Question about Microsoft Metrologic MS9520 Voyager Barcode Scanner - P/N MK9520-72B09 Handheld Barcode Scanner
Download metrologic ms9520 scanner software - Microsoft Metrologic MS9520 Voyager Barcode Scanner - P/N MK9520-72B09 Handheld Barcode Scanner
5 Suggested Answers
penmobile
SOURCE: Metrologic barcode scanner - laser is a dot not a line
This would be a fault with the scan engine. The dot is created when the mirror inside of the scan engine is not oscillating. The best solution is to have the device repaired, hopefully your scanner is still under warranty, or to purchase a replacement. /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:612.0pt 792.0pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Posted on Mar 20, 2009
NextStepComp
  • 185 Answers
SOURCE: metrologic inventory scanner software will not
try the driver at http://www.bioticaindia.com/ms-7120.html
Posted on Dec 31, 2009
SOURCE: Microsoft Metrologic MS9520 Voyager Barcode Scanner problem
If it is using the MX009 USB Cable it wont scan with the standard configuration. You will need extra configs such as enable Rs-232 Mode, Enable Xon/Xoff handshaking etc..
These can be found on the www.Metrologic.com website which will divert you to Honeywell website
Posted on Jul 08, 2010
  • 91 Answers
SOURCE: We are using a Metrologic MS9520 (keyboard wedge)
What I would first is to bring the barcode scanner back to factory defaults. To do this you will need the manual that came with the scanner, on the first page is a bar code that say "enter/exit configuration mode" scan that first and you will hear three beeps, then scan the bar code for "recall defaults" and rescan the bar code to "enter/exit configuration mode" then retry using your scanner, if this does not work bring up "notepad" on your computer and try to scan any bar code form any retail item. This should scan, if it does net then it could be a defective scanner. See page 2 on the manual link
http://www.posguys.com/download/voyagerprogramming.pdf
Posted on Nov 11, 2010
Driver for Honeywell MS9520
Yo! I will have to direct you to a website where you can download anything for your computer. please follow the links below..
www.download.com
http://www.filehippo.com/
Aug 13, 2011 | Metrologic Instruments HoneywellMetrologic...
We are using a Metrologic MS9520 (keyboard wedge) with QuickBooks. It won't scan barcodes provided by Quickbooks, even though it's supposed to be compatible. We've downloaded about every driver, config,...
Nov 11, 2010 | Microsoft Metrologic MS9520 Voyager...
May 25, 2010 | Microsoft Metrologic MS9520 Voyager...
Mar 09, 2009 | Microsoft Metrologic MS9520 Voyager...
Can't even start Metrologic voyager 9520
The MS9520 with RS232 needs the AC adapter plugged in to operate, the adapter plugs into the serial cable at the plastic "bulge". Cable part number is 53000c-3
Hope this helps, Terry @ TAG Technical INC
Mar 13, 2008 | Metrologic Instruments 9520 Voyager
Voyager scans into hyer terminal but not Notepad
Did you read the installation and configuration manuals? I download them from this website:
http://tinyurl.com/359pwh
Your scanner might note be configured correctly.
here are the guides I downloaded:
http://tinyurl.com/2sakgf
http://tinyurl.com/33gh4g
And the MFG website where you can download the material:
http://www.metrologic.com/corporate/products/pos/ms9520/
The scanner and host system must use the same communication protocol. I have a feeling the scanner is not configured correctly. The USB and serial connectors are 2 different types of configuration, but there are more.
You can also download the drivers and POS software from there website.
Feb 14, 2008 | Metrologic Instruments 9520 Voyager
Ms9520
try to reset a bar code ,from the manual
Jan 24, 2008 | Metrologic Instruments METROLOGIC VOYAGER...
Metrologic MS9520
You can reset back to original setting using your manual. If you are using cash register you need to look for the right settings in order the scanner will working.
Rate me SOLVED
Nov 21, 2007 | Metrologic Instruments 9520 Voyager
Microsoft Metrologic MS9520 Voyager Barcode Scanner - P/N MK9520-72B09 Handheld Barcode Scanner Logo
27 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
