Changing the battery for a haverhills navigator
I recently changed a discharged battery of my Toyota Sequioa 2008 model, and now my entire JBL Navigation and Audio system is not working.
by changing the battery with out maintaining a voltage for the radio and any other electronic gear , you have lost codes and other operational information that you will have to reinstall to get it all to work again
Jul 07, 2016 | 2008 Toyota Sequoia Limited 5.7L V8
I recently changed a dead battery on my sequoia 2008 and now the entire Navigation and audio system is not working. There is power but it keeps saying that a navigation dvd is not in
I work on a lot of different vehicles. When changing batteries, I use an external power source to keep radios and navigation intact, to avoid these problems. Owners manuals tell you this. And I know, about 1 in 20 cars I work on have manuals in them. You'll have to take it to a dealer to fix your problem.
My navigation program keeps shutting down, and the screen colours have changed automatically.
A likely cause is that the battery is "dead" ... i.e. no longer holds a charge. The GPS runs on battery power, even if it is plugged in. It will work even if the battery holds a (small) charge. But if the battery doesn't hold much of a charge anymore, the device may go into "power saving mode" ... that's where you'll notice the screen brightness goes down, the screen color changes, etc.
If this is the case, you'll want to change the battery.
If this is not the case, it is possible that the navigation software is corrupted. And you'll want to restore it from backup, or download a fresh version (from TomTom.com).
Sep 16, 2013 | Tomtom Navigator 5 1H50.082 GPS Receiver
2000 Lincoln Navigator won't start. First time in 12yrs.
im a import guy ..im tell u its your battery post tht went b ad they cost 10 dollar ez fixs good luck
Aug 30, 2012 | 2000 Lincoln Navigator
Were can i buy the stand that orig came with the tv?
Try Best buy they should have a universal stand if not try Tops Electronics in Haverhill ma
Nov 06, 2009 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
Replaced battery in 2004 Lincoln Navigator No audio
radio anti-theft. Should have a code card you got with vehicle. might be stuck in your owners manual.
Aug 25, 2009 | 2005 Lincoln Navigator
Need a diagram for this overcomplicated machine
Will probably bin it. Long experience shows that the ONLY alternators worth having are the British made Newage-Markon which IMHO are superior to both Sawafuji and Mecc-Alte. Voltage Dependent Resistors (VDRs) also known as Transorbs are essential if long term reliability is desired from small gensets. Haverhill Generators get around the voltage spike problem another way - 8 microfarads across the output but one Haverhill generator that I repaired had vibrated apart its control box wiring and fan. These little machines all leave a lot to be desired unfortunately and seem to give endless trouble.
Jul 30, 2009 | Office Equipment & Supplies
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
