Question about Minolta Office Equipment & Supplies
Machine indicating oil can
Machine showing oil can and toner sign.and toner is in plenty
    President:
  • 3,085 Answers
It is time for MAINTENANCE by a Minolta Technician
Posted on Jun 04, 2009
I have replace ma toner now indicator is showing toner not recognised please give me some solution
Did you get your toner from an authorized toshiba retailer? If not and you bought recycled toner cartridges, tough luck. You've probably just destroyed your machine.
Dec 13, 2012 | Toshiba estudio 255 Copier
Sharp Al1655cs copier black smudge down center of page about as wide as a pencil
Hi
Sounds like a fusing error . If your able to wipe the toner off the page its a fuser unit problem (replace fuser unit).
Also clean the copier's paper rollers. Marks on copies will occasionally be the result of a dirty paper-rolling mechanism. Simply access these rollers (your photocopier will likely have a plaque or series of signs indicating the locations of these areas) and wipe them off.
Clean the copier bed's glass plate. One of the most common causes of blemishes in photocopies is a dirty glass plate. In some cases a permanent mark, such as a scratch, will be present on the plate, showing up in every copy as a dark line or spot. However, most problems attributed to the glass plate can be fixed by wiping the plate with a soft towel and common household glass cleaner.
Clear any excess toner that has spilled or overflowed in the toner cartridge chamber. Excess toner will almost always result in blemishes on your copies. The most effective means of cleanup is to remove the toner cartridge and set it aside, thoroughly cleaning up any spilled toner in the compartment before putting the cartridge back in place.
Check for low toner levels. Low toner levels can actually contribute to unsightly lines and blotches on a photocopy. Most photocopiers will automatically indicate the need to replace an empty or low toner cartridge; while the toner is low, these models will permit continued copying. Consult your photocopier's instruction manual or key to warning lights and indicators for how to tell if the toner is low or empty.
Aug 03, 2011 | Office Equipment & Supplies
I have e-studio 355, machine is indicate low toner. I replaced new toner cartridge but the machine show "toner not recognize". I try to replace the ic at the back of the old toner cartridge and...
Do not go very far yet, the problem is with the toner so I recommend you do what the machine says before looking somewhere else. replace with correct toner.
If you have a friend with the similar machine which is working properly try and get their toner put in your machine if it works buy similar toner if does not then it is the machine. You can also try your unrecognized tone in another machine see the results. The problem is just toner and the sensors in your machine.
Jul 14, 2011 | Toshiba e-Studio 205 Copier
My sharp ar5316e is showing a red triangle blinking light and no key is responding nether the start button
That indication is Toner Indication.You should change the toner,Now May be the toner chip also damaged. whether the machine worked after changing the toner then no need to change the toner chip,other wise the same indication still, then you change that one also.
Jul 08, 2011 | Sharp AR-5316 Advanced Digital Imager...
Toshiba e-studio 211 copier .Toner sign not remove please halp me anwerali78@yahoo.com
Machine shows "Toner not Recognized" when correct toner is inserted into MFP.
It can be due to main PCB faulty.
May 28, 2011 | Toshiba Office Equipment & Supplies
FS 3900 "Unknow toner istall" shows in display?
The message is indicating that you do not havea real Kyocera toner installed in the machine.
Apr 04, 2011 | Kyocera Mita KYOCERA/MITA - FS-3900DN Mono...
I'm changing the oil on my bike...how much oil needs to be put back in after i drained the old oil?
when all old oil is drained put some new oil to make sure all the old is flushed out think it comes in 2l bottles that have a window to show how much is left 3/4s is plenty and also window to show how much oil is in the bike will have an indicator or should have to show how much oil is in but if not just make sure the window isint totally covered as this is to much when the bike is standing straight is easiest to see
Feb 13, 2011 | 1987 Honda VF 750 C Super magna
KUWIT OIL COMPANY IAM FACING PROBLEM IN FAX MACHINE BROTHER 2820 MESSAGE SHOWS 'TONER LIFE END' AFTER CHANGING TONER MESSAGE REMAIN SAME PLEASE GIVE ME SOLUTION. I HAVE AROUND 24 FAX MACHINES BROTHER...
you must have remove the white mylar sheet from the catridge when loading it...if yes! you got to find back the white mylar (plastic sheet) that slot in between the drum and charger roller placed it back ( the position must be accurate) then slot in back the catridge.The white mylar sheet is to reset the drum life counter
Jan 26, 2011 | Brother Office Equipment & Supplies
RED LIGHT
If the signs that is blinking red which is shape like triangle , it is the toner cartridge indicator. The toner cartridge is empty.Try to pullout and check the toner cartridge, if it is light in weight it is already empty.
Feb 23, 2009 | Sharp AR-153E Copier
Toner issue with several third party toner cartridges
Here is the manual for that machine ( incase you don't have it, check out page 59
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=fcb5a95908d7e226bcd8ab88b0637b4f&q=Sharp+AL-1641CS
$100 for toner, wow, try these guys, I've used them and their services are good. Not sponsoring.
http://www.precisionroller.com/k_sharp_al-1641-cs_toner_cartridge/m180d4669c36/
Oct 22, 2007 | Sharp AL-1641CS All-In-One Laser Printer
32 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
