Question about Amazon Kindle Paperwhite
Removing back cover
Battery not working, need to open cover
Inner screen is crack on a kurio
Kurio 7 Screen Replacement
Written By: Eric Rice (and 6 other contributors)
Comments: 2 Favorites: 5 Completions: 12
Main guide photo
Difficulty
Moderate
Steps
12
Time Required
30 - 45 minutes
Sections
Back Panel
4 steps
Kurio 7 Motherboard Removal Guide
5 steps
Screen
3 steps
Flags
Grammar Police
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Introduction
This is an easier part to replace than many others on the Kurio 7. Most require soldering, but this one does not. However, you must exercise extreme care when taking the device apart so that none of the soldered connections are broken. In the event that they are broken, look to our other guides for repair tips.
Tools
Buy these tools
Phillips #00 Screwdriver
$6.99
Buy
iFixit Opening Tools
$1.99
Buy
Parts
Kurio 7 Replacement Screen
Available for sale on Amazon
Buy
Step 1 Back Panel
Begin by removing the rubber cover from the Kurio 7.
Add a comment
Post comment
Step 2
Remove the four 30 mm Phillips #00 screws from the outer case.
Add a comment
Post comment
Step 3
Insert the plastic opening tool in the gap between the front cover and the back cover of the device.
Slide the plastic opening tool around the edge of the device. Gently pry apart the tabs that hold the front cover and the back cover together.
Be careful not to break off the tabs that hold the front cover and the back cover together.
Add a comment
Post comment
Step 4
Once all of the tabs are removed, the back cover should come off easily.
Gently remove the back cover. There are wires inside that may get caught on the cover while removing it. These wires are soldered to their components and are difficult to reattach.
Add a comment
Post comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Buy Now
Step 5 Kurio 7 Motherboard Removal Guide
Use a plastic credit card, or other thin object, to separate the battery from the screen.
Be sure to work the card carefully and slowly around in order to not damage, break, or deform the battery.
Carefully set the battery aside.
Add a comment
Post comment
Step 6
Use a Phillips #00 screwdriver to remove the eight 40mm screws holding the motherboard in place.
Place the screws aside in a container separate from the other size screws. You will need these later.
Add a comment
Post comment
Step 7
Place the plastic opening tool on the base of the black ribbon clip and pull up, like a lever, to release the mount. This should release the clip holding the ribbon to the mount.
Pull the ribbon out of the mount.
Add a comment
Post comment
Step 8
There should be masking tape on the yellow ribbon. Pull the tape off of the motherboard and wrap it around the yellow ribbon.
Do not pull the tape completely off the motherboard, as it is used to protect components on the ribbon.
To remove the ribbon from the mount, follow the same steps in Step 3.
Add a comment
Post comment
Step 9
Pull back the ribbons and put the battery near the bottom of the Kurio.
The motherboard is now removed so that other components can be worked on.
Add a comment
Post comment
Step 10 Screen
Flip motherboard down near base of device.
Be careful not to pull out any wires when moving the motherboard.
Add a comment
Post comment
Step 11
This is tricky, and an extra pair of hands may help. Use the opening tool to pry the screen out from underneath the tabs holding it in place.
Once you have created some space between the screen and the cover, slide the opening tool under the screen.
Slide the opening tool around the outside of the screen, releasing the tabs as you go along.
Be careful not to pull too ******* the motherboard while doing this, as there are still many wires attached to the body of the device.
Add a comment
Post comment
Step 12
You have successfully removed the screen!
Pull the screen out from the casing.
Jan 07, 2018 | Tablets & eReaders
How do i fix my asus tablet its froozen on screen cant turn it off
Take a flat object like a butter knife, start near a corner and pop the back cover loose...then work your way around removing the cover, pull the battery out, press and hold the power button for a few seconds, put the battery back in, put the cover back on, turn the tablet back on.
Feb 17, 2015 | ASUS MeMO Pad HD 7
How do I open the cover on next book 8
The back of the next book is sealed its not supposed to be oppend if you open it the back will not stay on unless you glue it back on
Nov 19, 2014 | Nextbook Premium 8 Se Android
Hoe to change galaxy tab batery
I do not believe it is all that easy to take the back cover off. Depending on which model of the tablet you have you need special tools. A plastic picnic knife might be helpful but then there are a couple of screws to open as well.
The different models have slightly different process. See these sites.
Samsung Galaxy Tab 10 1 Battery Replacement
Samsung Galaxy Tab Battery Replacement
Samsung Galaxy Tab 2 7 0 Battery Replacement
Sep 02, 2014 | Samsung Galaxy Tab Tablet PC
How to dismantle pantech p4100
although the manual is referring to the back of the tablet as battery cover, they don't mention how to open the tablet. They want you to contact the Pantech repair centre if you want it fixed.
I sen could not find a solution on ifixit.com for your tablet.
Sorry
Jul 08, 2014 | Pantech Tablets & eReaders
Tablet will not charge or come on.
I did this with my Asus memo pad 7 HD and it worked. http://www.youtube.com/watch?v=PXcQgpISSi8
The difference is only in removing the back cover. Use your nails to pop the cover to prevent damage. Do not use knife. Unplug the battery for 15 minutes than plug back in and pop the rear cover back on. After plugging the charger you should have the battery symbol on the screen. Then leave on the charger until fully charged.
Apr 01, 2014 | ASUS MeMO Pad HD 7
How to remove the battery to pandital
Removing the PDN bottom coversCaution Be careful not to put too much pressure on the display, there's glass under there! The larger back cover slides down away from the smaller cover. there s is a seam on the back that divides the two It is held in place internally by 2 strips of double sided tape, one on each side. Start by working a thin plastic tool guitar pick into the horizontal seam under the Pandigital logo. The cover is held securely by clips on the sides one in the center of the seam. As you open the seam, you are trying to overcome the grasp of the double sided tape & that's all. Be sure slide the cover down sufficiently 1/8 before you try to lift it up. Once you move it far enough to hear the hold of the tape let go, you should be able to lift the cover off. There is nothing electrical connected to the back cover. In the video, the double sided tape has already been removed & the cover slides open more easily than the first time. It is not necessary to remove the tape, as it will loose some of it's holding power & the cover will usually be easier to remove in subsequent attempts Removing the smaller (upper) back cover This info is a bit more sketchy, as I have not found detailed instructions, instead it is a collection of tips from those who have done it. The top of the back plate will be where the most resistance is. What I found is that you need to get the upper right side loose first if looking from the back once that's loose, you basically pry it off from there. It is very difficult to get off, even after the tape is detached. Every time I've done it I was sure I broke the **** thing because you get that cracking sound that makes your hair stand on end This cover does not slide to be lifted off like the larger cover. Instead you pry the sides OUT, because the tabs that hold it on push straight IN. Once you get those it's a matter of overcoming your fear and pulling hard enough to tear loose from the tape. Also, be smart. The top doesn't slide, but it has to be pushed UP to clear the switches. and remove the sd card
Oct 25, 2011 | PANDIGITAL 7270FW Tablet
I am using samsung galaxy tab, each time i click on camera, it says camera failed. As soon as i press ok, it takes me back to the main screen. I have bought the phone just a week back How can i rectify...
Being a NEW phone please do not attempt to open the set or trials as your set is covered under warranty. The best you can do is to remove the battery and reset to see if the phone works fine . if not get the free warranty support from the service dealer.
Jul 21, 2011 | Samsung Galaxy Tab Tablet PC
How do I install a keyboard in a Gateway M280E Tablet? (Directions with pictures a plus, but not absolutely needed.)
Power off and remove battery. Remove 2 screws on back cover marked with a K. Open display, gently pry off long thin silver panel between display and keyboard. With fingers at top of keyboard, pull up and flip top over toward ypu, then lay flat and upside down. Disconnect flat cable and remove the keyboard. Reverse steps to replace.
Apr 21, 2010 | Gateway M280E
Acer c110/ c112 CMOS Battery
Here is how I replaced it.
CMOS battery is under computer battery. Take computer battery out, open the cover under it you will see the CMOS battery is in black plastive cover. Cut a line through the cover until you can reveal soldering point. Use a soldering gun to remove the old one and solder the new one in. Wrap up the cover. You can buy sodering gun for 14 quit. I would not choose the risk to break the computer plus hours to disassemble & reassemble the computer. Note: Time is money! The time I spent is 3 minutes.
Sep 02, 2008 | Acer TravelMate C110 Tablet PC
Amazon Kindle Paperwhite Logo
Top Amazon Tablets & eReaders Experts
Lesley Cameron
Lesley Cameron
castletech
castletech
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
