Question about DeLonghi Coffee Makers & Espresso Machines
DeLonghi ESAM5450 stuck on heating up cycle on start up
General warning coming up in heating cycle.Not working at all.
For DeLonghi Perfecta ESAM5500 Fully Automatic Bean to Cup Coffee Maker Team De-Brewerz.com says:
1. General Alarms should be taken care by authorised delonghi technician only. Please do not try to fix yourself as it is related to safety.
2. This error occures due to loose wirings, opened water circuit, failure of heating elements and last failure of PC board repalcement.
3. Please contact your nearest Delonghi authorised dealer for technical support.
4. You can claim the warranty if recently purchased through De-Brewerz.com . If you are in India then contact us at de.brewerz@gmail.com
Nov 03, 2014 | DeLonghi Perfecta ESAM5500 Fully Automatic...
My delonghi perfecta plus esam5450 tells me to descale when the last descale was only 3 weeks ago. It is 18 months old and I usually only need to descale every few months. However, the last 3 times i have...
Marion, mine does the same and is around the same age. Did you ever get advice regarding this. I don't use rain water, I use tap water, but same problem
Aug 16, 2011 | Microwave Ovens
The machine is making strange noises when grinding
when first started up turn the steam valve open to get out air ... job done i hope or you need it repaired ... bsc appliances 07779933829 we repair via postal service anywere .
Jul 20, 2010 | DeLonghi EAM3400 Espresso Machine
The Diffuser is stuck inside the machine , with the shaft extended. and the warning light is on , before that all the lights were blinking
Try unplugging your DeLonghi; wait a few seconds; plug it back in. The diagnostic cycle should run. Then TURN OFF your DeLonghi. You should now be able to open the door and remove the diffusor for cleaning.
Jun 29, 2010 | DeLonghi Coffee Makers & Espresso Machines
Heat pump seems to be blowing alot of cold air and making more noise than it usually does
Most of the time when a heat pump starts blowing cold air it is low on refrigerant or **** in one cycle or the other. Try to switch from heat to cool several times. If this does not work you will ahve to call a service Tech . there is only so much you can do. Russ
Jul 23, 2009 | DeLonghi Heating & Cooling
The coffee pot won't turn on anymore
burnt thermal fuse or heater does heater work under coffee pot? :)
Jul 03, 2009 | DeLonghi DCM485 Coffee Maker
Stopped brewing
Tim, I do not have any pics of the fuse. If you follow the 2 wires that connect to the element upwards you will find it. It is covered with a heat resistant sheath.It is right next to the heating element. The fuse is maybe a half inch long with wires on each end. I believe mine was silver. Good luck, I hope this helps you. Mark.
Jun 10, 2008 | DeLonghi DCM485 Coffee Maker
Coffee Makers & Espresso Machines Logo
77 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
