear panel and begon looking for any type of heat damage, or any switches that may have been stuck closed.
i see this at least once per week
Oct 09, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Heat pump seems to be blowing alot of cold air and making more noise than it usually does
Most of the time when a heat pump starts blowing cold air it is low on refrigerant or **** in one cycle or the other. Try to switch from heat to cool several times. If this does not work you will ahve to call a service Tech . there is only so much you can do. Russ
Jul 23, 2009 | DeLonghi Heating & Cooling
Oven wont heat
That depends if the oven is electric or gas.
If it is electric, it can be heating element, temp probe, or control knob/buttons, board and wiring.
If it is gas it can be the igniter (check spark) , the thermostat, the safety valve that prevents accidental gas flow, or the control.
If the oven has self cleaning cycle, check that it is not stuck on self cleaning, try unplugging for a while and restarting self cleaning cycle in that case.
Check also What is wrong with your Range/Stove/Oven?
Mar 29, 2009 | Ovens
Problem diagnosis please
touch pad is stuck on the control panel machine putits self in self test
Mar 03, 2008 | Washing Machines
Coffee Makers & Espresso Machines Logo
22 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
