Question about Weber Genesis Silver B Grill
How to replace ignition switch
How do I replace crossover ignition system on a weber Genesis Silver B gas grill?
Where does the ignitor switch plug into ? genesis ....came unpluged
Posted on Jun 13, 2010
I think I need a new crossover ignition system for a Genesis 320 natural gas grill, where can I get one? I cannot find the correct one on your website.
Nancy, we don't have any parts on the FixYa website. But, if you're referring to to the crossover burner, that lights the last burner, you can find it at the following link under "tubing". http://www.appliancefactoryparts.com/gasgrillparts/brands/weber/weber-tubing.html
Hope this helps you and Happy Grilling. Thanks for choosing FixYa.
Aug 02, 2011 | Weber Genesis Silver B Grill
I have a full tank of propane - grill will not ignite. I have a weber silver model
Hi, Check the igniter and also the gas nozzle that it is not plugged with grease. Clean up and try again. Make sure that igniter is working properly. Replace if nescessary.
Jul 09, 2011 | Weber Genesis Silver B Grill
The igniter box inside the grill is rusting and disintegrating. I bought the Weber igniter kit at Home Depot, but it has a red push-button, and I can't see how to begin replacing the igniter under ...
I have provided 2 links for you. One is the Assembly Manual for the Genesis B 330
and the other is the Owners Manual. Both should prove invaluable to you, in replacing the Ignitor Button. You can download and print each manual for future reference.
Assembly Manual
http://help.weber.com/manuals/pdf_files_2011/Gas/Genesis%20ES%20Series%202007newer/AssemblyInstructions/Genesis_310320330_LPng_AssemblyInstrctns_56507_022811.pdf
Owner's Manual
http://help.weber.com/manuals/pdf_files_2011/Gas/Genesis%20ES%20Series%202007newer/OwnersGuides/Genesis_320330_LP_OwnersGuide_56508_111010.pdf
Hope this is some help to you. Please let me know. Thanks & Happy Grilling!!
Jun 17, 2011 | Weber Genesis Silver B Grill
Replacing the crossover ignition system in my weber genesis silver b grill. it has a propane tank. the small metal cover over the spark ignitor has rusted out.
What you're referring to is called a Collection Box. It traps gas so it will ignite. You can purchase a new one directly from Weber or from Appliance Factory Parts http://www.appliancefactoryparts.com/
Hope this helps you get the part you need. Happy Grilling!!
May 19, 2011 | Weber Genesis Silver B Grill
Burner won't ignite
Eventually grease and other debris will accumulate around the burners and require cleaning. Remove the burners, they should pull straight up and out and clean any grease. Also clean the inside of the base as best as possible. Replace burners and you'll be enjoying a grilled meal in no time.
May 02, 2010 | Weber Genesis Silver A Grill
Crossover ignition not working on weber gas grill
Check your wire connections at igniter button and igniter. Also you can buy a replacemnt at Home Depot.
Oct 28, 2009 | Weber Genesis Silver A Grill
The electronic ignition on my grill no longer sparks to ignite the gas. I replaced the battery and cleaned the contact points but there was not any improvement. Can the entire assembly be replaced?
Yes you can replace the entire assembly.
However you can try adjusting the spark gap to see if this will resolve the issue.
Heat will often expand the spark gap thus rendering a spark impossible.
Small adjustments and be careful not to break the ceramic insulator.
Many gas grills use a static ignitor that does not require a battery.
Big red button you push that causes a snapping noise. This makes a spark and lights the gas. These can last quite a long time and inexpensive too.
Oct 03, 2009 | Weber Genesis Silver C Grill
Weber grill
Can you tell if the gas is flowing? Its either dirty or perhaps your regulator got damaged.  I'd check that out.  Above all else, though, be careful!
Dec 05, 2007 | Weber Genesis Silver B Grill
Weber Genesis Silver B Grill Logo
3,628 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
